Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
02-22-2014, 17:37 | #1369 (permalink) |
Junior Member Join Date: Oct 2010
Member: 1430699 Status: Offline Thanks Meter: 0 | Nokia 5610 express music won't power on. Battery is fine. It shows battery charging when charger is plugged in but when I press on button the phone cannot power up. Please help me. |
03-21-2014, 02:22 | #1371 (permalink) |
Junior Member Join Date: Dec 2010
Member: 1477083 Status: Offline Sonork: albertlb Thanks Meter: 0 | hi, I need help pls, got nokia1200 here but when I turned it on security code was appeared, forgot my security code so ive tried to enter all possible code but still its stocked...then ill try removing simcard and power on but only demo appeared on the screen and insert sim.. please help me to fix this. thanks... |
06-15-2014, 21:23 | #1376 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2198084 Status: Offline Thanks Meter: 0 | nokia 710.1 screen touch digitalizer dont work. hello, i have a problem with my touch screen, changing the screen 4 times, not work, the problem is the motherboard, please could tell me the solution. |
07-31-2014, 19:40 | #1377 (permalink) | |
Junior Member Join Date: Nov 2009
Member: 1166538 Status: Offline Sonork: starplus Thanks Meter: 3 | How to open normal mode Quote:
I have nokia e63 which open in Local mode. Can you tell me what is the problem and how to solve out or how to open with normal mode. | |
11-08-2014, 11:42 | #1378 (permalink) |
Junior Member Join Date: Sep 2014 Location: RAMESWARAM Age: 36
Member: 2265302 Status: Offline Sonork: 9894544760 Thanks Meter: 3 | nokia 1280 dead Hello sir i need solution for nokia 1280 total dead, also help me to find genuine schematic for same model. thanks in advance |
02-10-2015, 05:37 | #1380 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2343946 Status: Offline Thanks Meter: 0 | Nokia RM-237 Is opening normal but the screen is black i cant see what im doing,the screen was changed because the previous screen was broken and this screen was working perfect but the next week it was black help i must open it with tiny tools? |
post all nokia software problem here, i will try to solved. | shahinahmed007 | Nokia Base Band 5 ( BB-5 ) | 145 | 11-04-2016 15:50 |
All Nokia Software Problem Solved .............. | GsmUniversal | Nokia Hardware & Hardware Repair | 19 | 02-26-2011 13:18 |
