Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
07-28-2005, 12:04 | #47 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: india Age: 49
Member: 107636 Status: Offline Thanks Meter: 100 | Quote:
The Following User Says Thank You to gsmindia For This Useful Post: |
07-29-2005, 07:43 | #50 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: BANDA ACEH INDONESIA
Member: 74519 Status: Offline Thanks Meter: 79 | Quote:
I think your file is damaged or something like that | |
07-29-2005, 13:14 | #51 (permalink) |
Junior Member Join Date: Jan 2005 Age: 45
Member: 104566 Status: Offline Thanks Meter: 0 | Sorry, didn't see this post when I wrote mine: http://forum.gsmhosting.com/vbb/showthread.php?t=222834 -------------- Hi all! My Nokia 6600 fell on the floor from 1m height and the backlight of the display went dead. The display and everything else works perfectly. What do you suggest I could do? Thanks for all your help in advance. Regards, Vitamin G. |
07-30-2005, 22:34 | #52 (permalink) |
Member: 107636 Status: Offline Thanks Meter: 100 | Problem : 6600 hangs/system failure message/contact retailer/blinking nokia/white screen solution : Format user area , You can do this by the following methods method 1 : press "*" + "green call button " + "3" press all the three togather and then press power on switch. keep all the 4 switches on till the word "formatting " appears on your screen. Then release all the keys and formatting will continue. method 2 : type *#7370# , the phone reset to original factory settings , phone prompts the user to enter the security code and after user enters the security code phone switches off then switches on. method 3 : format user area using ufs/griffin/or any other box. Gsmindia |
07-31-2005, 18:55 | #53 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Indonesia
Member: 90761 Status: Offline Sonork: 1617079 Thanks Meter: 95 | i`ve some experimen with 6600 if the phone say contact retailer & already format user area but not work..!!! usualy the problem from ic ram. maybe ram have broken ball so try to rehot or change it. |
The Following User Says Thank You to ekel For This Useful Post: |
07-31-2005, 19:49 | #54 (permalink) | |
08-07-2005, 12:04 | #55 (permalink) | |
No Life Poster Join Date: Aug 2004 Location: there Age: 19
Member: 77394 Status: Offline Thanks Meter: 118 | for gsminda Quote:
please GsmInda the file won't extracted need part2. | |
08-07-2005, 20:02 | #56 (permalink) | |
08-09-2005, 08:09 | #57 (permalink) | |
Registered User Join Date: Sep 2003 Location: Palestine Age: 50
Member: 39208 Status: Offline Thanks Meter: 152 | Quote:
08-09-2005, 18:55 | #58 (permalink) |
No Life Poster Join Date: Jul 2003 Location: LEBANON
Member: 33690 Status: Offline Thanks Meter: 3,398 | 6600 Signal Drop Hello Gsmindia, I Have This 6600 That Is Reallly Giving Me Pain. Reception Comes For About 30 Seconds And They Goes. I Changed Pa, Reflashed, Uploaded Pm But No Luck. Even Reheated The Flash Ics But Still The Same. Any Ideas, Thanks. |
08-09-2005, 20:52 | #59 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: Cuttack,India Age: 54
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | Quote:
The Following User Says Thank You to TURNING POINT For This Useful Post: |
Motorola W220 Display Problem Solved Here | Kanwalgee | Infinity-Box | 41 | 04-19-2013 18:26 |
et related problem solved here | gurukripa1982 | ET-BoX | 31 | 07-07-2010 03:50 |
problem solve here!!! | utol_kiko13 | Nokia Hardware & Hardware Repair | 34 | 04-23-2009 04:55 |
7250i problems solved here | gsmindia | Nokia Digital Core Technology 4 ( DCT-4 ) | 38 | 08-31-2007 04:06 |
