Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
12-20-2007, 17:35 | #48 (permalink) |
Freak Poster Join Date: Oct 2004 Location: South Africa Age: 53
Member: 86981 Status: Offline Thanks Meter: 10 | hello i have a 9300 for one of my customers.. the lcd ribbons we get here in south africa do not have components on so we transfer them from the faulty ribbon. on the ribbon near the lcd coil is 2 ic's a big 6 leg and 2 small ones. i need to know were on what phone can i find a suitable replacement for this component. as the one leg is broken off Last edited by BalfourCellular; 12-20-2007 at 17:36. Reason: edit |
02-26-2008, 13:01 | #56 (permalink) |
Junior Member Join Date: Jun 2006
Member: 290380 Status: Offline Thanks Meter: 1 | 9500 white screen 9500 white screen MCU ID: 0x1130 FLASH ID0: 00012A7E -> AMD Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.00 Done! Phone Restarted... Backing up PM Field 208 as RPL... Setting local mode... Reading IMEI... Reading IMEI data... Building RPL backup file... C:\Program Files\ODEON\JAF\ProgData\354305001890925_imei_back up_183252.rpl Done! Backup imei OK! MCU: C:\Program Files\Nokia\Phoenix\Products\RA-2\RA2_4441.352 Booting phone... MCU ID: 0x1130 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.45.00 -> Revision: 0007 Boot size is 0x09A0 Boot is ready... FLASH ID0: 00012A7E -> AMD Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x7E2A0100 Flash loader is C:\Program Files\ODEON\JAF\Flash\m_amd.fia Loader version: 04.45.00 -> Revision: 0007 Loader size is 0x8148; Loader chk: 0 Loader is ready... P-key nokia module version 01.00 MSID: 843479D2896A0E0653B179A1AB MSID decoded: 3E4EBAE90096A25CA8000000 FAID: B69CA83C8820F10B507D0ED6 Operation took 0 minutes 14 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 0139FFFF... ADL -> MCU ID: 0xB470 ADL -> FLASH ID: 0x07009800 ADL -> Loader: C:\Program Files\ODEON\JAF\Flash\OMAP1510_TOSHIBAMDOCG3_7.adl ADL -> Sending loader... ADL -> Waiting connection to loader... ADL -> Verify connection... ADL -> Done! ADL -> Write: C:\Program Files\Nokia\Phoenix\Products\RA-2\RA2n4441.c01 ADL -> Writing flash... ADL -> Write 5% ADL -> Write 10% ADL -> Write 15% ADL -> Write 20% ADL -> Write 25% ADL -> Write 30% ADL -> Write 35% ADL -> Write 40% Erasing area: 013A0000 - 013EFFFF... ADL -> Write 45% Erasing area: 017A0000 - 017EFFFF... Operation took 0 minutes 28 seconds... Writing... ADL -> Write 50% ADL -> Write 55% ADL -> Write 60% ADL -> Write 65% ADL -> Write 70% Perm. Data Restore OK Operation took 0 minutes 15 seconds... ADL -> Write 75% ADL -> Write 80% ADL -> Write 85% ADL -> Write 90% ADL -> Write 95% ADL -> Write 100% ADL -> Write: C:\Program Files\Nokia\Phoenix\Products\RA-2\RA2n4441.l108 ADL -> Writing flash... ADL -> Write 5% ADL -> Write 10% ADL -> Write 20% ADL -> Write 30% ADL -> Write 35% ADL -> Write 40% ADL -> Write 45% ADL -> Write 55% ADL -> Write 65% ADL -> Write 70% ADL -> Write 80% ADL -> Write 90% ADL -> Write 95% ADL -> Write 100% ADL -> Write: C:\Program Files\Nokia\Phoenix\Products\RA-2\RA2n4441.u108 ADL -> Writing flash... Data len: 65408 -> Write ADL failed data! Restarting MCU... Flashing Done! Operation took 2 minutes 17 seconds... After flash processing... Waiting for phone to boot... Reading... Phone type: RA-2, Software version: 3.35.2 IMEI: 354305001890925 Product Code: 0521330 Resetting PPC... Setting FULL FACTORY......Setting test mode... Setting FULL FACTORY... Failed! Aborting! Failed! Aborting! Done! |
05-20-2008, 05:43 | #57 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Bangladesh
Member: 621121 Status: Offline Thanks Meter: 366 | 9500 white screen after nokia logo hi how o fix 9500 white screen after nokia logo. its true because hardware problem? i has try to flash it with HWK and Mt-box with latest firmware and no result. Ape flashing not completed yet... APE Flashing interface was not found . Aborting Flash procedure for APE when flashing. whats wrong? software problem or hardware? |
05-31-2008, 04:12 | #58 (permalink) | |
Member: 621121 Status: Offline Thanks Meter: 366 | Quote:
05-31-2008, 04:42 | #59 (permalink) |
Member: 621121 Status: Offline Thanks Meter: 366 | 9500 white screen Phone is in: Local mode Model: RA-2 ( 9500) V 4.64.40/27-04-2006/RA-2 (c) Nokia. Production serial number YBA118872 Product code 0520792 Module code Basic production code 0630742 Flash code Order number Long production SN MCU SW V 4.64.40/27-04-2006/RA-2/(c) Nokia. HW 6001 PCI UEM 16 UPP 4400 RFIC 0205 DSP E4.10A4.20 IMEI: ************** ============= Set Flash mode for info ============= VBat is 3.91V Vpp pin has 1.30V, Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Boot... DCT4 u_2nd.fia u_amd.fia ASIC ID: 1130 Configuration Info (9F): Number of Flashes: 2 01000000: Amd, 0001 2A7E 0024 0111, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 UEM IMEI is: *************** ============= Set FBus mode for info ============= VBat is 3.96V Vpp pin has 1.28V, Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Model: RA-2 ( 9500) V 4.64.40/27-04-2006/RA-2 (c) Nokia. IMEI: ************** Phone is in: Local mode Phone SelfTest status: Passed: UEM_CBUS_IF Passed: SLEEP_X_LOOP Passed: AUX_DA_LOOP Passed: EAR_DATA_LOOP Passed: TX_IDP_LOOP Passed: TX_IQ_DP_LOOP Passed: SIM_CLK_LOOP NotExecuted: PWR_KEY Passed: SIM_IO_CTRL_LOOP Passed: FLASH_CHECKSUM Passed: MBUS_RX_TX_LOOP Passed: SLEEPCLK_FREQ NotExecuted: BACKUP_BATT NotExecuted: WARRANTY NotExecuted: CURRENT_GAUGE_IF NotExecuted: XABUS NotExecuted: APE_POST_CODE NotExecuted: APE_RAM Summary: Passed(11), NotExucuted(7), OtherStatus(0) Flashing log VBat is 3.91V Using Tx2 Data line. Processing File: RA2_6270.6440 Boot... ASIC ID: 1130 DCT4 u_2nd.fia m_amd.fia 8426F7E3EBB9E8CCFA0C310DAA35 Configuration Info (9F): Number of Flashes: 2 01000000: Amd, 0001 2A7E 0024 0111, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[4.25 MB]... request erase [01000000 to 0100FFFF] request erase [01010000 to 0139FFFF] request erase [013A0000 to 013EFFFF] request erase [017A0000 to 017EFFFF] Waiting response for 300 Sec... %%%%%%%% ERROR ERASING: Failed at address FF000000 Ape flashing not completed yet... APE Flashing interface was not found . Aborting Flash procedure for APE |
06-08-2008, 11:04 | #60 (permalink) |
Junior Member Join Date: May 2006 Location: Italy Age: 44
Member: 285449 Status: Offline Thanks Meter: 0 | I have problem with a nokia 9500 after flash it ( all ok) insert the battery and the internal display light go on and off and the phone not boot, but if i connect the phone to the jaf and change in normal mode the phone start and not have a problem. We can help me? Regards, Alberto |
>>>>>>>>>>APPS for NOKIA 3250 post here <<<<<<<<<<<<<<<<< | parthiv_sk | Nokia Multimedia | 37 | 03-06-2013 10:53 |
Success in Nokia flashing. Post here all logs and Models name! | GSMtricks | Multi-Box | 2 | 12-16-2007 18:43 |
please, themes and games for Nokia 6101, post here ! | mg70brz | Nokia Multimedia | 1 | 10-26-2006 10:21 |
Nokia Problem Post Here... | Mang mel | Nokia Hardware & Hardware Repair | 15 | 01-27-2006 14:56 |
nokia 7610....post here | a2k24 | Nokia Multimedia | 2 | 07-29-2004 22:18 |
