Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
08-31-2006, 01:26 | #16 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Kathmandu, Nepal
Member: 260236 Status: Offline Sonork: 100.1641081 Thanks Meter: 135 | May your phone has damaged "RAM". Try replacing it! |
The Following User Says Thank You to ace_venturia For This Useful Post: |
08-31-2006, 07:02 | #18 (permalink) |
Registered User Join Date: Sep 2003 Location: Palestine Age: 50
Member: 39208 Status: Offline Thanks Meter: 152 | 6230 with camera problem, the camera has no preview , when i take a shot, it save it normally, also the video preview is very very slow, i full erase the phone, flash it, full factory setting, write pm, all sw procedures but no help, i also change the screen, change the camera, still the same ... pls help |
08-31-2006, 08:01 | #21 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 248245 Status: Offline Thanks Meter: 85 | Thanks for your new thread i m getting a problem with Nokia 6170 in which when call attended only loudspeaker work not speaker work i change four speaker after changing speaker it work some time and then voice is very slow please give here any solution. |
08-31-2006, 09:18 | #22 (permalink) | |
Freak Poster Join Date: Apr 2006 Location: amsterdam , netherlands Age: 42
Member: 268495 Status: Offline Thanks Meter: 27 | Quote:
try to resolder or heat the headset ic ...... good luck....... | |
08-31-2006, 13:04 | #24 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Kuwait Age: 44
Member: 250607 Status: Offline Thanks Meter: 42 | N 70 Water Damage Hiiiii, I hv Nokia N70 ..Its water damage ...i cleaned the board ...its working now but its getting hot ....& no bettary Backup ....Pls send me the solution |
The Following 2 Users Say Thank You to monto For This Useful Post: |
08-31-2006, 18:40 | #26 (permalink) |
Junior Member Join Date: Aug 2006
Member: 341454 Status: Offline Thanks Meter: 0 | can u tell how can v install or format our phone and install SymbianOS in to our nokia mobile phones?? and wat is this JAF and UFS and wat is meant by "Flash with higher version"???? plzz reply me |
08-31-2006, 19:13 | #27 (permalink) |
Freak Poster Join Date: Nov 2004
Member: 94806 Status: Offline Thanks Meter: 19 | i have here 3650, init normal mode ok. no power on battery. am using twister and jaf. i'dd also check board for missing parts . does anyone encountered the same problem and has a solution. |
09-01-2006, 06:05 | #29 (permalink) |
Junior Member Join Date: Nov 2005
Member: 203363 Status: Offline Thanks Meter: 1 | i have N70 and if i chose the edit image it says "Not enough memory to perform operation. Delete some data first." I have a 256Mb dv rs mmc and a newly updated firmware to 5.0616.2.0.3 24-4-06 RM-84. pls help me |
09-01-2006, 06:24 | #30 (permalink) |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | 3220 , was signal problem. i rehot all board components , signal back for few days , phone back with no signal , i rehot board again , phone is not power on . flashed with newest flash np , phone power on with jaf , but not with battery. power switch is good . ideas ? 3220 power ways ? |
any mobile or computer problem solve in 24 hours free . | sindhi kanu | Nokia Base Band 5 ( BB-5 ) | 11 | 12-01-2010 16:50 |
Solve your problem whit in 24 hour | kashantariq2002 | Nokia Hardware & Hardware Repair | 16 | 12-01-2010 15:24 |
