WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
01-24-2005, 13:43 | #1 (permalink) |
Junior Member Join Date: Jun 2004 Age: 51
Member: 68540 Status: Offline Thanks Meter: 0 | help required flashing 6600 Is they a way I can flash the phone using my fbus cable connected to my pc ? Is so. what software do I need ? & where do I get the flash files ? & how do I do it ? Any help will be greatfully recieved Ta |
01-25-2005, 20:19 | #3 (permalink) |
No Life Poster Join Date: Dec 2001
Member: 8030 Status: Offline Thanks Meter: 3 | @payneardo - No you can't flash your 6600 using just an Fbus cable. You need a hardware solution such as Griffin/Twister-flasher/UFS3/Prodigy etc.......... to re-flash the phone and repair it. If you buy a solution from an approved reseller then it should come with all the necessary leads and flash files and instructions you need. Alternative is to find a place that unlocks phones and can flash it for you. Or if it's under warranty take it to a nokia service centre and they will repair it free (remember of course to deny "playing" with it, tell them you just switched it on one day and thats the message that came up) @ Khansb - stop asking the same question in many places - there is a section of the forum specially for requests like that. I don't know about Griffin - i use tornado flasher, but they are all basically the same method. start the software, connect the phone select the files to flash mcu/ppm/content files start the flash process. basically all there is to it |
01-26-2005, 12:28 | #4 (permalink) |
Freak Poster Join Date: Nov 2004 Location: philippines
Member: 93544 Status: Offline Thanks Meter: 1 | To buy gadget just to flash only one 6600 is not practical. Better to go to a nearby cellphone repair centre and let them fix your cellphone. Or you can try to manual format your cellphone. Press simultenously *3 and call sign then press the power button untill you see formating. i hope it will help. |
Please help me flash 6600s mr414 dead | rkozma50 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 01-31-2010 23:57 |
GTCL-001 Clip Code Calculator Update Required for 6600 | sound | Griffin | 0 | 03-30-2004 22:58 |
Help Required With Unlocking 6600 Tried This... | deetem | Phone Unlocking Codes & Maps | 0 | 03-15-2004 15:23 |
i NEED HELP ABOUT FLASHING 6600 | CELLTECuae | Griffin | 12 | 01-15-2004 19:41 |
