Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Digital Core Technology 4 ( DCT-4 ) > WD2 & APE (Symbian Phones)
WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708.
Old 06-02-2004, 19:48   #1 (permalink)
mailhassan's Avatar
Member: 23834
Thanks Meter: 27
3650 blinks white screen after flash with latest version
hi guys,
one of my 3650 had a four blinks problem which i flashed and then it stopped blinking and instead hangs on showing tha nokia at start up. i then had to download latest flash file 4.13.... and now it only shows a blinking white screen with no words of nokia, then goes off. i've tried to reflash with old flashes but the same error. please can any let me know what happened?
Old 06-02-2004, 20:48   #2 (permalink)
eko
eko's Avatar
Member: 30098
Thanks Meter: 29
Try flashing with a lower version , like any of the 2.series, it should work, most likely with the hanging nokia , this time format user area, till its ok,may be 3 or 4 times.
Old 06-02-2004, 21:15   #3 (permalink)
Registered User
Member: 7308
Thanks Meter: 18
after the flashin remove your mmc (memory card) from your phone and test it.
mybe your memory card is damaged
Old 06-02-2004, 21:52   #4 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Thanks Meter: 1,097
Try Format user area after flash.
Old 12-18-2004, 05:05   #5 (permalink)
Member: 11729
Hi same case with my 3650 white screen only after flashing and cant put in local mode so format user area is impossible. Any more suggestions? Tnx in advance....
Old 12-18-2004, 05:17   #6 (permalink)
Member: 87194
try flash with a more lower version, if still unchange, there maybe something
happend on your firmware, you should have a detail check.
br
Old 12-18-2004, 07:08   #7 (permalink)
pazeth™'s Avatar
Member: 74519
Thanks Meter: 79
used griffin and eraseflash then make full flash mcu-ppm-pm with old version..., everything will be ok
Old 12-18-2004, 08:10   #8 (permalink)
clinic*mobile's Avatar
Member: 20833
Thanks Meter: 5
only use from cceraseppm.fia in ppm flash and write ppm correct and unlock
no need full flash
best regard
Old 12-18-2004, 18:45   #9 (permalink)
hans0001's Avatar
Member: 84177
Thanks Meter: 29
Damuho,
White screen only,,means,,,some files are still missing....What box are u using????
Old 12-20-2004, 16:17   #10 (permalink)
Member: 79888
tyr to format the use area three times
Old 12-21-2004, 00:52   #11 (permalink)
mec
mec's Avatar
Member: 58291
Originally Posted by mailhassan
hi guys,
only for 4.13 you must check FULL FACTORY DEFAULT after flashing immediatly if you use UFS2/UFS3. And this version 4.13 only work at Griffin with SAS.
Old 12-21-2004, 16:46   #12 (permalink)
Member: 79888
i have two 3650 nokia one with camera not showing after snap, and the other one when you record with camera it doesnt record sound only image, pls somebody should help me out
Old 12-18-2008, 14:23   #13 (permalink)
Member: 854592
flashing with a lower version and Format user area then write pm then lint sim lock abd good luck
Old 12-19-2008, 08:00   #14 (permalink)
pavas's Avatar
Member: 792200
Thanks Meter: 64
U have to flash it with only mcu with every version u hav with whic version local mode comes slect that version ppm too n set will be ok 100 % its tested by me many times
K800 blinking white screen after flash the same tgsm Sony Ericsson Hardware Repair 4 01-11-2008 05:02
W810i white screen after flash with GOT TeeTeev GOT SEMC 5 05-03-2007 15:48
6630 dead after flashing with latest version why ? gsmservices MT-BOX 1 07-26-2006 17:17
3650 blank screen after flash with twister hekker Nokia Digital Core Technology 4 ( DCT-4 ) 8 11-11-2004 21:34
Page generated in 0.25470 seconds with 9 queries
