Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
12-08-2012, 05:33 | #841 (permalink) |
Junior Member Join Date: Dec 2012
Member: 1850048 Status: Offline Thanks Meter: 0 | |
03-23-2013, 12:05 | #843 (permalink) |
Junior Member Join Date: Apr 2010
Member: 1292201 Status: Offline Thanks Meter: 0 | my n73 joystick down button sometime working well, but sometime working like middle and right joystic key. When i remove screen holder (which holds screen) problem solved but it is impossible to remove screen holder because without screen holder, screen can be damage. Then what i do ? |
03-25-2013, 08:45 | #844 (permalink) |
Member: 1292201 Status: Offline Thanks Meter: 0 | I 100% solve n73 keypad wrong behaviour problem without any charge. We know that n73 screen holder holds screen around 4 corner at outside. I just band bottom 3 patti to 1 mm inside, now screen holder holds screen to 3 corner outside (top, right and left) and 1 side inside 3 patti (bottom). Ok your probld solved. I personally check this. |
08-16-2013, 09:30 | #847 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Br Max | |
08-16-2013, 09:35 | #848 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Uhhhhhhhhhh it's from magic ball, please post Full problem, what mean "i have problem in keypad?", can be only the block from Home ans Service button, this model want 3 sec.s of time in Service Button, but repeat w/o explaination only magic ball can solve u problem, BR Max |
post me your problem in motorola and let me give you the rite solution | greeni222000 | Motorola Hardware Repair | 2161 | 12-25-2023 05:54 |
Hello....Post here any problem about Nokia | dharmdev | Nokia Hardware & Hardware Repair | 3 | 08-17-2013 06:07 |
Post Here Any Problem About Advance Cdma.. | ch mobiles | Advance Cdma Products | 1 | 03-06-2010 15:26 |
Once again, NsTeam give you the solution for new models: ***NsPro v2.0.3*** | Elco | NSPRO | 52 | 03-24-2007 18:12 |
