Main Sales Section This is the Main Sales Advertisement Section, Used By Dealers |
08-22-2003, 00:24 | #1 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Croatia and occasionally MARS
Member: 7828 Status: Offline Thanks Meter: 3 | NEW!! DCT4 Nokia IMEI changer !! and many more.........!!! Commselect Inc. is proud to present NEW WEB and FORUM, along with new scale of GSM Software and Hardware products, as well as many other Consumer electronics that todays world demands, ranging from Home Audio Video systems to Security systems for your Home and Car or Boat. Here we are about to list only some of most interesting items we can offer, other you might find on our WEB site, or if you do not find it there, feel free to send us inquiry over E-mail or give us a phone call. NEW !! NOKIA DCT4 IMEI changer !!! WORKS on ALL models !! 7650, 3650,6800, and new coming models !!! we can also supply UEM ic, by BEST PRICE !!! see it at: http://www.commselect.net/html/dct4imei.html Nokia Matrix Flasher box: Main Features: FULL SUPPORT OF DCT4 Phones MCU + PPM flashing Content Package flashing Bluetooth Code flashing Contact Service repair (if software related problem) SP Unlock + Security Code Reset, Special Resets All above mentioned features are supported on following phone models: 3510, 3510i, 3650, 5100, 6100,6310, 6310i, 6510, 6610, 7210, 7650, 8310, 8910, 8910i, 7250, 6800, 3300, 6650, 7250i !!!READY DCT 4 IMEI CHANGE on ALL DCT4 models incl. 3650, 7650, 3300, 6650, 7250i !! EXTRA money will be asked for this unique feature. FULL SUPPORT OF DCT3 Phones MCU + PPM flashing Content Package flashing Contact Service repair (if software related problem) SP Unlock + Security Code Reset, Special Resets, IMEI Change All above mentioned features are supported on following phone models: 3310, 3210, 5110, 6110, 6150, 5210, 5510, 6210, 6250, 3410, 2100, 8210, 8250 Works also on 9110, 9210, 9210 Models !!! __________________________________________________ _______________________________________ Original NOKIA Service Equipment FPS8 FLS4-S All Jigs, Service modules, service software __________________________________________________ _______________________________________ FLA-2000 Cables and Adapter Specification: FLA-2000 is needed to use "low price" DCT4 Flasher cables with Original Nokia Flashers FLS-4(s) or FPS-8 - Power cable for FPS-8 (Black = GND = outside of DC plug, RED = VBAT/VCC = inside pin of DC plug) Usage on FLS-4(s): - Connect the Fla-2000 to your FLS-4(s) by the 10-Pin Modular / 10-Pin Modular connection cable - Connection of the Power cable is NOT needed - Now you can use "cheap" DCT4 Flasher cables by pluging them in the RJ45 jack of the FLA-2000 Usage on FPS-8: - Connect the Fla-2000 to your FPS-8 by the 10-Pin Modular / 10-Pin Modular connection cable - Connect the Bannana plugs of the Power cable to your FPS-8 and the DC connector of it to the FLA-2000 - Now you can use "cheap" DCT4 Flasher cables by pluging them in the RJ45 jack of the FLA-2000 REMARK: Never connect any other power source to the FLA-2000 instead of the one from the FPS-8 !!! Set Includes: - FLA-2000 Converter Box - Power cable for FPS-8 - 10-Pin Modular / 10-Pin Modular connection cable for FLS-4(s) or FPS-8 - DCT4 Flasher Cable fitting for Nokia 3510 - DCT4 Flasher Cable fitting for Nokia 3650 - DCT4 Flasher Cable fitting for Nokia 5100 - DCT4 Flasher Cable fitting for Nokia 6100 - DCT4 Flasher Cable fitting for Nokia 6310 - DCT4 Flasher Cable fitting for Nokia 6800 - DCT4 Flasher Cable fitting for Nokia 7210/6610 - DCT4 Flasher Cable fitting for Nokia 7650 - DCT4 Flasher Cable fitting for Nokia 8310/6510 - DCT4 Flasher Cable fitting for Nokia 8910 - DCT4 Flasher Cable fitting for Nokia 9210 __________________________________________________ ______________________________________ Universal Unlock/Service Box Unibox Specification: - Based on Maxim 3232, very important for new phones - Indication LED`s for TX, RX, RTS, CTS, Power, Flash Supply - Uses RJ45 Plug for connecting the needed Phone cable - You can manually switch between FBUS and MBUS - Optional 5V test voltage for flashing some Phones like Trium and Ericsson - It gets external supplied so it works also on Laptops and with Softwares that doesn't enable the power - Power supply should be between 7-9 V DC Mobile phone Cables that are included: (42 Pieces + 1 Nokia Adapter Cable) NOKIA 3210 (F/M-BUS) Unlocking; Change Logos and ringtones; change IMEI etc. NOKIA 3310/3390/3410 (F/M-BUS) Unlocking; Change Logos and ringtones; change IMEI etc. NOKIA 5110/6110/6150/6210/6250/5190/6190/6210/6310/7110 (F/M-BUS) Unlocking; Change Logos and ringtones; change IMEI etc. NOKIA 8210/8850/8290 (F/M-BUS) Unlocking; Change Logos and ringtones; change IMEI etc. NOKIA 8310/6510 (F/M-BUS) Unlocking; Change Logos and ringtones NOKIA 3510 (F/M-BUS) Unlocking; Change Logos and ringtones NOKIA 8910 (F/M-BUS) Unlocking; Change Logos and ringtones NOKIA 7210/6610 (F/M-BUS) Unlocking; Change Logos and ringtones NOKIA 7650 (F/M-BUS) Unlocking; Change Logos and ringtones NOKIA 6100 (F/M-BUS) Unlocking; Change Logos and ringtones NOKIA 3650 (F/M-BUS) Unlocking; Change Logos and ringtones NOKIA 5100 (F/M-BUS) Unlocking; Change Logos and ringtones NOKIA 6800(F/M-BUS) Unlocking; Change Logos and ringtones ERICSSON 388/337/318/218 Unlocking; flashing ERICSSON 688/788/888/A1018/T10/T18 Unlocking; flashing; IMEI change etc. ERICSSON T28/A2618/R320/R310 Unlocking; flashing; IMEI change etc. MOTOROLA T191 Unlocking; flashing etc. MOTOROLA V60/66/70 Unlocking; flashing (read info only), Internet etc. MOTOROLA T205/T2688 SIEMENS C25/S25/C35/M35/S35/SL45/S45/ME45/A35/A36 Unlocking / Connecting /Internet / Logos and Ringtones, change IMEI etc. SIEMENS S30/C30 Unlocking; flashing, IMEI change SIEMENS S40 Unlocking; flashing SIEMENS S55 Unlocking; flashing ALCATEL DB/3XX/5XX/7XX Unlocking; flashing ALCATEL BF 310/311/510/511 Unlocking; flashing ALCATEL BG 525 Unlocking; flashing ALCATEL BF 715 Unlocking; flashing PANASONIC G450/G500 Unlocking; flashing PANASONIC GD30/GD70/GD90 Unlocking; flashing PANASONIC GD92/GD93/GD52 Unlocking; flashing PANASONIC GD55 Unlocking; flashing SONY CMD-C5/Z5/Z15/Z18 Unlocking; flashing SONY CMD-J5/J7/J70 Unlocking; flashing PHILIPS SAVVY/Azalis Unlocking; flashing BOSCH 508/509/607/608/718/738 Unlocking BOSCH 908/909 Unlocking Sagem 7xx/8xx Unlocking SAGEM 9XX/MY-5X Unlocking; flashing; IMEI change etc. MITSUBISHI Trium Astral/Geo/Galaxy Unlocking; flashing; IMEI change MITSUBISHI Trium Mars/Neptun Unlocking; flashing; IMEI change SAMSUNG SGH600/2100/2400/N100 Unlocking SAMSUNG SGH2200 Unlocking SAMSUNG A100 Unlocking SAMSUNG A300/N400/R2XX Unlocking SAMSUNG A200 Unlocking SHARP GX10 Unlocking Other parts included in the Set: NOKIA 7650 OPENING TOOL - easy unlock slide and open mobile RS232 connection cable male / female for connect box with PC Remark: Optional cable XDA cable (RS232-XDA) LG cable Fitting for Motorola T205/T2688 __________________________________________________ _______________________________________ 2 WAY FM/FM REMOTE STARTER&ALARM WITH LCD DISPLAY With the #2000/#2100 2-way advanced interact system function, car owner not only can remote control his car for features like Remote engine start, Anti-Hijack, Arm/disarm, Door lock/unlock, Open trunk release but also can monitor his car security status any time. The user-friendly displays by #2000/#2100, user can definitely learn current status of the car. The remote control range is approximately from 300 to 500 M and its monitoring range approximately from 1200 to 2200 m. If the armed system is triggered by any possible intrusion or when any remote command is received by the system, the system will transmit different signals through its transmitter module to the LCD remote. The peerless function of Anti-Hijack will not only warning car owner with any violation situation through the transmitter; but remote immediately to stop the car engine operation as to stop any Hijack situation. Features: Unsurpassed interactive monitoring range up to 2200 meters in open area Unique exceptional 4 keys LCD transmitter with high tech black lit display clarify car status with any situation. SMART, GENERATOR, TACHO 3 types REMOTE ENGINE START for Auto Transmission and Manual Transmission. Wide Operating Temperature Range for both RF & SYSTEM Anti-Hijack system Remote Open Trunk at any car status. All time Range check, Alert user when out-of-range to ensure pager is in effective range all time 4 sets previous violation record memory __________________________________________________ ___________________________________ see all above items http://www.commselect.net/html/catalog.html Best regards Commselect Inc. www.commselect.net |
The Following User Says Thank You to sixkiller666 For This Useful Post: |
voice changer and many more application for nokia s60v3 download it and enjoy | malikraghav | Nokia Multimedia | 3 | 03-03-2010 18:00 |
voice changer and many more application for nokia s60v3 download it and enjoy | malikraghav | Nokia Multimedia | 0 | 07-01-2009 09:42 |
NEW!! Low priced ALL DCT4 Imei changer !! and much more, see it........ | sixkiller666 | Main Sales Section | 0 | 09-04-2003 11:46 |
DCT4 Flashing PPM , Upgrading and many more !!! | 666 | Main Sales Section | 28 | 05-03-2002 00:57 |
