Go Back   GSM-Forum > The Market Place > Main Sales Section
Main Sales Section This is the Main Sales Advertisement Section, Used By Dealers
Old 01-03-2008, 23:40   #1 (permalink)
techgsm's Avatar
Member: 10350
TechGSM.com EasyMini Flash, Smart-USB>LPT, Adapter 7.5k JAF
http://www.techgsm.com/MiniUSB_micro...er_,40971.html
MiniUSB -> microUSB converter allows to use existing cables for convert miniUSB into microUSB - due this you can use with any cable and fit for yoru needs, so if you need for Nokia BB5 unlock you connect for Nokia cable, if you need for Motorola V8 - you connect to Motorola cable etc. Support all Boxex as BB5 Box, JAF Plus, MTBOX and others....
http://www.techgsm.com/_Cable_for_Sa...MTI,40972.html
Cable for Sagem 411X / 202C / 300C Unlock SMTI it's additional service cable for new Sagem models usign new type connector to unlock, flash or read phone code using SMTI without phone opening.
Supported phones: 200C, 202C, 300C, 411X
http://www.techgsm.com/ST7282_Chip_P...mer,41013.html
Supported chips:
ST7282
ST72T82
ST72E82
http://www.techgsm.com/USBLPT_Adapto...lip,41149.html
Smart Adaptor for Smart-Clip is specially designed by GsmServer team to enable Smart-Clip connection to PC USB.
Approved to be applicable for any Smart-Clip function.
LPT-port is no more necessary.
http://www.techgsm.com/Hand_microsco...00x,41151.html
Hand microscope magnification 60-100x. Hand microscopes with adjustable magnification (ZOOM) : 60-100x. Fitted with battery powered illumination system. Designed for inspection of fibre optic cable terminals.
After removing a screw plug the microscope can be used for observation of electronic components, material samples, preparations, etc.
Body made of resistant plastic with magnification, acutance control and illumination switch.
http://www.techgsm.com/Multifunction...ter,41159.html
Multifunction Automotive Meter. Multifunction meters designed for diagnosing and repairing petrol engines. Can measure among other things dwell angle of ignition distributor contacts and engine RPM.
http://www.techgsm.com/Super_Adapter_75k,41197.html
Super Adapter 7.5k. This is adapter for cables that required 7.k resitor change. Now there is no need to open cable and change resistor - you can simply buy this cable adapter and problem is fixed.
http://www.techgsm.com/Mini_Easy_Fla...ble,41204.html
Mini Easy Flash RJ45 JAF, UFS, HWK Cable is additional cable supporting following Nokia phones: 1200, 1600,1650, 2630, 2760 and more with minieasy slot.
Supports: JAF Box, Twister, UFS, N-Box, HWK, Mt-Box, GRiffin and other
All this product you can find here:
http://www.techgsm.com/cat_-1
Best regards
TechGSM TEAM
Problems with any 7.5K phone Fernyx GPGUFC - The best Universal Fbus Cables ever made 0 10-28-2009 05:12
Problems with all 7.5K phones Fernyx GPGUFC - The best Universal Fbus Cables ever made 3 08-19-2009 10:31
7.5k wire resistor where to get in the UK? The Repair Shop Off Topic Zone 4 11-10-2007 10:31
NEW cables in cheap price (jaf 7.5k adapter, 6500c.6500s.8600.2760.6267.2630etc) victor-in-gsm Main Sales Section 0 11-02-2007 05:41
Page generated in 0.20297 seconds with 11 queries
