Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Digital Core Technology 4 ( DCT-4 ) > WD2 & APE (Symbian Phones)
WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708.
Old 05-02-2009, 15:22   #1 (permalink)
zeeshan tayyab's Avatar
Member: 828294
Sonork: 100.1615866
nk 3230 start up failed
bro,i have this fone with fault of startup failed contact retailer,i flashed it with ufs and jaf normal and with full erase,but same,i try to format with ufs and manually but not effective,the problem is when i try to format manaully,it shows little bit running with format screen but after 10% formatting it stoped and power on with contact retailer,i try to rehot flash ic but not effective,any idea to solve this problem,thanx.
The Following User Says Thank You to zeeshan tayyab For This Useful Post:
Old 05-02-2009, 18:04   #2 (permalink)
[ABDULLAH]'s Avatar
Member: 1021182
FIRST TRY TO FORMAT IT WITH ( * + send key + power button ) IF NO RESULTS THEN FLASH IT WITH
HIGH VER FLASH FILE AND THEN POST YOUR RESULTS
ABDULLAH81
The Following User Says Thank You to [ABDULLAH] For This Useful Post:
Old 05-15-2009, 17:56   #3 (permalink)
nomi_42us's Avatar
Member: 500844
flash with latest firmware do ui and then format user area.....
Old 05-16-2009, 09:42   #4 (permalink)
robean's Avatar
Member: 538410
Sonork: 100.1590750
ABDULLAH81
FORMAT IT WITH ( * + send key + power button + 3 )including 3 also
Old 05-16-2009, 09:49   #5 (permalink)
Member: 961701
Format with UFS "Fromat use" or * + send key + power button + 3
Old 05-16-2009, 09:51   #6 (permalink)
Member: 961701
Format with UFS "Fromat use" or * + send key + power button + 3.
P/s: Mod remove
Old 05-17-2009, 08:46   #7 (permalink)
Member: 544692
1. reboll f12 flash ic and cheak bsi path
2. and formet 4 time in ufs.............
cheak this
Old 07-17-2009, 14:28   #8 (permalink)
Member: 1051414
Sonork: 130304
erase flash,flash with higher version,format user area,write pm,full factory default,init sim lok.
good luck
Old 07-18-2009, 14:52   #9 (permalink)
Member: 235110
if you had rehoot flash ic already but not solve that problem....try to change small flash ic with the new one. (k8s6415/ns064)
3230 Phone Start up Fail Repaired By Typhoon Chennairam Typhoon Dongle 8 08-28-2011 16:23
nokia 3230 phone start-up failed help me palav Nokia Hardware & Hardware-Repair Area 10 08-28-2011 10:34
nk 3230 start up failed zeeshan tayyab WD2 & APE (Symbian Phones) 8 08-05-2009 08:52
SX1 generate this error at start "phone start-up failed picike E-Gold Based Phones 8 02-17-2007 12:26
Page generated in 0.26866 seconds with 11 queries
