Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
07-08-2010, 10:06 | #751 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Please Repair Your Key-pad is Very Carefully i hope your Problem willbe gone............. |
The Following 3 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
08-26-2010, 04:50 | #759 (permalink) |
Crazy Poster Join Date: Jul 2009
Member: 1070488 Status: Offline Thanks Meter: 1 | hi dear i have the keypad problem with nokia 6680. it happened after the repairman replaced the data cable connector pins [or say socket.. because there was a lot of oxcide and he said that the entire connector needs to be replaced and so i nodded to do so..] .... and now key "4" and Cancel/NO [red one] is not working... how to solve it ? i am badly in need of any help... plz help me....also the keypad ic was changed thrice but still not working... hope u help me... it was all ok before this surgery... so do u think what could lead to this problem ? technician said that replcacing it has no concern with the keypad......... and it was already faulty... which off course was not... thanks Last edited by khankll; 08-26-2010 at 04:59. |
09-03-2010, 01:47 | #761 (permalink) |
Junior Member Join Date: Mar 2006
Member: 241075 Status: Offline Thanks Meter: 0 | Hello I`ve got 5610, and 1,2,3 keys don`t work,and led`s are bkinking,like a bad contact. Flex pad is ok,i`ve checked it,also saw schematics - row2 has key "down" on upper pad - it works just fine. What is the problem? Z2405 or Z2406? Or there is other solutions? Thanks |
10-06-2010, 19:30 | #764 (permalink) |
Member: 1070488 Status: Offline Thanks Meter: 1 | ^^^ i also got the same prints damaged issue with my 6680. keys 2,3,7,8 not working.. repaiman says cannot be repaired.. is it true... have tried changing the keypad ic more then a 4 times but no solution |
post me your problem in motorola and let me give you the rite solution | greeni222000 | Motorola Hardware Repair | 2161 | 12-25-2023 05:54 |
Hello....Post here any problem about Nokia | dharmdev | Nokia Hardware & Hardware Repair | 3 | 08-17-2013 06:07 |
Post Here Any Problem About Advance Cdma.. | ch mobiles | Advance Cdma Products | 1 | 03-06-2010 15:26 |
Once again, NsTeam give you the solution for new models: ***NsPro v2.0.3*** | Elco | NSPRO | 52 | 03-24-2007 18:12 |
