Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
10-15-2005, 02:53 | #20 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Philippines Age: 45
Member: 184011 Status: Offline Thanks Meter: 4 | i have a problem about my 6600 always aplication close or reboot itself since i change lcd i try to flash it many times but nothing works, what should i do |
10-15-2005, 17:47 | #21 (permalink) | |
No Life Poster Join Date: May 2005 Location: GULMI Age: 49
Member: 143007 Status: Offline Thanks Meter: 141 | Quote:
you cheng rx filter end write full flash Rh12 mcu ppm cnt end write pm file unlock full ui default end full factory default my be 99% work | |
10-18-2005, 11:19 | #22 (permalink) | |
Registered User Join Date: Feb 2004 Location: MERSIN, TURKEY
Member: 55026 Status: Offline Thanks Meter: 53 | Quote:
For Example there was a specific one more problem, the phone can not enter galery, the problem accured from bluetooth! thanks for evrybody who searched and shared infos! I hope for these two problem we will find solution and share! regards! | |
10-18-2005, 11:30 | #23 (permalink) |
Junior Member Join Date: Feb 2005 Location: Dubai Age: 42
Member: 116892 Status: Offline Thanks Meter: 0 | 6600 boot problem 1- ist mobile u hav to flash mobile along wit pm file after that format user area 3-times... then it will be working.. if still white screen comming then erase the full flash by using ufs-3 after earse flash mobile with virgin pm .... its 100% working........... 2- 2nd mobile u hav to just format user area 3 times it will be 100% working. |
10-21-2005, 10:51 | #24 (permalink) |
Member: 55026 Status: Offline Thanks Meter: 53 | shezzy! You are not so clever I think! Why everybody spend their time for stupid infos! Do you believe if the phone could work and I would not do the things you mantioned! man the phone is not a bootable phone! and is not in LOCALE MODE, so how do you think format user area or e.t.c if phone can not enter in LOCAL MODE!? anyway Regards! |
10-21-2005, 17:16 | #25 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | @kubat1 please ppl want to help all in his own experince no need to use bad word at all by the way if you want more explaintion contact me and after you ll post the solution by yourself thanks br., |
10-21-2005, 18:44 | #26 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Quote:
what good thing you know and you can share it out ? if your phone can not into local mode, then you have to "SEARCH" more info how to do it ... not like some boy , just only know ask MILK with cry ! please do not show how poor you are! Willy | |
10-26-2005, 17:02 | #27 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Planet EARTH Age: 50
Member: 3194 Status: Offline Thanks Meter: 41 | HELP for 6600 blank white, keypad light also , but about 30 second turn off. 4 flash ics has been replace, i have had this problem before, replacing flashes, ram, uem, upp, and bt NOT HELP. so... i have to becarefull now in changing spare part (its expensive ..!!) nee your help my friend |
10-27-2005, 06:02 | #28 (permalink) |
Member: 1060 Status: Offline Thanks Meter: 10 | for me, first, i will "verify" core SW which i flash into phone ( some RD SW can do it easy) ! changed parts,,,,it not mean all parts you installed was "OK",, it might not work ,just eason becasue @#$%$#@#$%$#@.......... only one thing you can sure is the measurment result ! try to check all "CBUS" link .like 1Mhz clk .... try verify the "security data" in eeprom is correct , or you got good and new UEM , then check the "watch stupid dog" ! then next is go to check LCD connector ! others much easyway==> PHOE.N.I.X==>self text Willy |
10-27-2005, 12:20 | #30 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2005 Location: U S A / GOA /CHINA Age: 44
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | it was mind ****ing thnks to raheeb and willy what fantastic job sir but can u explain by jpg about uem and upp each ball contain what activity ther 14*14 ball starts A1toN14 pls thnks |
How to solve the problem in Kentucky, we service 5130 | shirzad3423 | Nokia Base Band 5 ( BB-5 ) | 2 | 02-14-2010 14:32 |
how to solve this problem in Mt-Box??? | svchost | MT-BOX | 6 | 03-24-2009 21:53 |
How to solve blinking problem of nokia 7500 with UB? help | alexvideogames | Universalbox | 1 | 10-30-2008 09:42 |
How to solve boot problem ? | pavankhatri4024 | Chinese Models & Cloned Phones | 4 | 09-21-2008 13:58 |
how to solve "no network in nokia 1110i" | gsmfield | Nokia Hardware & Hardware Repair | 21 | 04-15-2008 05:36 |
