Main Sales Section This is the Main Sales Advertisement Section, Used By Dealers |
03-05-2012, 16:28 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: INDIA Age: 43
Member: 75612 Status: Offline Thanks Meter: 1,427 | Unlock iPhone 4S on 5.0.1 / 5.0 with Gevey SIM NO MORE 112, replaced with ONE CLICK =HOT= NO MORE 112, replaced with ONE CLICK unlocking method =HOT= - added more networks to network list - improved compatibility with cards [IMG]http://img215.imageshack.us/img215/2874/*************swithgevey.jpg[/IMG] [IMG]http://img40.imageshack.us/img40/2874/*************swithgevey.jpg[/IMG] INFO: Now GEVEY has a built in menu. Using this menu you programs the code (MCC & MNC) of your initial iPhone 4S network. This way you can use your Gevey with different iPhone 4S providers without reprogramming this settings on your computer using GEVEY DONGLE. You can find the STK Menu here in Menu-> Settings-> Phone-> SIM Applications. The menu should be compatible with most of the existing simcards, but there are some cards on witch the menu is not working. After the "Unlock Menu" title you can see a number like (310410). This number represents the MCC and MNC with what your GEVEY is programmed to work. The first 3 numbers are the MCC and the last 3 are the MNC. By default this is AT&T (MCC:310 and MNC:410). This feature is very usefull when you need to know for sure that your GEVEY is correctly configured for your iPhone 4S. The menu options are: A. "Unlock" will start the unlocking process B. "Most used networks" will display a list with the most common 15 networks so you can easily select between them C. "Custom MCC&MNC" is to be used if your iPhone 4S network is not found in the list of networks. (the MCC of the network must be 3 characters, the MNC must be also 3 characters if your network has only 2 characters MNC then you can add a 0 as the third character) The unlock procedure using UPDATE V9: 1. Update your GEVEY with Update V9 You can select the appropriate MCC and MNC using the software at this stage or later using the internal phone menu 2. Insert GEVEY ALL IN ONE and your simcard into iPhone 4S 3. Go to the phone menu and select your network using "Most used networks list" or "Custom MCC&MNC" or don't do nothing if you already selected the correct MCC and MNC using GEVEY DONGLE. 4. Press Unlock and wait for the signal to appear. IPHONE 4S unlocking DONE ! Gevey SIM Ultra S iPhone 4 Unlock - Supported Basebands / iOS: 1.0.14 iOS 5.0.1 (Build 9A406) 1.0.13 iOS 5.0.1 (Build 9A405) 1.0.11 iOS 5.0 (Build 9A334) GEVEY Ultra S iPhone 4S Unlock - Features : No Need to Dial International Emergency Number 112 Untethered Unlock with no Jailbreak Required Compatible with all GSM iPhone 4S SIM Cards Complete Unlock with all 2G and 3G data services No SIM Card Cutting or Physical Modifications Works on iOS 5.0, 5.0.1 Works on Baseband 1.0.11, 1.013, 1.0.14 Guaranteed Better Reception than Previous Decreased Power Consumption Contact Me: Name: Rajan Nishchal Shop: Cellularhut Country: India City: New Delhi Yahoo Cellularhut_Rajan ICQ: 488527778 Cell#:+91-9810 720 720 +91-9910 720 720 |
The Following User Says Thank You to rajan nishchal For This Useful Post: |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
