HOW TO SOLVE (boot problem )IN NOKIA SYMBAIN PHONES SPECIALLY 6600 1 Attachment(s) HI ALL MATE WE HERE OFFER THE STEP BY STEP HOW TO SOLVE MOST OF BOOTING PROBLEMS IN NOKIA SYMBIAN PHONES (3650,6600,7610 AND 6670 ..ect) THE POST WILL COMPLETE STEP BY STEP BUT I POSTED TO STOP PEOPLE ASK AND ASK AND DO THE WRONG WAY .. CREDIT GO TO WILLY ITS CLOSED POST AND I LL WRITE EXPLAINATIONS IN ALL WHAT IN YOUR MINDS .. WATCH AND STUDY AND OPEN SERVICE MANUALS AND DO HARDWARE REPAIR BY BOOK AND MORE ACCURATE |
Thanks you my dear friend.....but have a problem. I am Using Advance UFS and it not contains Rebuild IMEI option. On this case what should i do..can you personally guide you.. |
Rebuild imie mean : make ask file for old imie and then use griffin server to have the rpl file for you ask so upload the rpl you got to the phone using of option write uem the imie data will been written ti flash chips again .... br., |
hi raheeeeb which devices can i use to find these error codes and the addresses of failing flashes?? bye |
Thank you very much for the chart, but I have 2 6600 with different problems as given below: 1) Switches on with white screen and when flashed, it flashes completely, but format user area, init sim locks and full factory defaults cannot be done. It remains with white screen. 2) Another set switches on then nokia logo appears and set switches off immediately after insert sim appears. What could be the possible solutions for these problems. |
please reffer again tothe sheet and follow the problem in the header till the end include some hints about kind of flashes and its conatian and action required in case of change any flash /.. br., raheeeeb |
THOSE ERROR CODE ,,,,, for most flash device , it show up when "INIT FLASH" mode 9XXXXXXXXXXXXXXXXXXXXXX...... |
1st..if u cant set full factory that mean ur flash already defective..what kind of flash ic in ur set??AMD?if u had the same flash ic wit u set..just replace that bottom one 2nd..if ur set off in 30sec..(when insert sim card appers)ur uem defective ..if.. |
better do dat mannualy using code if not then by computer |
some user data cant be format...even how u format that user area..defective is defective.... anyway i also need some help :D my 6600 phone hang in nokia word wit light i replace 4flash ic,sram ,upp and the problem still same..still hang wit light..at last i took off the bluetooth module...it still same..what should i do huh :confused: aiyo.. |
Yesterday I got a 6600 !!! its corrupted ! I dont know whats the problem ! when powerd on ! phone shows application closed !! and cant open any application ! always shows error ! Phonebook, message, manager, all programes shows error and dose not opens ! I tried Format user area with Griffin, UFS ! and then Formatted phone with * 3 Green button ! but still same contiditon ! I didnt used memory card coz I thought there might b virus in it ! but still phone can not b operated ! no menu is opening ! I didnt Flashed the phone coz It might stop in between and phone may become dead ! any solutions or suggestions ?? |
its BT adapter falls , reflow it or change it and then say thanks to me :) :) :) 1000000% tested BECARFULL UEM at the back side of the BT ok |
its BT adapter falls , reflow it or change it and then say thanks to me 1000000% tested BECARFULL UEM at the back side of the BT ok |
i do agree to mangaman |
