Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
07-21-2005, 15:22 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: india Age: 49
Member: 107636 Status: Offline Thanks Meter: 100 | Nokia 6600 problems solved here |
The Following 40 Users Say Thank You to gsmindia For This Useful Post: |
07-21-2005, 15:25 | #2 (permalink) |
No Life Poster Join Date: Apr 2005 Location: PAKISTAN Age: 45
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | my nOkia 6600 play wav file very low sound in Voice Recorder but it play fine in Profile when i play in Sound Recorder sound comes from the Speaker on front side when i play in Profile it came from back end with fine quality thnx in advance take care |
The Following 7 Users Say Thank You to imran_qasim For This Useful Post: |
07-21-2005, 15:36 | #3 (permalink) | |
Member: 107636 Status: Offline Thanks Meter: 100 | Quote:
try installing other player in your phone and then see if the sound quality changes try real one or power player. It is not a hardware problem only u need to put add on or 3rd party software for this to work perfectly. best regards | |
The Following 8 Users Say Thank You to gsmindia For This Useful Post: |
07-21-2005, 21:35 | #4 (permalink) |
No Life Poster Join Date: Dec 2004 Location: india Age: 40
Member: 101117 Status: Offline Thanks Meter: 466 | hey 6600 1st boot ok 2nd boot err does not show there id i.e massage comes unknown flash manufactrer |
The Following 2 Users Say Thank You to kailash_gm For This Useful Post: |
07-21-2005, 21:52 | #5 (permalink) | |
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Quote:
but it had very pooor sound quality when i play from gallery and it opens in Sound Recorder i am trying to play .wav file in Sound recorder , installing 3rd party software is not a solution for it (i think), but thnxxx for u advice , even video songs are playing veryfine in RealPlayer and in SmartMovie, i only have problem with Sound Recorder (.wav) files thnxxxx take care | |
The Following 4 Users Say Thank You to imran_qasim For This Useful Post: |
07-22-2005, 06:34 | #6 (permalink) | |
Junior Member Join Date: Jul 2005 Age: 40
Member: 161018 Status: Offline Thanks Meter: 6 | Quote:
The Following 6 Users Say Thank You to murtazabhurani For This Useful Post: |
07-22-2005, 08:05 | #7 (permalink) | |
Freak Poster Join Date: Sep 2004 Location: Beograd Age: 48
Member: 80255 Status: Offline Thanks Meter: 15 | Quote:
The Following 6 Users Say Thank You to yoya For This Useful Post: |
07-22-2005, 08:58 | #8 (permalink) | |
Heat the rom3 area marked in the diagran provided and then check again if 2nd boot is ok . in case it is not then post reply and i will help you. best regards | |
The Following 22 Users Say Thank You to gsmindia For This Useful Post: |
07-22-2005, 09:06 | #9 (permalink) | |
Please post your problem on the forum and i will post the solution. Best regards | |
07-22-2005, 21:47 | #10 (permalink) |
Registered User Join Date: Aug 2004 Location: Hall Road Lhr Age: 43
Member: 76284 Status: Offline Sonork: 1001625595 Thanks Meter: 24 | 6600 full flashed ok [including bt] but when power on .only white screen for 45 seconds and turns off. what it could be? |
The Following 8 Users Say Thank You to zeeber For This Useful Post: |
07-23-2005, 20:52 | #11 (permalink) |
Member: 101117 Status: Offline Thanks Meter: 466 | thanks for the solution but i have also reballed the flash ic butafter that its in white light does not display nokia on startup if u can plz reply |
The Following 7 Users Say Thank You to kailash_gm For This Useful Post: |
07-23-2005, 21:29 | #12 (permalink) | |
take care | |
The Following 5 Users Say Thank You to imran_qasim For This Useful Post: |
07-23-2005, 22:44 | #14 (permalink) | |
Freak Poster Join Date: Apr 2005 Age: 52
Member: 141127 Status: Offline Thanks Meter: 6 | Quote:
if the phone not in local mode only white screen???????? | |
The Following 5 Users Say Thank You to Friendship For This Useful Post: |
07-23-2005, 22:48 | #15 (permalink) | |
take care | |
Motorola W220 Display Problem Solved Here | Kanwalgee | Infinity-Box | 41 | 04-19-2013 18:26 |
et related problem solved here | gurukripa1982 | ET-BoX | 31 | 07-07-2010 03:50 |
problem solve here!!! | utol_kiko13 | Nokia Hardware & Hardware Repair | 34 | 04-23-2009 04:55 |
7250i problems solved here | gsmindia | Nokia Digital Core Technology 4 ( DCT-4 ) | 38 | 08-31-2007 04:06 |
