Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Hardware & Hardware Repair > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 09-04-2006, 15:02   #46 (permalink)
Member: 257507
bt is dameged disable " inable BT Flshing " at left top side of ur ufs or jaf and flsh it
it will be ok but BT & gallery not work
Old 09-04-2006, 18:50   #47 (permalink)
johnreza's Avatar
Member: 264366
Thanks Meter: 29
Originally Posted by adampurhawks View Post
Hi Mate
Dont worry abt the dead phone
just flash ur phone by selecting step by step procedure
write all the flash files by step by step..
and before flashing just lightly rehot the flash IC's and then flash ur phone
it will be ok tested by me on 5 sets
Regards
Adampur Hawks
I tried but always same brother ...
Another idea PLEASE ...
Old 09-05-2006, 04:26   #48 (permalink)
Digiview's Avatar
Member: 40975
Thanks Meter: 62
6600 power switch path totalll dameged .how can i give a alternative path.
plz friends so so urgent
Old 09-05-2006, 06:02   #49 (permalink)
adampurhawks's Avatar
Member: 258154
Thanks Meter: 319
hi Mate
Use Search to get 6600 on/off ways...good luck
Adampur Hawks
Old 09-05-2006, 06:14   #50 (permalink)
Member: 197333
Exclamation Help Needed
Hai Mates,
I m gonna start a new thread ..you can post ur all problem like Hardware and Softwares (6600,7610.6630 Specially) etc.. and all the softwares related to S60..Lets make this thread help other members also..
Regards..
Adampur Hawks..
what is the best way to format my N-Gage (phone memory) ?
please provide a solution
Old 09-05-2006, 07:04   #51 (permalink)
Member: 248245
Thanks Meter: 85
Originally Posted by swapnilbombay View Post
try to resolder or heat the headset ic ...... good luck.......
problem solved i just resold and clean its strip set working ok.
Old 09-05-2006, 09:39   #52 (permalink)
Member: 258154
Thanks Meter: 319
Hi
Just Use *#7370# or * + 3 + green button + power on
perfect formatting way
good luck
Adampur Hawks
The Following 2 Users Say Thank You to adampurhawks For This Useful Post:
Old 09-05-2006, 12:14   #53 (permalink)
john_john's Avatar
Member: 310833
Thanks Meter: 10
bro...ihave 6630 after charge battery full then hung up(freezed)the fon
help bro....
The Following User Says Thank You to john_john For This Useful Post:
Old 09-05-2006, 15:43   #54 (permalink)
Member: 4600
Thanks Meter: 79
6020 not charging
6020 water damaged. not charging when connect charger.
The Following User Says Thank You to GSM RAJ For This Useful Post:
Old 09-05-2006, 17:15   #55 (permalink)
Member: 69113
Thanks Meter: 5
nokia 6030. I cant enter in radio menu, flash with new werion sw, and the same, when i run solf tests in JAF show st radio test fail. Any idea?
Old 09-05-2006, 22:22   #56 (permalink)
moienshah's Avatar
Member: 258749
Thanks Meter: 10
Hi
good luck
Adampur Hawks
Nice work man thanx for this
Old 09-06-2006, 05:41   #57 (permalink)
Member: 218345
Thanks Meter: 37
samsung D415
sir plz help me how can use in india T-MOBILE samsung 415 imei no 010306001512846
Old 09-06-2006, 05:48   #58 (permalink)
Lhick's Avatar
Member: 333359
Thanks Meter: 91
Good solution ,format phone
Old 09-06-2006, 07:01   #59 (permalink)
Member: 258154
Thanks Meter: 319
help bro....
Hi
Just format ur phone by Using *#7370# or * + 3 + green button + power on 100 % working solution
good luck
Adampur Hawks
The Following User Says Thank You to adampurhawks For This Useful Post:
Old 09-06-2006, 19:31   #60 (permalink)
Member: 300985
i have 3200 insert simcard and 1600 insert simcard please can any body halp with picture please i need it augently please
any mobile or computer problem solve in 24 hours free . sindhi kanu Nokia Base Band 5 ( BB-5 ) 11 12-01-2010 16:50
Solve your problem whit in 24 hour kashantariq2002 Nokia Hardware & Hardware Repair 16 12-01-2010 15:24
Page generated in 0.25130 seconds with 10 queries
