WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
07-25-2008, 16:33 | #3 (permalink) |
Junior Member Join Date: Feb 2006
Member: 232131 Status: Offline Thanks Meter: 2 | read mcu+pmm from a working phone ,then read pm and save without imei no read mcu+pmm from a working phone ,then read pm and save without imei no |
The Following User Says Thank You to alabarago For This Useful Post: |
07-28-2008, 07:30 | #4 (permalink) |
Freak Poster Join Date: Jun 2008
Member: 788782 Status: Offline Sonork: 100.1610033 Thanks Meter: 1,035 | http://smartdl.ccw.com.cn/soft/ROM/S...CU7_0642_0.exe http://smartdl.ccw.com.cn/soft/ROM/S...CU7_0642_0.exe RH-51 Phone Data Package CHINA v.7.0 (MCU 7.0642.0) Installation ================================================== ============== NOTE !!! You MUST use Phoenix release 2006.34.2.156 or newer. See Technical bulletin for more detailed information on user settings handling with Phoenix v.2006.34.2.156 !!! Note! If some earlier version of RH-51 Phone Data Package is already installed, it must be uninstalled first. Close Phoenix before starting uninstallation or installation of Data Package. Go to Add/Remove Programs in Control Panel, then uninstall RH-51 Phone Data Package. Note! In some cases call logs might be empty after this SW update. Requirements: - Phoenix Release 2006.34.2.156 or newer - Save Settings feature must be DISABLED in FPS-8Flash (parameters menu) before flashing This installation package includes: - MCU software release 7.0642.0 chinese - Variant packages (PPM) for MCU software 7.0642.0 chinese for following variants: * APAC2-Chinese * APAC3-Chinese * Hong Kong * PRC * Taiwan - RH_51.ini file, that includes - options used in flashing - list of settings that can be saved from customer's phone when updating software - <product code>.ini files, that define - names of flash files - variant packages (language packages and EPOC settings) that belong to each product - default settings for each product - SW setting files (Product profiles) - User interface configuration file for Product Profile tool (rh_51_52_67_68.ppu) - Label printing files (600dpi only) - RH-51.val includes product type specific module information for Faultlogger - autotune_RH-51.ini allows user to align product's RF part automatically - rh_51_tunings.ini that specifies some TX Power Level tuning targets for RH-51 - readme_ch.txt (this file) Date: 10-11-2006 Copyright ?Nokia Corporation. All rights reserved. |
The Following 2 Users Say Thank You to MTK-BOX For This Useful Post: |
10-24-2009, 14:33 | #5 (permalink) | |
Junior Member Join Date: Jul 2009
Member: 1078040 Status: Offline Thanks Meter: 152 | Quote:
The Following User Says Thank You to fani_cm For This Useful Post: |
RH 51 3230 flash file | CHAUDHRAY ARSHAD | Nokia Base Band 5 ( BB-5 ) | 4 | 10-09-2009 07:30 |
RH-51 7610 all files v6/7 are corrupted!?! | sale | MT-BOX | 0 | 04-13-2007 10:37 |
RH-51 7610 all files v6/7 are corrupted!?! | sale | Griffin | 0 | 04-13-2007 10:01 |
Need rh 51 3230 flash file | viks | UFS2 + UFS3-Tornadoflasher | 0 | 09-30-2005 07:09 |
