Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
02-14-2008, 08:39 | #887 (permalink) | |
Junior Member Join Date: Apr 2006
Member: 260351 Status: Offline Thanks Meter: 0 | Quote:
rehot flash ics check clock crystal update with new verson tink ur problem solved n if not then pls tell me wether it is water damaged or any other physical damages | |
02-23-2008, 19:39 | #888 (permalink) |
Crazy Poster Join Date: Mar 2006
Member: 246850 Status: Offline Thanks Meter: 15 | continue charging when switch ON hi to all, i having problem with my nokia 6600 1st the bluetooth wont work i skip it when do flashing after that 2nd the nokia 6600 continue charging when switch ON it wont stop charging althought after 8 hour continue charging but the wired part is if the phone is switch OFF it can fully charge the battery, till now already try out the Low Batt solution that is change the L140 but still having this wired problem help me out Thank you i already spend around two week time to slove this but i still cant mange to find out what wrong with this nokia 6600 |
03-06-2008, 20:08 | #889 (permalink) |
Junior Member Join Date: May 2007 Location: PortHarcourt,Nigeria
Member: 505072 Status: Offline Thanks Meter: 0 | hi sir, i have problem with my 6600 the phone work normal but after some hours mins depending phone creen will show white and tripe off, some time if you power it on it will go off immidiatry. pls help if any solution 4 dis fualt. my mail[email protected] |
07-12-2008, 05:57 | #896 (permalink) |
Junior Member Join Date: Feb 2005 Location: INDIA Age: 43
Member: 117344 Status: Offline Thanks Meter: 0 | 6600 MMC corrupted (in phone ) else fine please help my card working fine till night, after charging phone displaying no memory card, but same is working fine in pc. after formatting MMC(through PC) and 6600 its shows "memory card corrupted" on formating from phone its shows formatting complet and asking for name but fails to name it. and again shows "memmory card corrupted" same time MMC working fne in PC please hel |
Motorola W220 Display Problem Solved Here | Kanwalgee | Infinity-Box | 41 | 04-19-2013 18:26 |
et related problem solved here | gurukripa1982 | ET-BoX | 31 | 07-07-2010 03:50 |
problem solve here!!! | utol_kiko13 | Nokia Hardware & Hardware Repair | 34 | 04-23-2009 04:55 |
7250i problems solved here | gsmindia | Nokia Digital Core Technology 4 ( DCT-4 ) | 38 | 08-31-2007 04:06 |
