Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Digital Core Technology 4 ( DCT-4 ) > WD2 & APE (Symbian Phones)
WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708.
Old 03-07-2005, 10:14   #1 (permalink)
Member: 71212
Nokia 3650 blinking.
Please i need help.
After full flashing (v3,17) with Ufs (MCU+PMM) 100%, phone blinking and i can't make full factory defaults. Also a can't read, when i make unlock it said wrong IMEI, please help me if there is problem in IMEI or i need to make any other step in order to work.
Also i read UEM as *ask file but i can't convert in *fls in order to write it.
Thanks
Arsidi
Old 03-22-2005, 14:47   #2 (permalink)
hans0001's Avatar
Member: 84177
Try to flash it wid Griffin....
Old 03-22-2005, 15:17   #3 (permalink)
jepor's Avatar
Member: 97261
Originally Posted by arsidi
Please i need help.
Thanks
Arsidi
1st: U must detect u're phone (used Griffin); 2nd: if the phone is detect then U just choise the sub menu for the SPECIAL FUNCTION and click FORMAT USER AREA and U're phone already to used else if the phone is no detect then u must FUllflash U're phone.
Please regard's me.
Old 03-23-2005, 10:01   #4 (permalink)
Member: 75424
get the full erase file from the twister site erase it with PPM area then flash MCU and PPM same file which u have selected before after flahing do format user area it will be ok
Old 03-24-2005, 13:41   #5 (permalink)
freedomizer's Avatar
Member: 123931
reez is saying the right thing. But you'll have to rebuild your IMEI after flashing ppm too.
Old 04-21-2005, 19:50   #6 (permalink)
Muneer Ahmed's Avatar
Member: 60500
ya man i also agree with reez idea..............
Old 04-21-2005, 19:55   #7 (permalink)
Member: 60500
hey man u MUst................................... do what reez have written then ur fone will be ok...............
Old 04-22-2005, 06:58   #8 (permalink)
Member: 123931
I said earlier you'll have to rebuild IMEI, but twister can't rebuild IMEI for this phone, I think there's only a paid solution somewhere. Anyone know?
Old 04-22-2005, 15:57   #9 (permalink)
Member: 31246
I have the same trouble, the phone switch on and turn off itself. i flashes to change language, i used tornado and griffin, but the same result.
Old 04-23-2005, 08:09   #10 (permalink)
Member: 61877
pls help Me! I have 3650 dead after flashing.I format user area but couldnt work. Pls help Me.
Old 04-23-2005, 18:18   #11 (permalink)
Member: 123931
try writing a different software version into the phone. I once had a similar problem, then ended up going back to a lesser version and the phone started up.
Old 05-05-2005, 08:14   #12 (permalink)
Member: 61877
I didnt it and is the some, what next?Pls Help Me. Thanks
Old 05-05-2005, 08:19   #13 (permalink)
Member: 123931
1. Erase ALL flash manually
2. Flash with ver 4.17
after that I was usually able to get phone info with Twister and reset UI settings and restore PM and stuff.
If I didn't manually erase the flash it didn't work for me
Old 05-05-2005, 08:25   #14 (permalink)
Member: 61877
Thanks so much.Will try and reply U.
Old 05-05-2005, 08:44   #15 (permalink)
Member: 61877
Pls do well to send Me the ver 4.17 .
Nokia 3650 Blinks. Won't power On !!! tical Griffin 39 09-27-2008 09:22
Nokia 3650 blinking nokia only nellabe Nokia Hardware & Hardware-Repair Area 0 01-17-2008 05:39
nokia 7600 blinking trying with erase file 6600,3650 error 122121221 GSM MIND Griffin 1 11-07-2004 21:15
Alcatel 735 acting just like nokia 3650 in 4 blinks state. anyone seen this??? Alinus BF, BG, TH, BHx Series 1 12-22-2003 20:34
Page generated in 0.66518 seconds with 11 queries
