Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
08-10-2005, 09:35 | #61 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: india Age: 49
Member: 107636 Status: Offline Thanks Meter: 100 | Quote:
please mention the exact nature of your problem. best regards | |
08-11-2005, 02:01 | #62 (permalink) |
Freak Poster Join Date: Jul 2005 Age: 47
Member: 165798 Status: Offline Thanks Meter: 3 | nokia 6620 freezes up every dang time i mess with virus software my phone messes up i got the latests simworks and copied AVServer to system/app/antivirus then rebooted my phone and everything moves like christmas now....so slow i can not even bring a menu up to delete anything using fe explorer i scanned all files before copying for viruses to my phone using nortons with the most updated virus definitions what gives with this is there anything i can do the phone wont connect usb either for some reason probably because something is bogging the phone down thanks to all who reply |
08-11-2005, 02:24 | #63 (permalink) |
Member: 165798 Status: Offline Thanks Meter: 3 | very helpful tips posted earlier in thread fix 1 solved my problem Problem : 6600 hangs/system failure message/contact retailer/blinking nokia/white screen solution : Format user area , You can do this by the following methods method 1 : press "*" + "green call button " + "3" press all the three togather and then press power on switch. keep all the 4 switches on till the word "formatting " appears on your screen. Then release all the keys and formatting will continue. method 2 : type *#7370# , the phone reset to original factory settings , phone prompts the user to enter the security code and after user enters the security code phone switches off then switches on. method 3 : format user area using ufs/griffin/or any other box. Gsmindia |
08-15-2005, 19:10 | #64 (permalink) | |
No Life Poster Join Date: Aug 2004 Age: 47
Member: 76257 Status: Offline Thanks Meter: 77 | Quote:
08-16-2005, 07:01 | #65 (permalink) |
Insane Poster Join Date: Apr 2004
Member: 61249 Status: Offline Thanks Meter: 0 | My dear friends, I am a Nokia authorised service technician,here we uses pheonix and fps8. I have one 6600 when it flashing it asks for "put power on" after switch has pressed the light comes but there is no NOKIA logo appears and does not coming to local mode.I have replaced"Battery connector,UPP ,sdram and all falsh ICs,Still the problem is same. Please help me to get a solution. How can i trouble shoot the errors by falshing using only Image file or the PPM file or the content file only. Previously i put one thread on 7610 error but till date i didnot received reply. Please guys need your help. Best Regards Techman |
08-16-2005, 18:33 | #66 (permalink) |
Junior Member Join Date: Aug 2005 Age: 45
Member: 171344 Status: Offline Thanks Meter: 0 | hi. my n6600 would show "App Closed Nsnlist" when i get sms or while reading it. i tried renamed my 1st boot to Xfirstboot.dat, and restarted my phone. my phone made another 1st boot. just awhile ago, my phone showed "App Cloased Ncnlist" again. what shall i do? |
08-17-2005, 09:49 | #67 (permalink) | |
Freak Poster Join Date: Jul 2005 Location: cebu Age: 43
Member: 164237 Status: Offline Thanks Meter: 12 | Quote:
08-17-2005, 09:51 | #68 (permalink) | |
08-17-2005, 09:53 | #69 (permalink) | |
08-19-2005, 10:08 | #70 (permalink) |
No Life Poster Join Date: Sep 2002 Location: mauritius
Member: 15162 Status: Offline Thanks Meter: 61 | Hi all I have one 6600 when power on with simcard ..network full ,when make a call it restart the phone. When received a call it rings and when take the call it freeze and after 5 sec it ok again.if recall on the phone it says phone off. I have flash mcu ppm erase user area.....same problem Have upload new pm file ....same problem Have rehot ic pa antena switch ....same problem Please let me know the problem cheers Djyash |
08-19-2005, 11:46 | #71 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: BANDA ACEH INDONESIA
Member: 74519 Status: Offline Thanks Meter: 79 | Quote:
change PA (power amplifier} | |
08-19-2005, 18:40 | #72 (permalink) |
Freak Poster Join Date: Jun 2003 Location: 9 JA
Member: 30405 Status: Offline Thanks Meter: 3 | Guys!!!! hav u experience this problem.... application closed, cannot open gallery,bluethooth not working....everytime app closed...when u try to flash it will always show error. Is this software or hardware problem Br |
08-19-2005, 20:50 | #74 (permalink) | |
Insane Poster Join Date: Oct 2004 Age: 43
Member: 86070 Status: Offline Thanks Meter: 0 | Quote:
08-19-2005, 21:20 | #75 (permalink) |
Freak Poster Join Date: Nov 2003 Location: Technology
Member: 44251 Status: Offline Thanks Meter: 5 | Before change the module ic do this. 1. Erase flash 2. Uncheck the enable bt flashing button 3. Write the MCU + PPM file with latest firmware 4. Click the UI settings button 5. Formate the phone If you still having the problem, t then change or rehot the bt module and flash the phone with enable bt flashing. |
Motorola W220 Display Problem Solved Here | Kanwalgee | Infinity-Box | 41 | 04-19-2013 18:26 |
et related problem solved here | gurukripa1982 | ET-BoX | 31 | 07-07-2010 03:50 |
problem solve here!!! | utol_kiko13 | Nokia Hardware & Hardware Repair | 34 | 04-23-2009 04:55 |
7250i problems solved here | gsmindia | Nokia Digital Core Technology 4 ( DCT-4 ) | 38 | 08-31-2007 04:06 |
