Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 07-21-2005, 15:22   #1 (permalink)
gsmindia's Avatar
Member: 107636
Smile Nokia 6600 problems solved here
Hi all members post all your problems here for quick and best troubleshooting all hardware and software queries will be answered here. Specialized in nokia 6600 problem solving.
Old 07-21-2005, 15:25   #2 (permalink)
imran_qasim's Avatar
Member: 133436
Sonork: 100.1577364
my nOkia 6600 play wav file very low sound in Voice Recorder but it play fine in Profile
when i play in Sound Recorder sound comes from the Speaker on front side when i play in Profile it came from back end with fine quality
thnx in advance
take care
The Following 7 Users Say Thank You to imran_qasim For This Useful Post:
Old 07-21-2005, 15:36   #3 (permalink)
gsmindia's Avatar
Member: 107636
thnx in advance
take care
Hi imran
try installing other player in your phone and then see if the sound quality changes try real one or power player. It is not a hardware problem only u need to put add on or 3rd party software for this to work perfectly.
best regards
The Following 8 Users Say Thank You to gsmindia For This Useful Post:
Old 07-21-2005, 21:35   #4 (permalink)
kailash_gm's Avatar
Member: 101117
hey 6600 1st boot ok
2nd boot err does not show there id
i.e massage comes unknown flash manufactrer
The Following 2 Users Say Thank You to kailash_gm For This Useful Post:
Old 07-21-2005, 21:52   #5 (permalink)
Member: 133436
Sonork: 100.1577364
Originally Posted by gsmindia
Hi imran
best regards
as i explained that Sound Quality is fine when i play tone from Profile Manager
but it had very pooor sound quality when i play from gallery and it opens in Sound Recorder i am trying to play .wav file in Sound recorder , installing 3rd party software is not a solution for it (i think), but thnxxx for u advice , even video songs are playing veryfine in RealPlayer and in SmartMovie, i only have problem with Sound Recorder (.wav) files
thnxxxx
take care
The Following 4 Users Say Thank You to imran_qasim For This Useful Post:
Old 07-22-2005, 06:34   #6 (permalink)
Member: 161018
Post
DEAR SIR PLZ HELP HOW TO SOLVE THE PROBLEM OF NOKIA 6600
The Following 6 Users Say Thank You to murtazabhurani For This Useful Post:
Old 07-22-2005, 08:05   #7 (permalink)
yoya's Avatar
Member: 80255
some flash ic is bad or unsoldered try to rehot if not work you must change ic
The Following 6 Users Say Thank You to yoya For This Useful Post:
Old 07-22-2005, 08:58   #8 (permalink)
gsmindia's Avatar
Member: 107636
Hi,
Heat the rom3 area marked in the diagran provided and then check again if 2nd boot is ok . in case it is not then post reply and i will help you.
best regards
Old 07-22-2005, 09:06   #9 (permalink)
gsmindia's Avatar
Member: 107636
Dear Murtaza,
Please post your problem on the forum and i will post the solution.
Best regards
Old 07-22-2005, 21:47   #10 (permalink)
Member: 76284
6600 full flashed ok [including bt] but when power on .only white screen for 45 seconds and turns off.
what it could be?
The Following 8 Users Say Thank You to zeeber For This Useful Post:
Old 07-23-2005, 20:52   #11 (permalink)
kailash_gm's Avatar
Member: 101117
thanks for the solution but i have also reballed the flash ic butafter that its in white light does not display nokia on startup
if u can plz reply
The Following 7 Users Say Thank You to kailash_gm For This Useful Post:
Old 07-23-2005, 21:29   #12 (permalink)
Member: 133436
Sonork: 100.1577364
what it could be?
just format user area then all will be Ook Again
take care
The Following 5 Users Say Thank You to imran_qasim For This Useful Post:
Old 07-23-2005, 21:46   #13 (permalink)
Member: 52087
can any one give me data sheet for z141 = ip4041cx25
The Following 4 Users Say Thank You to saidi321 For This Useful Post:
Old 07-23-2005, 22:44   #14 (permalink)
Friendship's Avatar
Member: 141127
Red face
take care
how can be to format user area,
if the phone not in local mode only white screen????????
The Following 5 Users Say Thank You to Friendship For This Useful Post:
Old 07-23-2005, 22:48   #15 (permalink)
Member: 133436
Sonork: 100.1577364
then just try to flash with latest flash file and try to slow the speed of flashing and dont reset anything and then power on the phone
take care
Motorola W220 Display Problem Solved Here Kanwalgee Infinity-Box 42 04-19-2013 18:26
et related problem solved here gurukripa1982 ET-BoX 31 07-07-2010 03:50
problem solve here!!! utol_kiko13 Nokia Hardware & Hardware-Repair Area 34 04-23-2009 04:55
7250i problems solved here gsmindia Nokia Digital Core Technology 4 ( DCT-4 ) 38 08-31-2007 04:06
Page generated in 0.37438 seconds with 12 queries
