Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Digital Core Technology 4 ( DCT-4 ) > WD2 & APE (Symbian Phones)
WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708.
Old 03-09-2005, 22:34   #1 (permalink)
Member: 123703
Is it possible to block incoming calls and txt on the Nokia 9500?
Hi I am desperate to find the software that will alow me to block incoming calls and txt, I have been told it is avaliable but can bot find it.
Can anyone help???
Email me direct if you like [email protected]
Old 03-09-2005, 22:47   #2 (permalink)
Member: 74443
yes u can block it by powering off your mobile!
But i have another powerfull sloution for your problem
Take your Mobile and put it out of the window
or send it to me i allways need new gsm!
no no ....
i think it will be better to ask this question your Service Provider !
Because laws are differnt in some countries
Old 03-10-2005, 22:36   #3 (permalink)
Member: 123703
Great thanks for nothing
I dont think you will find anyone sending you a free 9500 for advice like that, the reason I am asking this forum is because in th UK it is not possible for a servise provider to block and incomming call! So from now on only serious replys please!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 03-29-2005, 10:59   #4 (permalink)
Member: 131635
Well .... there is a SW called blacklist that will either let u block the unwanted incoming calls or accept calls from specefic numbers only.
Old 04-01-2005, 04:10   #5 (permalink)
Member: 114421
if you dont want incoming calls then just trun off your phone and trun it on whan you want ot make a call...
or use the offline profile to do that...
Old 04-22-2005, 16:41   #6 (permalink)
Member: 139590
First create a group from you contact. after that go to too-control panel-telephone then select profile setting. create a new group. Now enter necessary option. Lastly go to play for menu. under that you can see play ring tone for then change to user define and you can see the group you created then change it to yes.
To activate press the power button once and select the profile you had created. You will only recieve text & call from the group you created. Press power buttom again and select general profile to return to normal mode.
Hope this help
Easy way to block incoming calls and sms by MCleaner ho-by iPhone 2 / iPhone 3G / iPhone 3GS 3 10-01-2008 08:30
phones with possibility to block incoming calls .... microera Wanted Products 3 08-03-2008 18:37
Is it possible to block a set via network with imie??? chinex14 Off Topic Zone 10 04-12-2005 16:07
Is it possible to change ringtones, fonts, graphics etc on 3410? GeeZuZz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 09-22-2002 13:11
Page generated in 0.16805 seconds with 10 queries
