Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Digital Core Technology 4 ( DCT-4 ) > WD2 & APE (Symbian Phones)
WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708.
Old 11-04-2008, 02:16   #1 (permalink)
magixian's Avatar
Member: 61176
Sonork: 100.86572
No way without format +8801715794512
I HAVE A NOKIA 3650 WHEN POWER ON IT ONLY SHOWS THIS DISPLAY AND STOPS THERE
NO WAY WITHOUT FORMAT +8801715794512
I FLASHED MORE THAN 20 TIMES AFTER ERASE STLL REMAIN.
THE ONLY THING I FOUD OUT IS COLOUR OF THAT DISPLAY CHANGES AFTER EACH FLASHING
AFTER HOURS OF SEACHING, I ONLY FOUND THIS
http://www.google.com/search?q=%2B88...L_enNG242NG242 WHICH IS NOT ENGLISH
PLS HELP ME!
Old 11-06-2008, 02:54   #2 (permalink)
Rhyan777's Avatar
Member: 893209
Hmmmmmmm..............
What version you use?????????
POST THE LOGS.........
Try to FLASH the unit using v4.13 or lower 3.15..
Hope it HELPS.........
Brother...
Old 11-07-2008, 03:46   #3 (permalink)
magixian's Avatar
Member: 61176
Sonork: 100.86572
i tried everything you said
but i already solved problem
i got erase file from jaf support,
flashed it as mcu,
then flashed as normal and wrote pm
Old 11-10-2008, 02:00   #4 (permalink)
gsm2start's Avatar
Member: 894719
Sonork: 100.1580092
flashed it as mcu,
well done mate and thank you for your good work
alot of members may need this solution
thank you for sharing
TUTORIAL: Recover memory card password on s60 phones without formatting knucles9000 Nokia Base Band 5 ( BB-5 ) 15 08-05-2012 10:45
Unlock MMC Card Without Formatting gsm2share Various 7 07-02-2009 14:48
Unlock MMC Card Without Formatting alamgarh Various 2 06-29-2008 18:08
E90 N95 micro sd password recovery without format ? shimano1234 Nokia Hardware & Hardware-Repair Area 1 05-22-2008 09:06
D500 Flash Without Format? revolver861 SWIFT Platform 0 06-15-2005 23:18
Page generated in 0.31438 seconds with 11 queries
