Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Digital Core Technology 4 ( DCT-4 ) > WD2 & APE (Symbian Phones)
WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708.
Old 01-28-2005, 07:22   #1 (permalink)
dreamzvk's Avatar
Member: 77518
N-gage QD booting problem...solution please
hi there,
my N-gage QD is not booting at all with battery support. it just shows nokia logo n get off immedeately. but while charger is on and i switch on the phone it says that memory full, not enough memory to perform operation.
pls help if there is any way that i can master reset (*#7373# ) the phone or boot the phone.
regards,
Vivek
Old 01-28-2005, 07:50   #2 (permalink)
Member: 98562
Hello,
I got the same problem as you 1 month ago. The only solution is to flash it at a Nokia Service Center or any mobile shop in your country. I did mine in a mobile shop here.
Hope it helps
Old 01-28-2005, 08:39   #3 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Sonork: 100.75672
Originally Posted by dreamzvk
hi there,
regards,
Vivek
friend! don't worry for that ,pls download a new ver. software and then reflasher that ,i will be ok. i have a same problem before , but when i flasher the new ver, everything was ok!
Old 01-28-2005, 08:41   #4 (permalink)
Member: 106320
That right,you should bring your phone to any nokia shop and ask them to reflash your phone....this problem cause when you send MMS via bluetool and the MMS got the memory lager than the device memory
Old 01-28-2005, 12:08   #5 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Moved to NGage section
Old 02-02-2005, 22:44   #6 (permalink)
Member: 58111
hi u can try reboot it with this code *#7780# ithink
Old 02-04-2005, 02:44   #7 (permalink)
Member: 89144
JUST reflasf it!Good Luck!
Old 02-11-2005, 20:35   #8 (permalink)
Member: 104866
my u dont have any problem just try and conect the phone to ur n gage qd cable and just do the write the flash after u do ui seting
Old 02-12-2005, 00:11   #9 (permalink)
Seedy's Avatar
Member: 8102
Has naybody got the PM file for the NGAGE QD (RH29) and the CERASE file as well ?
Thanking you in advance
Old 02-13-2005, 06:03   #10 (permalink)
Member: 106320
i got the PM but i have no erase file for Ngage QD....if you need the PM leave your email add here
Old 02-13-2005, 11:12   #11 (permalink)
Seedy's Avatar
Member: 8102
Thanks m8 - email is gsmhelps@aol.com
Old 02-14-2005, 00:45   #12 (permalink)
Seedy's Avatar
Member: 8102
Anybody else got this ?
Old 02-15-2005, 14:10   #13 (permalink)
Member: 105641
me also got the same problem...after sending back to shop..repair already..
p/s : wonder if QD problem will be this..??
Old 02-20-2005, 11:22   #14 (permalink)
Member: 106248
have you tried using an external MMC card reader maybe you just need to format the card it happened to me but luckily my phone turned on for 10 mins so i had a chance to format it and it worked.
N-GAGE QD MMC Corrupted Solution siang8788 Nokia Hardware & Hardware-Repair Area 2 07-29-2007 12:24
N-gage QD buzzer problem raffazila WD2 & APE (Symbian Phones) 0 10-30-2005 08:31
N-Gage QD Flashing Problem?????? ccw123 WD2 & APE (Symbian Phones) 3 04-15-2005 10:53
N-Gage QD unlocking problem win_christianto WD2 & APE (Symbian Phones) 4 02-13-2005 02:56
N-Gage QD software problem?? anson81 WD2 & APE (Symbian Phones) 2 12-07-2004 04:04
Page generated in 0.56181 seconds with 11 queries
