RH 51 3230 flash file need 3230 flash file its very urgent |
how can i backup flash file for 3230 |
read mcu+pmm from a working phone ,then read pm and save without imei no read mcu+pmm from a working phone ,then read pm and save without imei no |
http://smartdl.ccw.com.cn/soft/ROM/S...CU7_0642_0.exe http://smartdl.ccw.com.cn/soft/ROM/S...CU7_0642_0.exe RH-51 Phone Data Package CHINA v.7.0 (MCU 7.0642.0) Installation ================================================== ============== NOTE !!! You MUST use Phoenix release 2006.34.2.156 or newer. See Technical bulletin for more detailed information on user settings handling with Phoenix v.2006.34.2.156 !!! Note! If some earlier version of RH-51 Phone Data Package is already installed, it must be uninstalled first. Close Phoenix before starting uninstallation or installation of Data Package. Go to Add/Remove Programs in Control Panel, then uninstall RH-51 Phone Data Package. Note! In some cases call logs might be empty after this SW update. Requirements: - Phoenix Release 2006.34.2.156 or newer - Save Settings feature must be DISABLED in FPS-8Flash (parameters menu) before flashing This installation package includes: - MCU software release 7.0642.0 chinese - Variant packages (PPM) for MCU software 7.0642.0 chinese for following variants: * APAC2-Chinese * APAC3-Chinese * Hong Kong * PRC * Taiwan - RH_51.ini file, that includes - options used in flashing - list of settings that can be saved from customer's phone when updating software - <product code>.ini files, that define - names of flash files - variant packages (language packages and EPOC settings) that belong to each product - default settings for each product - SW setting files (Product profiles) - User interface configuration file for Product Profile tool (rh_51_52_67_68.ppu) - Label printing files (600dpi only) - RH-51.val includes product type specific module information for Faultlogger - autotune_RH-51.ini allows user to align product's RF part automatically - rh_51_tunings.ini that specifies some TX Power Level tuning targets for RH-51 - readme_ch.txt (this file) Date: 10-11-2006 Copyright ?Nokia Corporation. All rights reserved. |
