Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Hardware & Hardware Repair > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 04-12-2008, 15:11   #16 (permalink)
foufou34's Avatar
Member: 695274
Thanks Meter: 793
about 3220
rest the same problem pleas give me another solution..
The Following User Says Thank You to foufou34 For This Useful Post:
Old 04-12-2008, 17:20   #17 (permalink)
Member: 461923
Thanks Meter: 2,015
foufou34 please check :
1. if line A B is continuous
2. if line C D is continuous
3. if line A E is continuous
..and post results..
The Following 7 Users Say Thank You to stefani For This Useful Post:
Old 04-12-2008, 20:43   #18 (permalink)
Member: 461923
Thanks Meter: 2,015
E50 keypad repair :
Z2400 FES EMIF10COM01F2 is compatibility with nokia 6280, N70, 6233, 6234, 6151, SE k750i, SE W810i etc. IC
Z2409 EMIF02-MIC02F3 is compatibility with nokia 6170, 6151, N series etc. IC
The Following 14 Users Say Thank You to stefani For This Useful Post:
Old 04-12-2008, 22:10   #19 (permalink)
Member: 659827
Thanks Meter: 16
3500 changed i.c still not working 1.4.7.send.
Old 04-12-2008, 23:11   #20 (permalink)
Member: 382641
Thanks Meter: 14
Originally Posted by stefani View Post
Nokia 2310 keypad repair..clean and rehot ..if don't work replace Z2400 IC..Succes
thanks i replace the Z2400 and now the keypad is working
Old 04-13-2008, 09:38   #21 (permalink)
Member: 461923
Thanks Meter: 2,015
mittho.gsm..which type of IC you use ?? Use EMIF10-LCD02F3....If you are sure 100% IC changed is ok then reheat UPP...Succes
The Following User Says Thank You to stefani For This Useful Post:
Old 04-16-2008, 10:05   #22 (permalink)
Member: 601984
Thanks Meter: 445
sir g i have e50 in this phone memorycard not working so if u have any soulution tell me advance thanks
Old 04-16-2008, 14:15   #23 (permalink)
Member: 461923
Thanks Meter: 2,015
..a.asifali, this post is only about nokia keypad problem..but for your problem i try to give a response tomorrow...
Old 04-16-2008, 14:22   #24 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
Thanks Meter: 851
Have Problem With N70 2,3 7,8 Noth Work Im Change Ic But Stiill Same Problem
Old 04-16-2008, 14:32   #25 (permalink)
Member: 751634
Sonork: phonestop
nokia 6288 number 1 2 3 not working need help
Old 04-16-2008, 15:48   #26 (permalink)
Member: 461923
Thanks Meter: 2,015
N70 keypad repair :
..delchoni, wich IC you change ?? check this foto..
Z4401 EMIF02-MIC02F2 is compatibility with nokia 6170, 6151, N series etc. IC
.. be carefulness with OMAP when change the IC..Succes and post results...
The Following 11 Users Say Thank You to stefani For This Useful Post:
Old 04-16-2008, 15:59   #27 (permalink)
AAS.Akbar's Avatar
Member: 750628
Thanks Meter: 55
Check this.................................!
The Following 8 Users Say Thank You to AAS.Akbar For This Useful Post:
Old 04-16-2008, 18:48   #28 (permalink)
Member: 461923
Thanks Meter: 2,015
...AAS.Akbar thank's for your help..it's s good picture...
Old 04-17-2008, 08:57   #29 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
Thanks Meter: 851
Wink thanks for nice solutions ...
N70 keypad repair :
before im change Z4400
REGARDS
Old 04-17-2008, 09:00   #30 (permalink)
Member: 461923
Thanks Meter: 2,015
..change Z4401 and post results please...
post me your problem in motorola and let me give you the rite solution greeni222000 Motorola Hardware Repair 2149 01-15-2020 04:23
Hello....Post here any problem about Nokia dharmdev Nokia Hardware & Hardware Repair 3 08-17-2013 07:07
Post Here Any Problem About Advance Cdma.. ch mobiles Advance Cdma Products 1 03-06-2010 15:26
Once again, NsTeam give you the solution for new models: ***NsPro v2.0.3*** Elco NSPRO 52 03-24-2007 19:12
Page generated in 0.47863 seconds with 9 queries
