Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
11-21-2004, 01:39 | #1 (permalink) |
Freak Poster Join Date: Nov 2003 Location: jordan
Member: 44186 Status: Offline Sonork: 100.108965 Thanks Meter: 65 | Converting 6200 to 6610 works 100% to 6610 (900/1800/1900) that could make it works 100% in some contrys 1- replace parts as in the attached pic 2- flash phone with nhl-4u (6610) mcu + pm 3- upload this spacial pmm to phone to avoid speaker problem (attached as TXT file convert it to RAR) tested by me.. enjoy .. |
11-21-2004, 02:17 | #2 (permalink) |
Junior Member Join Date: Oct 2004 Location: Egypt - 10 of ramdan Age: 45
Member: 86205 Status: Offline Thanks Meter: 0 | hi BoOzer, do i have to change the uem after flashing with 6610 flash ? someone told me that it will give me an IEMI :??????????????????????? another told me that i must use 6100 flash i am confused thnx.. |
11-21-2004, 11:04 | #3 (permalink) | |
Member: 44186 Status: Offline Sonork: 100.108965 Thanks Meter: 65 | Quote:
no need to change the uem.. you will not get imei:?????????????????? after flashing nhl-4u | |
11-28-2004, 01:09 | #4 (permalink) |
Member: 86205 Status: Offline Thanks Meter: 0 | hi Boozer the mobile 6200 works 100% but every time i try to make a call i get "battery empty" and my telephone is shutdown i try 3 new battry but the problem still the same what should i do ? plz need some help ( softwear or hardwear) ??????????????????????? |
11-28-2004, 02:57 | #5 (permalink) |
Freak Poster Join Date: Mar 2003 Location: MNE Age: 43
Member: 23848 Status: Offline Thanks Meter: 13 | Question:Why to replace the parts?I tried replacing the 6220 HF out with the regular HF out like on 7210/6610 and I saw no difference.I left the old antenna switch and the phone works fine. But the PM looks like a nice job! Salut! |
12-02-2004, 06:16 | #6 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | At all no need to change RX filter, just antena switch, add first GSM amplifier /and some parts arround his circuit/ and change GSM TX filter ... P.S. There important is "mixing" of 6200 6220 and 72/6610 PM-s to achieve speaker sound, low RF PA consumption and good network reception ... |
The Following User Says Thank You to debeliamark For This Useful Post: |
12-02-2004, 09:12 | #7 (permalink) |
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | And also one more - if someone haven't success with BoOzer's pm - try one attached from me |
12-05-2004, 02:43 | #8 (permalink) | |
to get best resoults just flow the pic .. in some countrys .. works on 900 mhz band u will get a weak signal if u left the anntena switch... | |
01-09-2005, 06:22 | #10 (permalink) |
No Life Poster Join Date: Dec 2001 Location: United Arab Emirates, Dubai Age: 52
Member: 7751 Status: Offline Thanks Meter: 74 | @BoOzer665 Added to sticky's All non contructive posts like "thank you" posts removed. Only posts in this thread trgarding this mod directly, question, additions ect will be kept intact. Regards |
***6800a to 6800 works 100%*** | lemor | Nokia Hardware & Hardware Repair | 53 | 10-28-2011 08:24 |
Converting 3100b to 3100. Works 100% | BoOzer665 | Nokia Repair Guide and FAQ | 242 | 02-22-2011 19:20 |
Converting 3220b to 3200. Works 100% | cooleyes | Nokia Hardware & Hardware Repair | 34 | 09-10-2007 11:10 |
6200 to 6610 convertion ok but........ | faisi | Nokia Hardware & Hardware Repair | 0 | 11-27-2005 09:56 |
NOKIA 6210 to 6250 WORKS 100% | forhike | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 08-28-2002 14:02 |
