10-19-2016, 03:31
#1 (permalink)
Member: 79315
Thanks Meter: 6,025 | SHP - the best professional toolkit for your electronic hardware repair needs ! @All, We are looking for worldwide reseller ! Product Description: - All functions are finely controlled using our custom made software control system with real time data display
- General settings and operating ambient temperature ranges can be programmed using our software in order to work with or without computer
- Has 4 integrated temperature sensors (internal temperature, heater temperature, external temperature and real time temperature tester K Type sensor)
- The heating system has automatic temperature control that can keeping temperature constant and accurate while you work
- An integrated 4 digits LED Display that can display all necessary data including state, temperature and voltages
- A built in temperature tester function that can accurately and efficiently measure solder iron and hot air temperature (Measurement range: -125 - 1200 ℃, Tolerance: ± 1 ℃) in real time . This way you can be sure your rework tools are correctly calibrated and working at peak performance
- Heating panel A made from high purity copper with an efficient method for high heat flux design
- Heating panel B made from aluminum can separating glass etc(Compatible size for 13 inch and below)
- With panel B can use for baking、drying、aging etc (Eg.water-flooded components of UMT mainboard)
- Almost all current PCB integrated circuits can be soldered and de-soldered without the need of a soldering iron or a hot air gun. (Eg,Apple A7 A8 A9 A10 CPU 、baseband IC or harddisk IC etc)
- Can act as a pre-heater for your everyday needs to minimize the risk of component damage
- Smart phones, iPad products's glass lens, touch screens & LCD displays can be separated in a few mins
- Default factory settings with general working conditions specification (Eg. Glue remove、IC de-soldering & Soldering、lens & touch screen assembly settings etc)
- Integrated self-resetting overheat protection
- LED warning alerts and sound alerts
- Voltage overload protection integrated
- Short circuit detection integrated
- Automatic shutdown function integrated
- All functions are user customizable
- Lifetime free software upgrades and more
Add-ons Software (Activation required): - Working with all Apple product and Huawei Android Mobile Hisilicon based mobile device (Called iMFC)
Technical Data: - Operating voltage: AC 220V & DC 5V(USB)
- Output Power: 300W
- Temperature Range:Room temperature - 350 ℃
- Temperature Tolerance: ± 3 ℃
- SHP Box Size: 226*90*45 MM
- Heating panel A Size: 58*12 MM
- Heating panel B Size: 315*220 MM
- Gross Weight: 3.7Kg
Package content: |
