Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 11-28-2007, 11:17   #46 (permalink)
Member: 306111
help. 9500 no signal. i have flashed the phone with tornado and replced pa, still no signal
Old 12-07-2007, 04:02   #47 (permalink)
rk19801's Avatar
Member: 238252
sir i have nokia 9500 in brand new condition but its ringer not working i check ringer its ok..plssssssssssss help..
Old 12-20-2007, 16:35   #48 (permalink)
BalfourCellular's Avatar
Member: 86981
hello i have a 9300 for one of my customers.. the lcd ribbons we get here in south africa do not have components on so we transfer them from the faulty ribbon. on the ribbon near the lcd coil is 2 ic's a big 6 leg and 2 small ones. i need to know were on what phone can i find a suitable replacement for this component. as the one leg is broken off
Old 12-20-2007, 18:24   #49 (permalink)
Member: 434317
Originally Posted by ..:MumbaiGsm:.. View Post
how to format 9300,9500 using keypads???????????
remove battery and put the battery in handset and open, before become nokia,press ctrl+shift+f key simulteneously.
Old 12-21-2007, 04:48   #50 (permalink)
Member: 220070
9500 discharging battery after charging full it would discharge in a very short time, Please anyone with this solution help.
Old 12-21-2007, 22:27   #51 (permalink)
Member: 610980
check your battery or watch for element that became hot. uem, pa...
Old 02-13-2008, 09:27   #52 (permalink)
mahadi's Avatar
Member: 562024
Sonork: 100.1589529
how i flash a nokia 9300?
Old 02-13-2008, 09:57   #53 (permalink)
mahadi's Avatar
Member: 562024
Sonork: 100.1589529
Old 02-20-2008, 02:55   #54 (permalink)
Rhyks's Avatar
Member: 243127
i need help 9500 insert sim
Old 02-21-2008, 07:28   #55 (permalink)
Adil Mobiles's Avatar
Member: 228476
Sonork: 100.1575078
Dear check it out. will help u
The Following User Says Thank You to Adil Mobiles For This Useful Post:
Old 02-26-2008, 12:01   #56 (permalink)
Member: 290380
9500 white screen
9500 white screen
MCU ID: 0x1130
FLASH ID0: 00012A7E -> AMD Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
P-key nokia module version 01.00
Done!
Phone Restarted...
Backing up PM Field 208 as RPL...
Setting local mode...
Reading IMEI...
Reading IMEI data...
Building RPL backup file...
C:\Program Files\ODEON\JAF\ProgData\354305001890925_imei_back up_183252.rpl
Done!
Backup imei OK!
MCU: C:\Program Files\Nokia\Phoenix\Products\RA-2\RA2_4441.352
Booting phone...
MCU ID: 0x1130
BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
Loader version: 04.45.00 -> Revision: 0007
Boot size is 0x09A0
Boot is ready...
Flash ID is 0x7E2A0100
Flash loader is C:\Program Files\ODEON\JAF\Flash\m_amd.fia
Loader size is 0x8148; Loader chk: 0
Loader is ready...
MSID: 843479D2896A0E0653B179A1AB
MSID decoded: 3E4EBAE90096A25CA8000000
FAID: B69CA83C8820F10B507D0ED6
Operation took 0 minutes 14 seconds...
Erasing...
Found 4 interval(s) to erase
Erasing area: 01000000 - 0100FFFF...
Erasing area: 01010000 - 0139FFFF...
ADL -> MCU ID: 0xB470
ADL -> FLASH ID: 0x07009800
ADL -> Loader: C:\Program Files\ODEON\JAF\Flash\OMAP1510_TOSHIBAMDOCG3_7.adl
ADL -> Sending loader...
ADL -> Waiting connection to loader...
ADL -> Verify connection...
ADL -> Done!
ADL -> Write: C:\Program Files\Nokia\Phoenix\Products\RA-2\RA2n4441.c01
ADL -> Writing flash...
ADL -> Write 5%
ADL -> Write 10%
ADL -> Write 15%
ADL -> Write 20%
ADL -> Write 25%
ADL -> Write 30%
ADL -> Write 35%
ADL -> Write 40%
Erasing area: 013A0000 - 013EFFFF...
ADL -> Write 45%
Erasing area: 017A0000 - 017EFFFF...
Operation took 0 minutes 28 seconds...
Writing...
ADL -> Write 50%
ADL -> Write 55%
ADL -> Write 60%
ADL -> Write 65%
ADL -> Write 70%
Perm. Data Restore OK
Operation took 0 minutes 15 seconds...
ADL -> Write 75%
ADL -> Write 80%
ADL -> Write 85%
ADL -> Write 90%
ADL -> Write 95%
ADL -> Write 100%
ADL -> Write: C:\Program Files\Nokia\Phoenix\Products\RA-2\RA2n4441.l108
ADL -> Write 5%
ADL -> Write 10%
ADL -> Write 20%
ADL -> Write 30%
ADL -> Write 35%
ADL -> Write 40%
ADL -> Write 45%
ADL -> Write 55%
ADL -> Write 65%
ADL -> Write 70%
ADL -> Write 80%
ADL -> Write 90%
ADL -> Write 95%
ADL -> Write 100%
ADL -> Write: C:\Program Files\Nokia\Phoenix\Products\RA-2\RA2n4441.u108
Data len: 65408 -> Write ADL failed data!
Restarting MCU...
Flashing Done!
Operation took 2 minutes 17 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RA-2, Software version: 3.35.2
IMEI: 354305001890925
Product Code: 0521330
Resetting PPC...
Setting FULL FACTORY......Setting test mode...
Failed! Aborting!
Failed! Aborting!
Done!
Old 05-20-2008, 05:43   #57 (permalink)
Member: 621121
9500 white screen after nokia logo
hi how o fix 9500 white screen after nokia logo. its true because hardware problem? i has try to flash it with HWK and Mt-box with latest firmware and no result. Ape flashing not completed yet...
APE Flashing interface was not found . Aborting Flash procedure for APE when flashing. whats wrong? software problem or hardware?
Old 05-31-2008, 04:12   #58 (permalink)
Member: 621121
pls help very argent
Old 05-31-2008, 04:42   #59 (permalink)
Member: 621121
9500 white screen
Phone is in: Local mode
Model: RA-2 ( 9500)
V 4.64.40/27-04-2006/RA-2 (c) Nokia.
Production serial number YBA118872
Product code 0520792
Module code
Basic production code 0630742
Flash code
Order number
Long production SN
MCU SW V 4.64.40/27-04-2006/RA-2/(c) Nokia.
HW 6001
PCI
UEM 16
UPP 4400
RFIC 0205
DSP E4.10A4.20
IMEI: **************
============= Set Flash mode for info =============
VBat is 3.91V
Vpp pin has 1.30V, Connected
Pins:
Mbus 1, Box Tx 1, Box Rx 1, Bsi 0
Boot...
DCT4
u_2nd.fia
u_amd.fia
ASIC ID: 1130
Configuration Info (9F):
Number of Flashes: 2
01000000: Amd, 0001 2A7E 0024 0111, 10
02000000: NotUsed, 0000 0001 0000 0000, 0
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
UEM IMEI is: ***************
============= Set FBus mode for info =============
VBat is 3.96V
Vpp pin has 1.28V, Connected
Pins:
Model: RA-2 ( 9500)
Phone SelfTest status:
Passed: UEM_CBUS_IF
Passed: SLEEP_X_LOOP
Passed: AUX_DA_LOOP
Passed: EAR_DATA_LOOP
Passed: TX_IDP_LOOP
Passed: TX_IQ_DP_LOOP
Passed: SIM_CLK_LOOP
NotExecuted: PWR_KEY
Passed: SIM_IO_CTRL_LOOP
Passed: FLASH_CHECKSUM
Passed: MBUS_RX_TX_LOOP
Passed: SLEEPCLK_FREQ
NotExecuted: BACKUP_BATT
NotExecuted: WARRANTY
NotExecuted: CURRENT_GAUGE_IF
NotExecuted: XABUS
NotExecuted: APE_POST_CODE
NotExecuted: APE_RAM
Summary: Passed(11), NotExucuted(7), OtherStatus(0)
Flashing log
VBat is 3.91V
Using Tx2 Data line.
Processing File: RA2_6270.6440
Boot...
ASIC ID: 1130
DCT4
u_2nd.fia
m_amd.fia
8426F7E3EBB9E8CCFA0C310DAA35
Erase[4.25 MB]...
request erase [01000000 to 0100FFFF]
request erase [01010000 to 0139FFFF]
request erase [013A0000 to 013EFFFF]
request erase [017A0000 to 017EFFFF]
Waiting response for 300 Sec...
%%%%%%%% ERROR ERASING:
Failed at address FF000000
Old 06-08-2008, 11:04   #60 (permalink)
Member: 285449
I have problem with a nokia 9500 after flash it ( all ok) insert the battery and the internal display light go on and off and the phone not boot, but if i connect the phone to the jaf and change in normal mode the phone start and not have a problem.
We can help me?
Regards,
Alberto
>>>>>>>>>>APPS for NOKIA 3250 post here <<<<<<<<<<<<<<<<< parthiv_sk Nokia Multimedia 38 03-06-2013 09:53
Success in Nokia flashing. Post here all logs and Models name! GSMtricks Multi-Box 2 12-16-2007 17:43
please, themes and games for Nokia 6101, post here ! mg70brz Nokia Multimedia 1 10-26-2006 10:21
Nokia Problem Post Here... Mang mel Nokia Hardware & Hardware-Repair Area 15 01-27-2006 13:56
nokia 7610....post here a2k24 Nokia Multimedia 2 07-29-2004 22:18
Page generated in 0.45440 seconds with 12 queries
