Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 07-23-2004, 02:02   #1 (permalink)
GSM Coolhawk's Avatar
Member: 7751
Hardware Repair Series : 7650 Flex Fix with pictures and explanation in details
@All
One more for today.
havent you all been pissed off when a 7650 flex cable have been ripped, either by the client, or even worse, by yourself, done that a few times myself duhh
Those flexies are still quite exspensive, and it take some time to fit a new new, but what if you dont have a new one ? Then your busted, and clients start screaming hehe (C) Crew
Well I did that some time ago with a clients phone upss, and did not have any flex cables in stock at the time, and wouldn't have for a few weeks to come. soooo lets get started.
Tools needed for this fix :
1 : A good stereo microscope or lupe, min 20x, I prefer to do this fix in 40x magnification !
2 : 30-50 W SMD soldering iron
3 : Cobber wire 0.2 mm
4 : Good flux, I recommend ERSA - FMKANC32-005 non-clean cream.
5 : Soldering tin 1.5 - 2 mm with core flux
6 : Doctors scalpel
7 : Some very steady hands
Note that this fix can ONLY be done if the flex cable have been ripped just above the pads on the PCB, if it's ripped other places, this fix does not apply.
First you'll have to cut the flex just where the rip has occured and make a nice strait cut all the way. Find your scalpel. In order to have the flex steady, I always put it back on the PCB and line it up with the pads.
What you do now is to start scraping of the plastic of the flex very very carefull, the lines are VERY fragile, one mistake and you can throw that flex away for good. As soon as you reach the thin cobber line under the plastic, take it even more slowly, you have to clear at least 2-3 mm of the line. When you after some nervous time have done this to the hole flex, it's time to prep it.
Apply flux on all the lines which are now in the free, and after prep them with some good solder. After this you can start to mount the wires. You need something like 3 mm on the flex and 3 mm on the pad. What I do normally in this kind of operation is to have a long cobber wire at hand, start to solder it to the flex first, then the pads, then you cut it, it's nearly impossible to control a 6 mm long patchwire trust me.
Under here you'll see the finished result of a ripped flex, which I've fixed by the above method, you should have an idea now what this takes.
Under here is a close up in 60x magnification.
Hope this helps out some folks. Good luck, and dont blame me for busted boards, do this at you own risk !
And please, do not start any "send me too" posts of any kind, they will be deleted. I do not have it whatever it might be. For your information I use a Novex AP-8 stereo microscope, and pictures posted here is taken with a QX3 Intel (tm) digital toy microscope, you can find those nice little ones on Ebay for around 60 Euro.
Regards
The Following User Says Thank You to GSM Coolhawk For This Useful Post:
Old 07-23-2004, 10:37   #2 (permalink)
teerak2uk's Avatar
Member: 24791
just look on eBay much easier and less hassle
Old 07-23-2004, 13:43   #3 (permalink)
Member: 7751
@teerak2uk
Yeah Nice China copies, where around 10% is faulty . And furthermore this fix was in emergency, in case you did not have any flexies in stock. Not everybody with this problem lives in UK with free postage, not to mention eventual WU transfer + postage outside UK + waiting time.
Regards
Old 07-31-2004, 23:58   #4 (permalink)
dydycom's Avatar
Member: 19875
oy oy oy
HE IS A british guy WHAT DO U KNOW??
I MUST SAY THAT I TRIED SEVERAL TIMES THAT PROBLEM BUT..... LOST MY PATIENCE.
TO POST HERE, MEANS ALLOT, THATS TO BE APRECIATE!!
GOOD JOB MATE!!!
Old 08-12-2004, 16:07   #5 (permalink)
Member: 1970
WOW man.. I have to say you have the nervous..
uniden
slovenia
Old 08-26-2004, 19:35   #6 (permalink)
Member: 17108
*** job man i dont have patience to do
Old 09-12-2004, 16:49   #7 (permalink)
dexter2's Avatar
Member: 38959
hi, this is new guy try 2 come out well just the ways u all are coming. i love u all for making d world sweet place for all thanks for all your doing gbenga
Old 09-22-2004, 12:49   #8 (permalink)
Member: 82426
good jog man.
can i go to greece and work with you?
very good, u the tecnition.
Old 11-16-2004, 02:40   #9 (permalink)
Member: 3508
This is art!! Man you have the nerves!!
But to make all this I can lost all day, and for 5-6 € I get new flat with connector and fix that for 5 minutes, and the customer pays it!!
Old 01-20-2005, 11:24   #10 (permalink)
Member: 106335
Thanks men it works 100%
Old 04-30-2005, 12:10   #11 (permalink)
iwi
Member: 134084
what a flex! u nid more patience tu do this
Old 05-04-2005, 01:37   #12 (permalink)
Member: 62953
Thanks guys good work well done.
Old 06-27-2005, 18:30   #13 (permalink)
GamalyGsM's Avatar
Member: 154404
Thanks man its great work and work 100%
Old 10-14-2005, 00:53   #14 (permalink)
Member: 143156
Thaaaanx Nice Workkkk
Old 11-12-2005, 09:35   #15 (permalink)
gsm st's Avatar
Member: 143007
hi@all
sir i have a 6230i 2.5.8.0.key not working plz help me thanks
have a nise day
Hardware Repair Series : 7210-6610 no power on after flash GSM Coolhawk Nokia Repair Guide and FAQ 86 06-27-2011 11:52
Hardware Repair Series : T610 not charging with pictures and explanation in details GSM Coolhawk Sony Ericsson Hardware Repair Area 95 09-11-2010 10:18
Hardware Repair Series : 8310 on/off change with pictures and explanation in details GSM Coolhawk Nokia Hardware & Hardware-Repair Area 32 09-27-2005 11:38
Hardware Repair Series: 6310i Buzzer Fix with pictures and explanation in details GSM Coolhawk Nokia Hardware & Hardware-Repair Area 1 12-05-2004 18:39
Page generated in 2.08083 seconds with 11 queries
