Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 07-05-2004, 10:12   #1 (permalink)
keany's Avatar
Member: 67419
For new beginners. Nokia NO signal solutions
nokia has 2 dirctories of signal
1-TX(that mean trasmiter)
2-RX(that mean receiver)
3-when i understand that is rx and tx problem???
3/1The most problems of TX are(when you power on the
phone, signal is well but..before the light is off,
signal shut down
3/2 The most problems of RX are (when you switch on
the phone and you have not signal
I DONT KNOW IF YOU UNDERSTAND THE DIFERENCE OF 2 CAUSES?
ANYWAY THESE ARE IN GENERAL
4- Whitch parts of nokia are RX and TX?
4/1- PA (power amplificator)is only TX(trasmiter)
4/2- DUBLEXER is RX and TX too
PA AND DUBLEXER EXEPT THE SIGNAL THEY CAUSE MOST OF
PROBLEMS WHEN NOKIA SHUT DAWN WHEN MAKE A CALL
4/3 HAGAR -is RX and have a little part of TX but 80%
of received signal is hagar
4/4 COBBA is TX and a little RX
but cobba cause most of contact service in nokia
and when you listen bad in earphone
4/5 32.768 KHZ REAL TIME CLOCK cause too much problems
of signal and when the phone shut dawn inormaly
you must listen the ring of the phone if it is
too slowly 32.768khz must be change
4/6 CCONTI TRASMIT ELECTRICITY ALL NOKIA PARTS
most of problems when the phone not swhitch on
the problem is cconti
4/7 FLASH IC cause most of contact service in nokia
and signal ( when you switch on the phone and you
have not signal but only the name operator example
( like only vodafone but nothink signal) is a flash
problem
OK MAN I WISH U UNDERSTAND ME
PLEASE RATE THESE THREAD (BECAUSE ALL CAN SEE IT)
BG KEANY
The Following 189 Users Say Thank You to keany For This Useful Post:
2gang, 6ayatri, Aaman Ali, abad_an, abdo unlocker, adnan sarwar, ADNAN_G, adryanbiru, afterdark, ahmedraj, ajeetjoy, ajit jain, ALIEVE, aloknair, amadjo01, amdraffic, amirgsmbejaia, amitagarwal1980, amitbhanushali, ashwani gupta, asrinu, bboynam99, bertskie, bhawarlal, bijimonalpy, bir_mag18, bluecobba, bluekutu, bobbby, broken_rules, bubluji, cellrichz, chisti, chitaranjan, contact_ihsan, cpbeginner, crooghoo, cyi, danidj, david_h4ck_u, DEBABAABAN@GMAI, dhillon, dhinesh123, dn.maury, don osita, donkank, DR MKOU, dreameye, dunken, DUWA786, d_installer99, eaglesdikhan2, ebsmac, Emotional_raja, erazor047, erixxx84, eusolz, exequel, faizal-dio, fcell, flavioro, flirt, frankesambur, FreeLock, Freshbol, GEEBOO, gilean, gill666, gm.mobiles, gnmughal_786, gsm_3gn, guicholili, happylogos, hemant11, hitek_2009, hussnan_stylo, ianlay tech, ihsangmw, imran162, imranfath, inamullah, ismail21sa, jammaj, jason81, jayanth.b, jethro09, jignesh14452, jjosjoshuaoshua, JOSEVARGHESE, jplakans, jugno007, Jun Celso, kailashkumar, kashantariq2002, kaylee_santos, keshavulu, killcrc, kirkenkish, kojobruce-gsm, laredo_r, lhakkaoui, ljcellshop, logesh_ashok, longowal, manaram, max0066, mdhasan2005, megalitz, mickervin, Mizan_Rahman, mnijesh, mobilesharif, mohsip9, mohzish, Mr. Right, mrajitkumar, Mudasirawais, Muhammad Zakria, mwaseem, nadeem101, nahashon dianga, najim uddin, nani1000, naushad09, NETTOSIMLA, niladrism_1979, Omega157, omidsh, onewkhaye, p12_panha, pakloi, PENGUINSYSTEMS, platini, POWER MAN, PRAKASHSANG, prasad2, Pratheesh T K, preetmobile, prem_airtelsp, quickgsm, rangaewb, razvanik_89, revitcadder, robf1rst@yahoo, ronin75, rvijethunga, saeed ahmed, sajin6660, salbahe_2087, samirsana, Sandeepjagdeva, SarAyatin, shaab, shab rafiq, shah g, shahjee99, shambu, sharmietv, sharpgsm, shivaji raje, silverio, Spark Plug, spsalu, Ssadabridge_84, sselectronics, sudhirpaul, syedbaazigar, system failure, t102ati, taieeb, tariquebaig, telecom2, Test Point, tharindunn, themobileguy1, ttms, umarfa, viccky, vijay1101, vijaykumar_1971, vinku8899, vinod raina, WaOneCell, yos_2684, yotyot, yulsa, zeedan, zen_01001, ~The JoKeR~
Old 07-05-2004, 17:17   #2 (permalink)
keany's Avatar
Member: 67419
any questions for signal ,you must replay here.
The Following 13 Users Say Thank You to keany For This Useful Post:
Old 07-05-2004, 17:20   #3 (permalink)
megone's Avatar
Member: 31594
bravos.........good experience))
The Following 4 Users Say Thank You to megone For This Useful Post:
Old 07-05-2004, 18:49   #4 (permalink)
DeltaGSM's Avatar
Member: 65947
@keany
good job
The Following 2 Users Say Thank You to DeltaGSM For This Useful Post:
Old 07-06-2004, 09:07   #5 (permalink)
Member: 25763
good job..keep up the *** work
The Following User Says Thank You to supremegsm For This Useful Post:
Old 07-06-2004, 09:21   #6 (permalink)
keany's Avatar
Member: 67419
i am waiting for your questions in nokia signal
The Following 3 Users Say Thank You to keany For This Useful Post:
Old 07-06-2004, 09:30   #7 (permalink)
keany's Avatar
Member: 67419
i think not anyone is not expert !!! i have an experience with 2 inginiers of nokia and they arent experts .
good luck
The Following 2 Users Say Thank You to keany For This Useful Post:
Old 07-06-2004, 12:29   #8 (permalink)
GSM SNIPER's Avatar
Member: 27291
3310 no signal :
So as you said above:
PA is not the cause !
can the problem be in Swtch antenna since It was the first Rx responsable ?
The Following 2 Users Say Thank You to GSM SNIPER For This Useful Post:
Old 07-06-2004, 15:22   #9 (permalink)
keany's Avatar
Member: 67419
antena switch is too responsabil of rx problems .but i dont understand well what are you trying to tell me?
Old 07-06-2004, 19:48   #10 (permalink)
Member: 44625
In a 5210, it can find network manually and works fine. When on automatic network selection, it can't find signal. WHat could be the cause?
The Following 2 Users Say Thank You to Trion For This Useful Post:
Old 07-06-2004, 19:55   #11 (permalink)
eeprom_flash's Avatar
Member: 58599
nice question here man
The Following 2 Users Say Thank You to eeprom_flash For This Useful Post:
Old 07-06-2004, 20:35   #12 (permalink)
Member: 31028
yes! and on dct 4 a 6310 and 6100 that can not find signal, switched PA, and ant switch also saw... what could be??? upp? uem? the ic underneath the saw???
regards
The Following 2 Users Say Thank You to [Rod] For This Useful Post:
Old 07-07-2004, 08:27   #13 (permalink)
keany's Avatar
Member: 67419
5210 is a nokia delusion phone .100% of his problems is the flash ic and cpu.in your problem i see that your memory is not working well you must change (or hot flash ic)
and after flash the phone with a good flash file.this is one way (the problem of your memory ) but in signal problem dublexer make a switch of signal must change it!
The Following User Says Thank You to keany For This Useful Post:
Old 07-07-2004, 08:34   #14 (permalink)
keany's Avatar
Member: 67419
ok in 6310 and 6310i most of signal problems is HAGAR. if he can not find signal the problem is the receiver RX and a hagar is the most responbil for these in rx not exluse and dublexer but 85% is hagar
Old 07-07-2004, 08:41   #15 (permalink)
keany's Avatar
Member: 67419
when i say hagar i mean (mjolner)
Nokia 1600 no signal solution required azam_gsm1 Nokia Hardware & Hardware-Repair Area 9 02-23-2009 10:03
3100 No signal solution irfaN_vu Nokia Hardware & Hardware-Repair Area 31 05-22-2008 03:54
For new beginners. here Nokia code's pazeth™ Nokia Hardware & Hardware-Repair Area 0 06-26-2005 15:20
1220 NO signal solutions mrfixit Various CDMA/TDMA Cell Phones 1 04-03-2005 18:04
lg 8110 no signal solution ihsanali LG 5 03-03-2005 10:51
Page generated in 0.41977 seconds with 12 queries
