Main Sales Section This is the Main Sales Advertisement Section, Used By Dealers |
11-17-2014, 04:22 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: guangzhou-China
Member: 973222 Status: Offline Sonork: 100.1584595 Thanks Meter: 792 | Bomb!Lastest Ip dongle unlock iphone screen password ,more fast ,more easy more cheap Ip dongle - unlock iphone screen password Lastest version Completely dispenses with the computer , no need with set up , and fool-operation Charge your phone when you unlock-others can't The new compact design , military-use shell , stylish and durable. More fast More easy More cheap youtobe link ;https://www.youtube.com/watch?v=9BHm...ture=********* After series of unlocking products for screen lock of smartphones exsiting in market ,ALI SIM TEAM have launched a new unlocking tool -IP DONGLE Completely dispenses with the computer , no need with set up , and fool-operation . The new compact design , military-use shell , stylish and durable. in built 1000 sets of commonly used passwords, to help your quickly unlock. Speed is as twice as others the normal screen unlocking devices do. make your unlocking more accurate ,sloved the problem of tweeting even if phones are not unlocked which was a headache before. bring out the latest 5th generation adapter in order to get a flexible conversion . Price advantage, parity none , so that our customers really benefit . We are now on a global scale Recruitment or agencies . No more than 2 agents are needed for each country . Condition :buy at one time 50 pcs before 10. Usage 1.ip dongle has five keys , wherein the intermediate key is the Enter key and a start key M key is used to clear the decimal point and to start-up the screen . The remaining three keys are used to adjust the size of the figures . 2. at the beginning , with the end of the data lines linking the phone the other to link the dongle ,press the middle button , so the screen no longer flash, then you can adjust the figures yourselves, you can start whatever digital as you want,if you do not adjust , the in-built commonly used numbers will help your attempts , until the trial finished (from 0000 to 9999 ). Next step, press the M key , quickly press twice within a short time . The first press is due to remove the aboved spots , the second is to start the phone screen . After that , quickly press the middle key of the keyboard , now the device will enter figures automatically . 3. After successfully unlocked ,the dongle' buzzer will be called , and then the phone's screen will be automatically opened and you can use your mobile phone again happily . Note: 1.make sure to press the M key twice, and your action must be quick for pressing the key twice . Then, you have to quickly press the center button. If the interval time is too long , the screen will not stay bright ,which means your operation has mistakes . 2. the phone will vibrate after entering each array , . And during the unlocking process,the phone will still stay on. The lacking either of the above metioned only can prove your operation problems. 3. make sure your phone is under charge . 4. the sensing line will tweet when it is bright ,unless you have a black screen . and you have to debug the front commissioning end of the dongle if it is under another situation . ALI-SIM weichat:1074256126 whatsApp:15902076077 Sonork: 100.1593080 Sonork: 100.1578030 Sonork: 100.1584595 ALI-SIM |
