Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 06-10-2005, 11:33   #1 (permalink)
Member: 64744
6230 low signal
hi to all
I have here one 6230 and the signal strength is weak it can register to a network only when the signal is strong.
Does anybody have an idea about this problem????????
thank you
The Following 4 Users Say Thank You to phpl For This Useful Post:
Old 06-18-2005, 07:52   #2 (permalink)
Member: 64744
nobody know anything about this prob???????
i change the pa and the problem exist
any ideas plz halp me
thank you
The Following User Says Thank You to phpl For This Useful Post:
Old 06-18-2005, 08:02   #3 (permalink)
kardelen gsm's Avatar
Member: 133173
CHANGE antene sw..regards
The Following 4 Users Say Thank You to kardelen gsm For This Useful Post:
Old 06-20-2005, 00:04   #4 (permalink)
Cheater -Don't Deal with him-
unlockingteam's Avatar
Member: 148419
Sonork: 100.999999
Please also check that the antenna connector is having a good connectivity with motherboard and replace the antenna as well.
Thanks
The Following User Says Thank You to unlockingteam For This Useful Post:
Old 02-04-2006, 21:10   #5 (permalink)
Member: 2852
6230 network
Isn't there a solution to repair the network signal at a 6230? Like the one with a 6310 (wire soldering at antenna).
Old 03-10-2006, 14:46   #6 (permalink)
Member: 83476
I have same problem here is any one succsesfully solved this problem? please replay
The Following User Says Thank You to dipakgt9 For This Useful Post:
Old 03-18-2006, 12:02   #7 (permalink)
Member: 241915
i have the same problem as well.anyone have the solutions for this problem yet?
The Following User Says Thank You to maximus great For This Useful Post:
Old 03-23-2006, 08:01   #8 (permalink)
Member: 83476
Finaly I solved my problem after rebolling hager IC TRY this if some one have same problem before this I replace entena switch too
Old 04-13-2006, 10:13   #9 (permalink)
zullu2004's Avatar
Member: 146635
6230 signal drop only sometimes.signal full or medium.
when drop, signal 0, but not say's anything(no coverage.etc).
after 15 min, signal come back strong.
i try reflash, change pa, still no change.
it's antena switch, or what ?
thx
The Following User Says Thank You to zullu2004 For This Useful Post:
Old 06-10-2006, 03:53   #10 (permalink)
albert maren's Avatar
Member: 185010
i have 6230 that is hot & discharging batt. what will be the solution
The Following User Says Thank You to albert maren For This Useful Post:
Old 07-01-2006, 14:42   #11 (permalink)
Crazy Poster
Member: 28660
Thumbs up gooooooooo
Originally Posted by phpl
hi to all
thank you
u must change net filters
it will work ok
The Following User Says Thank You to scary For This Useful Post:
Old 07-01-2006, 14:49   #12 (permalink)
Crazy Poster
Member: 28660
Thumbs up wait to try
thx
i think u need to reball or change ur hilga
100% working
tested
The Following 2 Users Say Thank You to scary For This Useful Post:
Old 07-04-2006, 06:33   #13 (permalink)
Member: 47532
is 6230 pa same as 6230i?
Old 07-13-2006, 05:59   #14 (permalink)
Member: 11441
yes sir!..................................
Old 07-29-2006, 11:31   #15 (permalink)
Member: 320310
thank you sir 3100 net work problam solving help me (antina switch filter chang)other problam ok c u letar
nokia 6230 low battery Solutions shahalom007 Nokia Hardware & Hardware-Repair Area 4 03-11-2010 16:07
LG KG800 chocolate no signal or low signal ProGsm2K7 LG Hardware Repair Section 3 09-26-2009 12:38
6230 LOW mic rk19801 Nokia Hardware & Hardware-Repair Area 2 11-19-2008 05:34
6230 low ringing tone James-R Nokia Hardware & Hardware-Repair Area 1 03-09-2006 13:50
6230 low ringtone rihawi Nokia Hardware & Hardware-Repair Area 0 04-14-2005 10:04
Page generated in 0.43492 seconds with 12 queries
