Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
02-27-2006, 21:41 | #31 (permalink) | |
Freak Poster Join Date: Feb 2006 Location: pakistan
Member: 232662 Status: Offline Thanks Meter: 58 | Ismail Khan Quote:
step1:click erase flash start address:02000000 end address : 027FFFFF *if get an *erase flash error *message in a specific address in the flash IC,this means that you have a damage flash IC. you will need to replace IC number 2 inside the phone .(the 6600 has 4 flash ICs inside). step2: if you are successful in erasing flash IC number 2, make a full flash of the phone....MCU,PPM & Bluetooth if required step3: if you are successful in full flashing the phone ,put battrey inside phone and you should GET "Contact Retailer" message again . now remove the battrey , put it backand hold buttons " call (green button on the left)"+ "*" +"3" then press the power button while still holding the 3 buttons above the phone should stsrt formatting itself (note that there must be no sim card inside the phone while doing this........) after formatting , phone should be ok... and press *#7370# phone will be reset but need to update a good pm file if nessessary. tyr this and tell me result im waiting for your result | |
The Following User Says Thank You to tommobil2005 For This Useful Post: |
03-01-2006, 12:53 | #33 (permalink) | |
Member: 232662 Status: Offline Thanks Meter: 58 | Ismail khan Quote:
2:change mic 3:if not not work check main IC and trace a fuolt with multimeter or replace foulted part's | |
03-01-2006, 12:59 | #34 (permalink) |
Member: 232662 Status: Offline Thanks Meter: 58 | Ismail khan hay turning point what about your 6600 contact the retailor tell me result im waiting Best Regard, Last edited by ..::Neo::..; 04-02-2006 at 22:54. |
03-01-2006, 20:29 | #35 (permalink) | ||
No Life Poster Join Date: Jul 2004 Location: Cuttack,India Age: 54
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | Quote:
its done with full flashing and format user area and manual formating Quote:
03-01-2006, 20:34 | #36 (permalink) |
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | dear have u any idea abut 6600 erase ok,full flash ok but not power on al so have screen shots in this thread http://forum.gsmhosting.com/vbb/show...57#post1526957 i tried without bt flashing also |
03-02-2006, 17:44 | #37 (permalink) | |
Member: 232662 Status: Offline Thanks Meter: 58 | Quote:
STEP1: UNINSTALL DCTX BB5 TOOL1.4_D STEP2: UNINSTALL NHL10 6600 FIRMWARE EXE'S "SURE THAT ALL COMPONENT'S UNINSTALL COMPLETELY" AND RESTART YOUR COMPUTER, INSTALL FRESH COPY OF SOFTWARE INSTALL BB5 TOOL1.4_D BY SARAS SOFT INSTALL NHL10 6600 FIRMWARE EXE'S STEP1: Remove battery and Connect cable in your phone and full erase flash with this file (6600_fullerase.fia) STEP2: FULL FLASH MCU,PPM,PMM CHOOSE THE NORMAL SPEED PRESS "START" BUTTON DO THE JOB . NOTE: WD2 PHONE BOOTING IS SLOW ,SO PLEASE BE PATIENT HERE, AND DON'T DO THESE STEPS FAST. STEP3: When flashing is done,choose "Normal" in UI Setting ,after that can see the "Init Normal Mode OK in the software STEP4:Choose "Local" in UI Setting, after that can see the "Init Local Mode OK" in the software STEP5:Press the "format user area" Button, after that can see the "User Area Format OK" in the software. step6:[SIZE=2] Done IF PHONE DOESN'T ENTER "LOCAL" MODE WHEN CONNECTED OR AFTER FLASHING. PLEASE CHECK CABLE WITH SCHEEMATICS (BSI WIRE) HERE MUST BE SERIAL RESISTOR ON BSI (3.3KOM) And also check power swicth also power swicth way's be sure is good and working proper, check filter, capaciter , daivode arround the power swicth , CHECK THIS. AND REPLY FAST RESULT. I M WAITING YOUR RESULT. Best Regard, tommobil2004GSM CO,LTD Last edited by ..::Neo::..; 04-02-2006 at 22:55. | |
03-02-2006, 18:34 | #38 (permalink) |
Member: 232662 Status: Offline Thanks Meter: 58 | Ismail Khan here im attach NHL10 6600 ERASE file hay turning point use this ok URL link : http://70.85.181.19/ufsx/download.php?id_file=3179 Best Regard, tommobil2004GSM CO,LTD Last edited by ..::Neo::..; 04-02-2006 at 22:55. |
03-02-2006, 19:14 | #39 (permalink) |
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | @thanks for your very clear and step by step solution for 6600,i think its helpful to many members i already tried but after flashing no normal mode showing anyway i will try again with my new computer not installed ufsx till now,i will try tomrrow and post u result |
03-03-2006, 12:46 | #40 (permalink) | |
TURNING POINT Please check phone connecting cable. Check also UFSX main USB cable. And sure that all cable working proper and a good If problem Occured YOU MUST change cable and try again Best Regard, tommobil2004GSM CO,LTD Last edited by ..::Neo::..; 04-02-2006 at 22:55. | |
03-03-2006, 15:56 | #41 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: india Age: 43
Member: 238252 Status: Offline Thanks Meter: 81 | Quote:
03-03-2006, 18:26 | #42 (permalink) | |
you forgot your access password contact your resseller and reset your password If you don't have orignale box and you want Buy Access Area. Be inform the ufsxsupport.com is payed site since 2 month box's clone box user want buy a access account login ID & password contact me at my mobile number or email me Best Regard, tommobil2004GSM CO,LTD Last edited by ..::Neo::..; 04-02-2006 at 22:59. | |
03-03-2006, 18:57 | #43 (permalink) | |
this is full erase patrun and full Erase phone Flash Last edited by ..::Neo::..; 04-02-2006 at 22:59. | |
The Following 2 Users Say Thank You to tommobil2005 For This Useful Post: |
03-04-2006, 08:55 | #44 (permalink) |
Freak Poster Join Date: Jul 2005 Location: cebu Age: 43
Member: 164237 Status: Offline Thanks Meter: 12 | @ turning point after flashing yor phone my friend, does it say failed rebooting mobile?your using UFS am i right? you might want to give a try using JAF to revive it bec i encountered similar problem with UFSXHWK.. B.R. |
post me your problem (NOKIA) | nolyboy | Nokia Repair Guide and FAQ | 8987 | 02-27-2024 03:43 |
post me your problem in motorola and let me give you the rite solution | greeni222000 | Motorola Hardware Repair | 2161 | 12-25-2023 05:54 |
!!!!post Me Your Hardware Problem!!!! | Ustad rajab.Com | Nokia Hardware & Hardware Repair | 32 | 01-18-2013 08:37 |
Search And Post Here Your All 6600 Solution Problem's Ismail Khan | tommobil2005 | Nokia Hardware & Hardware Repair | 0 | 04-04-2006 16:55 |
