Problem with 6600 1 Attachment(s) I can't flash it with UFS. Does anibody have that problem? |
hi dejo, for some reason, i hav exactly the same problem with flashing a 6600! but hav no idea why ufs does that, or how to fix it, so ur not the only 1 in the dark! nix |
You need twister for this. Why ? Because it has better support. :D :D :D |
Hi guys Twister/UFS its all the same ain't it ? I flash 6600 100% ok Make sure ur using the latest Fia files check soldering on cable (couple of friends have had this issue) Was the handset functional before flashing ? If not try resolder flash ic Regards D. |
Problem solved, BT hardware faulty. thx to Legija ;) |
disabnle bt flashing, al will be fine |
disable bt flashing, all will be fine |
