Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
11-10-2004, 10:25 | #1 (permalink) |
No Life Poster Join Date: Dec 2001 Location: United Arab Emirates, Dubai Age: 52
Member: 7751 Status: Offline Thanks Meter: 74 | Hardware Repair Series : 7210-6610 no power on after flash All credits and thanks for this goes to StuioGSM for posting the picture Please note that original bmp file of 855 kb was resampled to jpg 51 kb ! Regards |
The Following 3 Users Say Thank You to GSM Coolhawk For This Useful Post: |
11-10-2004, 10:30 | #2 (permalink) |
No Life Poster Join Date: Nov 2002 Age: 43
Member: 17689 Status: Offline Sonork: 100.72392 Thanks Meter: 737 | yes we know it its a track b/w flash and ram if the phone does`nt power on even after this track than replace RAM anyways thanx GSMCOOLHAWK Edit by GSM Coolhawk**The thanks goes to StudioGSM for posting picture** |
11-11-2004, 00:19 | #3 (permalink) |
No Life Poster Join Date: Jun 2003 Age: 37
Member: 30303 Status: Offline Sonork: 1001579198 Thanks Meter: 17 | ya it's work for me in water damage set 6610 but still no network pls help me i reflashed but nothing and no lights Edit By GSM Coolhawk @azampk Please take care. Stay within topic, this is for no power on when phone can be flashed. Make a new thread or search the bord, there's litterally over 40 posts containing your question regarding signal. Last edited by GSM Coolhawk; 11-11-2004 at 01:46. |
11-11-2004, 21:42 | #4 (permalink) | |
Freak Poster Join Date: Aug 2002 Location: Poland Age: 44
Member: 15122 Status: Offline Thanks Meter: 18 | Quote:
BR StudioGSM.pl | |
11-16-2004, 10:48 | #8 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Slovakia
Member: 7586 Status: Offline Thanks Meter: 11 | this solution is not working for me : when i connect this 2 capacitors then i cant flash my phone . see here : 9B0201008C2290000000800200000000... Failed to find FIA file in 'C:\Program Files\Nokia\Phoenix\flash\ In 994314770f the cases this is caused by corrupt FLASH folder. Fully DELETE the contents of the Flash folder, and then Install the latest FIA package! Error[78878778] bad ID of Flash ic . without this bridge i can flash my phone but dont power on after flashing . see here : Initializing Phone... Flash configuration: 9B020100EC22F2000000E00200000000... Boot and Flash loaders operation took 5.128000 seconds Erasing .... etc.. there is different FLASH ID . any idea ? Pali |
11-16-2004, 16:04 | #9 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Everywere Age: 46
Member: 18057 Status: Offline Thanks Meter: 64 | then try to make jumper btw capecitors . or try to on phone. if not then rehot ram or change ram, or sometimes uem also reason for this type of falult. @kki |
11-17-2004, 18:08 | #10 (permalink) |
Member: 7586 Status: Offline Thanks Meter: 11 | @akshay well Ram is changed , all BGA reballed , board doesnt seems to be damaged. if i connect this 2 Capacitors then i have error . If i dont connect i can flash my phone , flash id is correct. any idea? what about other Capacitors near RAM and FLASH IC ? Pali |
11-23-2004, 09:05 | #11 (permalink) |
No Life Poster Join Date: Feb 2002 Location: SIBIU
Member: 9411 Status: Offline Thanks Meter: 16 | 7210 I MAKE CONNECTION LIKE IN PICTURE,PHONE POWER ON 3-4 TIMES AND NOW ONLY WHEN I MAKE WITH TORNADO REBOOT IN NORMAL MODE PHONE IS POWER ON .WHAT IS THE PROBLEM? |
11-26-2004, 08:03 | #13 (permalink) |
No Life Poster Join Date: Aug 2002 Location: india Age: 63
Member: 14578 Status: Offline Thanks Meter: 831 | thanks m8, with your solution i can power on 6610, with c.s. imei is ????????????? phone can power on with twister normal mode for few second. need more help. thanks again. w.b.r. |
The Following User Says Thank You to baraka42 For This Useful Post: |
6600 no power on after flash help!!!!!!!!! | hansis | UFS2 + UFS3-Tornadoflasher | 33 | 04-06-2005 23:39 |
8130 ... No Power on after Flash | jokkergsm | LG | 1 | 03-10-2005 16:03 |
help 6100 no power on after flash | Nokall | Nokia Hardware & Hardware Repair | 9 | 12-23-2004 06:16 |
R520m no power ON after flash | pepik | Old Ericsson Phones & Sony Phones | 0 | 08-26-2004 21:38 |
