Main Sales Section This is the Main Sales Advertisement Section, Used By Dealers |
04-21-2011, 13:49 | #1 (permalink) |
No Life Poster Join Date: Jul 2003 Location: Amman Age: 41
Member: 35002 Status: Offline Sonork: 100.98829 Thanks Meter: 167 | @ 5 usd only super xsim , gevey sim , siprit sim unlock iphone 4g all ver We are working on this for very long time and finally got close to a sucess. We are going to bring it out right after apple releasing iOS 4.x. It works compatible with baseband 01.59.00, 02.10.04, 03.10.01 and 04.10.01. No Jailbreak needed! No software unlock! Not breaking your warranty! Features: work without software Test-Point, Computer, logs, Cables or Hacks No more using your phone as only an ipod Unlocks without loosing the phones warranty Long lasting and durable solution Safe, secure and cheap key Fully Upgradable Hardware Supports Latest iPhone 4 OS 4.1 4.2 4.3 4.3.1 4.x Easy Unlock Solution for iPhone 4 (including iphone3, 3gs) Supports All Networks & Countires iphone 4 Sim Tray + Super Micro Sim included in Package. Free software Updates with optional Programmers Unlocks USA AT&T and other networks that cant be Factory Unlocked Technical Specifications: Based on a 0.10 mm thin FPC with gold Immersion RISC Micro Controller which can handle all voltages and speeds required in this environment FPC, components and solder tin used are ROHS compliant How to use the unlock sim card? 1. Close your phone ,Put the super x-sim with your sim card into the sim solt .then put inside phone 2. Open the phone ,Click accept when the SIM welcome Menu display on the phone 3. Do not do anything until get one signal. press accept. 4. Waiting 15 seconds ,don't do anythings. 5. After 15 seconds, Call Emergency number (sample 112, 911 and so on). then hung up at once in 2 second. 6. Open the FLy model in 5 seconds. waiting till display erroe prompt, close it . 7. leave Fly model. The "sim failed" , don't care it, wait for a few seconds and then have the signal it! Notice: 1.after follow up step also not singal, close your phone and try again 2.when you want use 3G function ,you should open the 3G function . 3.you can select the welcome language in the STK 4.IF YOU ARE KEEP GETTING A MESSAGE SAYING 'NO SIM', THEN YOUR SUPER X-SIM HAS BEEN ALREADY BROKEN. 5.IF IT COULD NOT GET YOU SIGNAL, PLEASE TRY TO TURN OFF 3G AND RESTART YOUR IPHONE. 6.YOU COULD NOT GET GPRS OR 3G WORKING, PLEASE TURN ON 'DATA ROAMING'. Technical Details: Does not do any changes to your SIM card or phone (you only have to make a cut in the SIM card) Does not influence any communication between the phone and the network and vice versa Real time on the fly communication modifications, does not reroute SIM card traffic (Its transparent to the phone) Works with normal and inverted protocol SIM cards Its slim enough to fit together with your SIM card into for Iphone 4 sim card. email @ msn : [email protected] sonrok 100.98829 Iphone Store |
The Following User Says Thank You to shadi For This Useful Post: |
