Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
01-10-2007, 19:09 | #752 (permalink) |
Insane Poster Join Date: May 2006 Location: dubai, u.A.e.
Member: 275352 Status: Offline Thanks Meter: 17 | hi guys remove the front cover of your n73 and you will see the screw, and be careful for the next step after you remove the screw because there is a flex cable for some parts, ok, good luck twin army -=Blue_moon22=- |
01-11-2007, 07:16 | #753 (permalink) |
Junior Member Join Date: Jan 2007
Member: 428802 Status: Offline Thanks Meter: 0 | Hi buddy, I have a Nokia 3595 which was in use of my frnd at USA. Now as he sift back to PAKISTAN it is useless cause of frequency range.Do u have any solution for it else than dumping it...i think i can use it after changing its frequency to asia standard...but i dont know how? do u think m right and do u tell me how i can change its frequency. plz provide me detail info. thanks |
01-11-2007, 12:16 | #755 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: algeria BBA BELIMOUR Age: 46
Member: 184351 Status: Offline Thanks Meter: 263 | Quote:
hot the flash ic and your problem will be solved | |
01-11-2007, 12:48 | #756 (permalink) |
Junior Member Join Date: Sep 2006
Member: 353034 Status: Offline Thanks Meter: 0 | help me with 3250!! I want to know where the bluetoothed files go. I know it goes to inbox, I don't mean that one! I want to see the transfered file in my "file explorer". I couldn't find it. I know where the file might be, it should be in one of "private" or "Sys" folders, but I don't have access to these folders. they are protected, and no matter what I do, I can't access those folders. HELP ME!!! |
01-11-2007, 22:41 | #757 (permalink) |
Major Poster Join Date: Oct 2006
Member: 374198 Status: Offline Thanks Meter: 4 | my nokia 6101b shows check multimedia settings on the screen when i power it on. when i press ok, it says multimedia sending failed. check multimedia settings stays on the screen . how can i get that off the screen so i can use the phone??? Please ?????? |
01-13-2007, 03:30 | #760 (permalink) |
No Life Poster Join Date: Apr 2005 Location: brunei
Member: 141262 Status: Offline Thanks Meter: 348 | 3220 need attention!! elo guyz have here 3220. this phone send totally dead.. i try to full flash the phone. it finished alright but only local mode try set factory failed.. try to on a battery still cannot on.. what do u think guys i'm a little confuse by now!! thanks... |
01-15-2007, 12:57 | #765 (permalink) |
Freak Poster Join Date: Apr 2004 Location: secunderabad Age: 55
Member: 63691 Status: Offline Thanks Meter: 114 | I had a 6600 ok phone,some times display gets white,I flashed the phone with new version,the phone got dead.it is accepting all files in flashing,but after flash process it says failed.the product cede is:0507787,can anybody help in sending 0507787.ini file. thanks in advance |
any mobile or computer problem solve in 24 hours free . | sindhi kanu | Nokia Base Band 5 ( BB-5 ) | 11 | 12-01-2010 16:50 |
Solve your problem whit in 24 hour | kashantariq2002 | Nokia Hardware & Hardware Repair | 16 | 12-01-2010 15:24 |
