Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
05-13-2006, 08:39 | #151 (permalink) |
Freak Poster Join Date: Feb 2002 Location: MOBILE
Member: 9491 Status: Offline Thanks Meter: 14 | 6600 power on problem i could flash the set set with success , after unclicking ENABLE BT FLASHING, BUT CANNOT GET INFORMATION OF THE SET OR DO UI SETTING. THE SET IS NOT POWERING ON. |
05-13-2006, 14:41 | #152 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: Uttaranchal Age: 35
Member: 181696 Status: Offline Sonork: 100.107830 Thanks Meter: 5,406 | Quote:
change memory card ic [email protected] | |
05-25-2006, 00:02 | #153 (permalink) |
Junior Member Join Date: Mar 2005 Age: 38
Member: 128627 Status: Offline Thanks Meter: 0 | 6600 works badly... Hi! At once, my 6600 began to work badly. The bluetooth doesn't work, it says "Can't Start Bluetooth operation" or something similar. it became very slowly, and the vibration does'nt work always. it works only a few time... If i also start an application, it stops working, and it "crash"... what happened to my phone? what can i do? I want to tell you that i didn't hurt it and it never fall. I'll wait for your reply. Thank you very much Tamer |
06-05-2006, 15:58 | #154 (permalink) | |
No Life Poster Join Date: Mar 2006 Age: 41
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | Quote:
after formatting press *#7370# | |
06-09-2006, 12:15 | #156 (permalink) |
Junior Member Join Date: Apr 2006
Member: 267900 Status: Offline Thanks Meter: 0 | hello ismile bhi i am nauman khan tell me any jumper solution OR any other solution of 6600 "Not charging" tell me a way without changing UEM .................. Nauman khan mardan |
06-09-2006, 23:59 | #157 (permalink) | |
Freak Poster Join Date: Feb 2006 Location: pakistan
Member: 232662 Status: Offline Thanks Meter: 58 | Quote:
WBR, ISMAIL KHAN | |
06-10-2006, 03:45 | #158 (permalink) | |
Freak Poster Join Date: Jul 2005 Location: cebu Age: 43
Member: 164237 Status: Offline Thanks Meter: 12 | Quote:
06-10-2006, 20:50 | #160 (permalink) | |
Member: 232662 Status: Offline Thanks Meter: 58 | Ismail Khan Quote:
Flash with UFS3 then inform here WBR, ISMAIL KHAN | |
06-11-2006, 11:36 | #162 (permalink) |
Junior Member Join Date: Jun 2006 Location: Pakistan
Member: 291990 Status: Offline Thanks Meter: 0 | Nokia 6600 key pad and unlock code problem Nokia 6600 key pad and unlock code problem Hi Guys.. i have a problem with my 6600/....its 'menu' and 'ok' key is not working well.. also i dont know the unlock code of my phone .... plz guide me what to do..... i have formated ma phone severel times but it doesnt solve my unlock code problem.. kindly guide me the flashing procedure as i am new to this World.. do u have nokia's charger circuit diagram if so then plz shre with me... i will be highly thankfull thanx |
06-12-2006, 10:23 | #163 (permalink) |
Freak Poster Join Date: Feb 2006 Location: cebu city phillipines
Member: 229636 Status: Offline Thanks Meter: 48 | 6600 hello to all my friends i have 6600 unit all letter and number spread i try change lcd filter or ic but still the same problem can you help me or post any solution so that i can solve my problem thanks a lot ............. |
06-12-2006, 11:49 | #164 (permalink) |
Member: 292526 Status: Offline Thanks Meter: 0 | free up some memory i'm posting because i have problem with my n6600 when I try to unlock keyboard ( or just press any key to close screansaver ) display blinks for a few seconds and free up some memory error jump. Not evry time but often. After half a minute phone recover but any button pressed invoke same error and phone again restart. Tried to format phone, take out battery for a few hours, try again and sooner or later error appeares. Friend put new version of software (flash) but problem is here... Any suggestion? |
06-12-2006, 12:12 | #165 (permalink) | |
Freak Poster Join Date: Mar 2006 Location: INDIA
Member: 239707 Status: Offline Thanks Meter: 14 | help me for 6600 Quote:
post me your problem (NOKIA) | nolyboy | Nokia Repair Guide and FAQ | 8987 | 02-27-2024 03:43 |
post me your problem in motorola and let me give you the rite solution | greeni222000 | Motorola Hardware Repair | 2161 | 12-25-2023 05:54 |
!!!!post Me Your Hardware Problem!!!! | Ustad rajab.Com | Nokia Hardware & Hardware Repair | 32 | 01-18-2013 08:37 |
Search And Post Here Your All 6600 Solution Problem's Ismail Khan | tommobil2005 | Nokia Hardware & Hardware Repair | 0 | 04-04-2006 16:55 |
