WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
06-01-2005, 08:41 | #1 (permalink) |
Crazy Poster Join Date: Nov 2003 Age: 55
Member: 43988 Status: Offline Thanks Meter: 0 | nokia 6600 cannot open bluetooh |
06-04-2005, 11:36 | #2 (permalink) | |
Freak Poster Join Date: May 2004 Location: Malaysia Age: 50
Member: 66197 Status: Offline Thanks Meter: 2 | Quote:
i hv the same problem that cant on bt but can on ir ,galaries n file manager cannt open ............ try to flash wif UFS or griffin but wen ever i try to flash it if i enable bt flashing it will be error ................. Write Bt.pm ok but still have d same problem ???????? any solution ???????????? | |
06-04-2005, 23:56 | #4 (permalink) |
No Life Poster Join Date: May 2005 Age: 48
Member: 146798 Status: Offline Sonork: 100.1576177 Thanks Meter: 24 | first u can do BT repair software by using one of saras boxes (twister ,tornado,..) new virsions if ur problem still then rehot BT or change BT unit |
08-28-2007, 15:03 | #6 (permalink) |
Junior Member Join Date: Jun 2007 Location: Indonesia
Member: 527563 Status: Offline Thanks Meter: 4 | first open the cane on the bluetooth module and you'll see three black ic's, rehot it about 20 sec and dont forget to use some flux around it. rehot means with hot air gun. temp about 400 degree celcius- air flow about 3. after that repair bt with your repair box such as tornado, universal box. if it doesnt work u must change the bluetooth module with a new one , good luck bro |
nokia 6600 cant open menu | obioha | MT-BOX | 1 | 08-29-2006 19:14 |
Nokia 6600 Cannot Open Gallery | castelloworks | WD2 & APE (Symbian Phones) | 13 | 05-23-2006 07:16 |
6600 cannot open galery...need help | tony84 | Nokia Digital Core Technology 4 ( DCT-4 ) | 11 | 05-05-2006 06:54 |
nokia 6600 not open galry application close | falak | WD2 & APE (Symbian Phones) | 4 | 04-22-2005 18:06 |
Nokia 6600 - cannot flash with Griffin!!! | gsmcaptain | Griffin | 13 | 10-10-2004 20:04 |
