Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
09-01-2006, 06:59 | #31 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Calicut Kerala India Age: 46
Member: 74036 Status: Offline Sonork: 100.1601291 Thanks Meter: 42 | 9300 |
09-01-2006, 13:15 | #32 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Inside PM
Member: 258154 Status: Offline Thanks Meter: 319 | Hi MatesU can easily install symbian application by simply sending it via bluetooth and after that u can install it..Mean while i think u are a new baby to this website and don know abt mobile repair and mobile flashing ..JAF and UFS are the boxes mainly used for unlocking and flashing for Nokia and Higher version means to Flash ur phone with latest files of that Model...Any way try to read more abt all this in this forum...RegardsAdampur Hawks. |
09-01-2006, 13:18 | #33 (permalink) | |
Member: 258154 Status: Offline Thanks Meter: 319 | Quote:
Try to format it with *#7370# or may be with * + 3 + green + Power On and it will manualy format ur phone...this will solve ur problem Regards Adampur Hawks | |
The Following User Says Thank You to adampurhawks For This Useful Post: |
09-02-2006, 06:52 | #37 (permalink) |
Freak Poster Join Date: Feb 2003 Location: Ottawa Age: 44
Member: 21152 Status: Offline Thanks Meter: 2 | Nokia 6620 No light on Screen I took apart my 6620 to see if I could find anything wrong with the atenna as it was giving me a hard time with call's. droping them all them time. I cleaned it up a bit and such and put all back toghter and it works fine now but the lcd screens lights will not come on. The keypad lights come on but I can't figure out why the screen's won't.I even reopned it to see if anything was loose or anything like this. I have take apart series 60 phones before and older phones and this the first I've had a problem due to the direct result of me opening it. Any suggestions ? |
09-02-2006, 12:42 | #38 (permalink) | |
follow following steps 1) Desolder both Volume switched in left sides of PCB..if not ok then 2) Reheat the Keypad IC if not replace it.. 1st step is very best i repaired 23 sets with this ...1000% working Try and post me Regards Adampur Hawks | |
09-03-2006, 12:36 | #39 (permalink) |
Junior Member Join Date: Jul 2006 Location: Indonesia
Member: 320675 Status: Offline Thanks Meter: 1 | can you hlp me with 8250 thanks for your guide in 5100. now, could you help me with this one. i've nok 8250. when i turn it on the signal indicator was show and then drop (no signal). i.ve changed with new PA but the problem still occur. could you help me ? plz |
The Following User Says Thank You to ceo_phill For This Useful Post: |
09-03-2006, 12:50 | #40 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: eproom memory Age: 41
Member: 264366 Status: Offline Thanks Meter: 29 | Quote:
hi ... i have one 6680 that hang when using bluetooth so i flashed with HWK ... But i get this error now 6680 is dead and i will also dead tomorrow when i'll tell my customer that i killed his mobile 1st BOOT : C0,0C HELEN ID : 17100701 HELEN MODE: 00 HELEN PBID: 6C141A43DE2DF195BB7715F0173E70220D0FBD3C HELEN HASH: 2C05369F57CC3C4CF9E783E83D9B512B HELEN ROID: AB5E4ADB27A06946 RAP3 ID : 000000010000022600010006000C192101002200 EM 1 ID : 00000232 EM 2 ID : 00000352 RAP3 PBID : 14000102737E4E51292B80DE4D61024FB6DA463B RAP3 MODE : 00 RAP3 HASH : E9EFF4BFAA5393217CA6B17755FC3E1401000000 RAP3 ROID : F28A211FCEA7B19D CMT 1st Boot Ok CMT 2nd Bt: RAP3Gv2_2nd.fg, Ver: 1.9.2 CMT FLID : 002088C0-00000221, St M28W640 CMT FLCNT : 000080008000800080008000800080008000 CMT 2nd Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 1.9.3 CMT Alg Boot OK Erase Area: CMT 0x00000000-00509BFD Erase Area: CMT 0x006DF000-006EFFFF Erase Area: CMT 0x00700000-007EFFFF Process Failed, Repowering Mobile | |
The Following User Says Thank You to johnreza For This Useful Post: |
09-04-2006, 08:08 | #41 (permalink) | |
Dont worry abt the dead phone just flash ur phone by selecting step by step procedure write all the flash files by step by step.. and before flashing just lightly rehot the flash IC's and then flash ur phone it will be ok tested by me on 5 sets Regards Adampur Hawks | |
09-04-2006, 08:12 | #42 (permalink) | |
first tell me if ur 5100 is ok or not..if yes then plz tell me...so that i can response u better next time..and for now The problem is in Antenna Switch,and may be in filters.. Just Change them it will be ok.. Regards Adampur Hawks | |
09-04-2006, 11:03 | #43 (permalink) |
Member: 311959 Status: Offline Thanks Meter: 1 | My 6600 1st boot ok but dead. please help My 6600 1st boot ok but dead. when am trying to flash it with ufs it shows like this. 1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x007FFFFF,002088C0,St M28W640 Fl1: 0x02000000-0x027FFFFF,002088C0,St M28W640 Fl2: 0x04000000-0x047FFFFF,002088C0,St M28W640 Fl3: 0x06000000-0x067FFFFF,002088C0,St M28W640 Algorithm: w3_st_i.fia, w3_cbusb.fia Algorithm Ok, MSID: 84A22FF3727DE6F84E03609CAF Decoded MSID: 3E4EBAF7-0042A943-A9000000 Encoded FAID: 0159EE1A-DEC1B643-9986C62B Cbus Boot Error: 9 Error Data1: 00000000: 00 96 84 A2 2F F3 72 7D E6 F8 4E 03 60 9C AF EE ..../.r}..N.`... 00000010: 00 C0 88 00 00 21 01 10 00 04 20 00 C0 88 00 00 .....!.... ..... 00000020: 21 01 10 00 06 20 00 C0 88 00 00 21 01 10 00 C6 !.... .....!.... 00000030: 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA AA ...u...x...{.... Error Data2: 00000000: A3 72 72 C0 88 00 00 21 01 10 00 02 20 00 C0 88 .rr....!.... ... 00000010: 00 00 21 01 10 00 04 20 00 C0 88 00 00 21 01 10 ..!.... .....!.. 00000020: 00 06 20 00 C0 88 00 00 21 01 10 00 C6 00 00 EA .. .....!....... 00000030: 75 01 00 EA 78 01 00 EA 7B 01 00 EA AA C3 72 00 u...x...{.....r. Before taking screenshot, expand this window ! Process Failed, Repowering Mobile i checked battery connector is ok. The problem occured very strangely. phone was ok but i inserted another lcd in this board to check that lcd is ok or not. but when rollback to old lcd, phone doesn't power on. Pls help me. |
The Following User Says Thank You to digital_mind For This Useful Post: |
09-04-2006, 12:16 | #44 (permalink) | |
Freak Poster Join Date: Apr 2006 Location: amsterdam , netherlands Age: 42
Member: 268495 Status: Offline Thanks Meter: 27 | Quote:
09-04-2006, 12:19 | #45 (permalink) | |
Try and if still not working do write me. Regards Adampur Hawks | |
any mobile or computer problem solve in 24 hours free . | sindhi kanu | Nokia Base Band 5 ( BB-5 ) | 11 | 12-01-2010 16:50 |
Solve your problem whit in 24 hour | kashantariq2002 | Nokia Hardware & Hardware Repair | 16 | 12-01-2010 15:24 |
