Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 11-10-2004, 09:25   #1 (permalink)
GSM Coolhawk's Avatar
Member: 7751
Hardware Repair Series : 7210-6610 no power on after flash
Please see following picture for solution to DCT4 7210 and 6610 no power on after flashing, with no appearent damages to the board, or light waterdamage.
All credits and thanks for this goes to StuioGSM for posting the picture
Please note that original bmp file of 855 kb was resampled to jpg 51 kb !
Regards
The Following 3 Users Say Thank You to GSM Coolhawk For This Useful Post:
Old 11-10-2004, 09:30   #2 (permalink)
Moderator
yousha's Avatar
Member: 17689
Sonork: 100.72392
yes we know it its a track b/w flash and ram if the phone does`nt power on even after this track than replace RAM
anyways thanx GSMCOOLHAWK
Edit by GSM Coolhawk**The thanks goes to StudioGSM for posting picture**
Old 11-10-2004, 23:19   #3 (permalink)
Azampk's Avatar
Member: 30303
Sonork: 1001579198
ya it's work for me in water damage set 6610
but still no network pls help me i reflashed but nothing and no lights
Edit By GSM Coolhawk
@azampk
Please take care. Stay within topic, this is for no power on when phone can be flashed. Make a new thread or search the bord, there's litterally over 40 posts containing your question regarding signal.
Old 11-11-2004, 20:42   #4 (permalink)
StudioGSM's Avatar
Member: 15122
Originally Posted by akshay
this is really great . working solution, thanx to StudioGSM
thanx again
@kki
OK. No problem friends. It's good to see some good words for me. Next solutions will be ready soon.
StudioGSM.pl
Old 11-12-2004, 07:35   #5 (permalink)
baraka42's Avatar
Member: 14578
this solution can work with 3100, same problem ?
w.b.r.
Old 11-12-2004, 07:50   #6 (permalink)
Moderator
yousha's Avatar
Member: 17689
Sonork: 100.72392
w.b.r.
no my frnd the platform is totally differs
Old 11-12-2004, 08:16   #7 (permalink)
baraka42's Avatar
Member: 14578
yes yousa,
u right, i hadn't refer 3100 sche. there is combo memory.
in 6610 c451-c452 is memory coupling capacitor for ram.
w.b.r.
Old 11-16-2004, 09:48   #8 (permalink)
Member: 7586
this solution is not working for me :
when i connect this 2 capacitors then i cant flash my phone .
see here :
9B0201008C2290000000800200000000...
Failed to find FIA file in 'C:\Program Files\Nokia\Phoenix\flash\
In 994314770f the cases this is caused by corrupt FLASH folder.
Fully DELETE the contents of the Flash folder,
and then Install the latest FIA package!
Error[78878778]
bad ID of Flash ic .
without this bridge i can flash my phone but dont power on after flashing .
see here :
Initializing Phone...
Flash configuration:
9B020100EC22F2000000E00200000000...
Boot and Flash loaders operation took 5.128000 seconds
Erasing ....
etc..
there is different FLASH ID .
any idea ?
Pali
Old 11-16-2004, 15:04   #9 (permalink)
Member: 18057
then try to make jumper btw capecitors . or try to on phone. if not then rehot ram
or change ram, or sometimes uem also reason for this type of falult.
@kki
Old 11-17-2004, 17:08   #10 (permalink)
Member: 7586
@akshay
well
Ram is changed , all BGA reballed , board doesnt seems to be damaged.
if i connect this 2 Capacitors then i have error .
If i dont connect i can flash my phone , flash id is correct.
any idea?
what about other Capacitors near RAM and FLASH IC ?
Pali
Old 11-23-2004, 08:05   #11 (permalink)
NELU-GSM's Avatar
Member: 9411
7210
I MAKE CONNECTION LIKE IN PICTURE,PHONE POWER ON 3-4 TIMES AND NOW ONLY WHEN I MAKE WITH TORNADO REBOOT IN NORMAL MODE PHONE IS POWER ON .WHAT IS THE PROBLEM?
Old 11-26-2004, 01:07   #12 (permalink)
needi's Avatar
Member: 18303
Bad Ram...try with new RAM.
Old 11-26-2004, 07:03   #13 (permalink)
baraka42's Avatar
Member: 14578
thanks m8,
with your solution i can power on 6610, with c.s. imei is ?????????????
phone can power on with twister normal mode for few second.
need more help.
thanks again.
w.b.r.
The Following User Says Thank You to baraka42 For This Useful Post:
Old 12-01-2004, 22:02   #14 (permalink)
badi's Avatar
Member: 11945
yes m8 this is the right solution to fix this prob
Old 12-12-2004, 18:27   #15 (permalink)
mrfixit's Avatar
Member: 60899
this extra wire connection worked for me too
6600 no power on after flash help!!!!!!!!! hansis UFS2 + UFS3-Tornadoflasher 33 04-06-2005 23:39
8130 ... No Power on after Flash jokkergsm LG 1 03-10-2005 15:03
help 6100 no power on after flash Nokall Nokia Hardware & Hardware-Repair Area 9 12-23-2004 05:16
R520m no power ON after flash pepik Old Ericsson Phones & Sony Phones 0 08-26-2004 21:38
Page generated in 0.60173 seconds with 12 queries
