WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
05-30-2007, 00:48 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Philippines
Member: 230087 Status: Offline Thanks Meter: 373 | Post here all software problem 3230 nokia hang, flash with Twister-- dead! Try to flash with UB (universal box) first erase its fia (full erase) then flash it with high version after flashing write good pm then format user area and then unlock..... the phone is now alive and kicking strong!!!! |
06-02-2007, 04:21 | #2 (permalink) |
Member: 230087 Status: Offline Thanks Meter: 373 | here is another info to consider. have you ever tried to solve the 4 blinks (nokia start-up display on screen only) and yet not successful inspite of all attempts you made to repair it? here is my experience and I have tried this method to work perfectly mostly in 3650 & 3660. As in my case, 4 blinks can be repaired by formatting the unit by pressing "format user area (UFS) or "file system format" (JAF/MT). if not successful, then try full erase (1st,2nd & 3rd bin erase files, CCSerase). if not successful what then??? This is the final solution and tested 100% working. If all the above method is unsuccessful then it is a hardware fault and it is the flash or SDRAM fault or UEM. First check if IMEI serial No is ok, if it's ???????????????? then change UEM. if serial is ok then back-it up (if possible). Now Change Flash IC, first the application IC (usually F12) then flash the phone. if unsuccessful, then change all the 3 flash IC then flash after rewrite UEM, write PM then unlock! good luck. (don't forget to say cheeeseee...) |
09-11-2007, 12:47 | #3 (permalink) |
Crazy Poster Join Date: Oct 2006
Member: 374164 Status: Offline Thanks Meter: 1 | sir i have a nokia 3230 in dead condition i connect it to computer .... MCU: C:\Program Files\Nokia\Phoenix\Products\RM-51\RM51PE305171.C1 Booting phone... MCU ID: 0x1081 BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.40.00 -> Revision: 0007 Boot size is 0x10A8 Boot is ready... Error in CHK... Error Loading loader! please help me sir |
04-17-2009, 06:09 | #5 (permalink) |
Junior Member Join Date: Nov 2008
Member: 900247 Status: Offline Thanks Meter: 5 | 3230 flash problem i have mt-box & nokia 3230 dead phone, when flash show Processing File: RM51PE506140.C1 Boot... ASIC ID: 1081 WD2 BT2 w3_2nd.fia Configuration Info (9F): Number of Flashes: 4 00000000: Unkown, 78F0 7FFF 0000 78F0, 0 02000000: Unkown, 7FFF 7FFF 0000 FCF8, 0 04000000: Amd, 0001 277E 0002 0111, 0 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: 3424 D92C 0048 4B62 AF4D 850F 3657 5F40 %%%%%%%% ERROR BOOTING: please soloution any body how to solve this problem. thnaks |
04-17-2009, 06:09 | #6 (permalink) |
Member: 900247 Status: Offline Thanks Meter: 5 | 3230 flash problem i have mt-box & nokia 3230 dead phone, when flash show Processing File: RM51PE506140.C1 Boot... ASIC ID: 1081 WD2 BT2 w3_2nd.fia Configuration Info (9F): Number of Flashes: 4 00000000: Unkown, 78F0 7FFF 0000 78F0, 0 02000000: Unkown, 7FFF 7FFF 0000 FCF8, 0 04000000: Amd, 0001 277E 0002 0111, 0 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: 3424 D92C 0048 4B62 AF4D 850F 3657 5F40 %%%%%%%% ERROR BOOTING: please soloution any body how to solve this problem. thanks..... |
Post here all the problems for New Sonyericsson model from K800 and newer | roro_manool | Sony Ericsson Hardware Repair | 474 | 12-06-2014 16:09 |
post here all infinity problems | BHARGAV | Infinity-Box | 20 | 07-18-2008 11:10 |
Post Here All Ur Problems Appears On Ufsx | CONTACT-GSM | Nokia Hardware & Hardware Repair | 45 | 08-13-2006 04:45 |
Post Here All Ur Problems Appears On Ufsx | CONTACT-GSM | Nokia Hardware & Hardware Repair | 0 | 02-06-2006 14:27 |
