Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
02-17-2011, 08:46 | #1067 (permalink) | |
Junior Member Join Date: Jan 2011
Member: 1498432 Status: Offline Sonork: bogs Thanks Meter: 0 | Two units nokia 6600 model with different problem Quote:
one unit the problem is GALLERY, it is hard to open the GALLERY menu...... and the other one unit problem is the memory card, meaning when i used the mini SD MMC, on multimedie menu the prompt will always be "memory card is corrupted", and if i used the micro MMC the prompt is always "no memory card is inserted". I dont know what is the solution on it... plsss help me.... Action taken is reformat & reprogram v5.27 using HWK software but unfortunately the problem has not been solved.. Thanks in advance for helping me sir........... | |
08-18-2011, 07:16 | #1071 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1637432 Status: Offline Thanks Meter: 0 | My Mobile fell down last day. After this, its mic stopped working. I opened the whole set and then plug out that mic, clean it and re-plug it in the right place. But when I restart my set, it display only a white screen. i try to format using 3 keys combination but it also did noting in this regard (same white screen). Plz help |
09-04-2011, 15:13 | #1073 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: Saudi Arabia
Member: 615730 Status: Offline Thanks Meter: 256 | Quote:
04-01-2012, 08:10 | #1076 (permalink) |
Junior Member Join Date: Feb 2009
Member: 967385 Status: Offline Thanks Meter: 0 | Sorry to bump this thread, but my Nokia 6600 (manufactured in 2004 December-V 5.53.0 NHL10) has the following problem- I was unable to open the gallery and BlueTooth menu, but this was fixed by a local repair shop in December. The BlueTooth operations performed well and the gallery opened after the repair. Recenlty the BlueTooth menu can be accessed, but when I select "BlueTooth ON" I get "cannot perform operation" error. But the biggest problem my phone has is that the battery life is very short; around two days. I am a very light phone user and the only aftermarket application I have installed is Fexplorer. I have noticed that sometimes the screensaver is not switched on, even though it is enabled from settings. The battery is a genuine BL5C purchased from the Nokia agents in October. I installed "F Secure" antivirus and scanned the phone and the results were that it was not infected. I even tested it for the "cabir" virus and the result was negative. What must I do to get it working properly again? Will reflashing it work? Any replies appreciated. |
Motorola W220 Display Problem Solved Here | Kanwalgee | Infinity-Box | 41 | 04-19-2013 18:26 |
et related problem solved here | gurukripa1982 | ET-BoX | 31 | 07-07-2010 03:50 |
problem solve here!!! | utol_kiko13 | Nokia Hardware & Hardware Repair | 34 | 04-23-2009 04:55 |
7250i problems solved here | gsmindia | Nokia Digital Core Technology 4 ( DCT-4 ) | 38 | 08-31-2007 04:06 |
