Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 08-28-2006, 16:41   #1 (permalink)
adampurhawks's Avatar
Member: 258154
Get All Your Problems Solved in 12 hours....
Hai Mates,
I m gonna start a new thread ..you can post ur all problem like Hardware and Softwares (6600,7610.6630 Specially) etc.. and all the softwares related to S60..Lets make this thread help other members also..
Regards..
Adampur Hawks..
The Following 88 Users Say Thank You to adampurhawks For This Useful Post:
-=MR_Gsm=-, .::ADNAN440::., 7459124, abizar111, alzir512, amancommunicati, amiparmo, angelcomunition, aralip09, Ashley 28, aurobinda8, badgerjum, behzad786, ben ali khaled, bengamra, benjie08, boss_yuki, broken_rules, chadrich27, chinni143, damha2nd, daryl_rasta, defrianto, devolpers, dharmesh1510, dibyendu, djamel1986, don_joel, edwin08, ejaz_2008, exmobile, fabicel, gats71, gunjan singh, guru99146, gurvinder_ynr, hajji1, imran32203, imrannzb, irfaan khan, jackbloomberg, jatin_lucky, jawad munir, ktrauoof, kyleann, layek, m rizwan sh, MASHOODH, max0066, mewat, mj25011, moon4gsm, msalla, Mujaffar, nael_mansoor, nazeem, nitin.gulati64, niyasniya, noor_gsm, ozonecare, parmo-ami, PETER7661, pishtaz, polanco, pramodviswam, Pratheesh T K, prem_airtelsp, rabcr18, rajib_at, raltelefonica, rashel.com, ref786, Rizwan ch08, rYo_x_treme, sabrin, sam22001, sandeep_1304, saturni, shahadat29, shivamobiles, shoeb7, tamilvel, thagro, tipu_ms, VELLAIKANNAN, waheed1234, watari31, zahidbutt
Old 08-28-2006, 23:34   #2 (permalink)
Member: 339692
I am new here. Nice place to discuss, lots of help for juniors
The Following 11 Users Say Thank You to gsmasters For This Useful Post:
Old 08-29-2006, 03:35   #3 (permalink)
Member: 234185
Nokia 7610 No Display..
Hi Guys, Regards. Hope U Can Help Me.. My 7610 No Images Or Words Can Be Seen But Only Hv Backlight On, And Still Can Receive Calls But Nothing On The Screen. Pls Help Me.
The Following 9 Users Say Thank You to boy_may22 For This Useful Post:
Old 08-29-2006, 05:29   #4 (permalink)
Member: 258154
Hi Mate
Steps for 7610 White Display
1) First of All Check ur display
2) Check the Display Connectors on PCB,Bat be Shorting or damaged.
3) Reheat display IC
4) Full format your phone with JAF or with UFS
5) Reflash with higher version...
Regards.
Adampur Hawks..
The Following 14 Users Say Thank You to adampurhawks For This Useful Post:
Old 08-29-2006, 05:40   #5 (permalink)
Member: 212944
hello! 7610 problem...
phone startup failed!
reballing of flashes gave no result also erasing and flashing with formatting.
problem in RAM?
The Following 7 Users Say Thank You to vitpod For This Useful Post:
Old 08-29-2006, 05:45   #6 (permalink)
Member: 322577
hi ENGR. on line i say good morning as it here now in nigeria
The Following 3 Users Say Thank You to obytech For This Useful Post:
Old 08-29-2006, 05:47   #7 (permalink)
Member: 322577
Engr. ADAMPURHAWRKS RESPOND TO ME
Old 08-29-2006, 05:56   #8 (permalink)
Member: 218345
nokia 6020
i have nokia 6020 inserts sim i have change the ic but still it is not working so plz give me solution
The Following 7 Users Say Thank You to pradeep agrawal For This Useful Post:
Old 08-29-2006, 09:58   #9 (permalink)
Member: 263378
7610 dead set.
Flash with tornado give result like this:
1st Boot Ok, WD2, UPP: 1081
Fl0: 0x00000000-0x00FFFFFF,00EC22F8,Sam K8S2815ETA
Fl1: 0x02000000-0x02FFFFFF,00EC22F8,Sam K8S2815ETA
Fl2: 0x04000000-0x047FFFFF,00EC22FA,Sam K8S6415ETA
Algorithm: w3_amd_b.fia, Ver: 4.52.0
Alg Boot Error: 2
Error Data1:
00000000: 9F 04 04 00 EC 00 F8 22 00 00 11 00 10 00 02 EC ......."........
00000010: 00 F8 22 00 00 11 00 10 00 04 EC 00 FA 22 00 00 ..".........."..
00000020: 11 00 10 00 06 00 00 01 00 00 00 00 00 00 00 FF ................
00000030: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 83 ................
Error Data2:
00000000: F3 72 00 F8 22 00 00 11 00 10 00 02 EC 00 F8 22 .r..".........."
00000010: 00 00 11 00 10 00 04 EC 00 FA 22 00 00 11 00 10 ..........".....
00000020: 00 06 00 00 01 00 00 00 00 00 00 00 FF FF FF FF ................
00000030: FF FF FF FF FF FF FF FF FF FF FF FF 83 D3 72 00 ..............r.
Before taking screenshot, expand this window !
Process Failed, Repowering Mobile
Can you give idea which part give error like this?
The Following 6 Users Say Thank You to HPDebug For This Useful Post:
Old 08-29-2006, 12:00   #10 (permalink)
Member: 313478
6600 camera
hi
i am having 6600 it has problem of camer when i cilk camera it take photo but after that display show temporary overload continue plz tell how to solve this problem
The Following 5 Users Say Thank You to jaynshah For This Useful Post:
Old 08-30-2006, 14:37   #11 (permalink)
Member: 258154
Originally Posted by jaynshah View Post
hi
Hey Mate, follow following steps :
1) Try to format your phone manualy with * + 3 + Green + Power on
2) If not Ok..Format User Area with UFS of with JAf
3) If still not OK Flash your phone with higher version ..
Regards
Adampur Hawks
The Following 6 Users Say Thank You to adampurhawks For This Useful Post:
Old 08-30-2006, 14:43   #12 (permalink)
Member: 258154
[quote=pradeep agrawal;1954878]hi plz give me solution for sumsung v 200 no network found[/quot]
Hi Mate..
First of all Reset your phone with
1)*2767*2875# or with *2767*3855#
2) If not Ok Full Flash your phone...
Evrythng wll b ok
Regards
Adampur Hawks
Old 08-30-2006, 17:27   #13 (permalink)
Satyam321's Avatar
Member: 269198
6600 cam
temporarilly overload galery not open and bluthooth not work
flash is not the solution
must be heat with hot gun the BT module
if not ok so change it
be carefull
The Following 5 Users Say Thank You to Satyam321 For This Useful Post:
Old 08-30-2006, 17:30   #14 (permalink)
Satyam321's Avatar
Member: 269198
heat with hot gun BT mobule then try
The Following 4 Users Say Thank You to Satyam321 For This Useful Post:
Old 08-31-2006, 00:20   #15 (permalink)
Member: 263378
My problem not solved after 12 hours
Thanks.
BR.
The Following 2 Users Say Thank You to HPDebug For This Useful Post:
any mobile or computer problem solve in 24 hours free . sindhi kanu Nokia Base Band 5 ( BB-5 ) 11 12-01-2010 15:50
Solve your problem whit in 24 hour kashantariq2002 Nokia Hardware & Hardware-Repair Area 16 12-01-2010 14:24
Page generated in 0.47336 seconds with 12 queries
