Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
03-04-2006, 20:05 | #46 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: Cuttack,India Age: 54
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | Quote:
i dont have jaf i will try to chinese flash tomrrow thanks | |
03-07-2006, 15:56 | #48 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: india Age: 43
Member: 238252 Status: Offline Thanks Meter: 81 | Try This Quote:
03-07-2006, 16:00 | #49 (permalink) |
Member: 238252 Status: Offline Thanks Meter: 81 | I Having Problem With My N Gage Qd Its Goes Blank & Restart Again While Making Call Or Listen Mp3 I Do The Full Flash But Its Given Me Problem Again & Again Pls Give Me Solution I M Upset For This Problem |
03-08-2006, 00:35 | #50 (permalink) | |
Freak Poster Join Date: Feb 2006 Location: pakistan
Member: 232662 Status: Offline Thanks Meter: 58 | Ismail Khan Quote:
after full eras flash download new version and fresh copy of pmm do the full flash phone after flash formate user area and do full ui factory defoult step by step hope you will success try this and let me do reply result if not success contact at : BEST REGARD, Last edited by ..::Neo::..; 04-03-2006 at 17:14. | |
03-08-2006, 15:25 | #51 (permalink) |
Member: 238252 Status: Offline Thanks Meter: 81 | thanks [quote=tommobil2005]full erase flash after full eras flash download new version and fresh copy of pmm do the full flash phone after flash formate user area and do full ui factory defoult step by step hope you will success try this and let me do reply result if not success contact at : BEST REGARD, surely i repply u after the my work done Last edited by ..::Neo::..; 04-03-2006 at 17:14. |
03-09-2006, 11:55 | #52 (permalink) |
Member: 238252 Status: Offline Thanks Meter: 81 | i having problem with 6600 white display i try to flash phone its done but problem still pending so i check inside board there i have flux on disply ic i clean it but not done i also check new ic in market but not available so pls give me jumping solution for it.i m waiting for ur repply |
03-09-2006, 11:58 | #53 (permalink) | |
Member: 238252 Status: Offline Thanks Meter: 81 | thanks Quote:
i do as ur instruction its done but oinly one work i wand to more i.e rehot the uem & bluetiooth ic so its working properly. THANKING YOU ROHIT | |
03-09-2006, 12:04 | #54 (permalink) |
Member: 238252 Status: Offline Thanks Meter: 81 | 6600 Joy Stick Problem I Having Problem With Joy Stick In 6600 Model Its Only Not Move Upside I Change Joy Stick But Problem Still Pending. So Pls Help Me What I Do. Pls Give Me Solution |
03-10-2006, 08:08 | #55 (permalink) |
Member: 238252 Status: Offline Thanks Meter: 81 | Not Charging I Having Problem In Noklia 6600 Not Charging Pls Help Me I Try To Do Software But Its Still Continue Problem Pls Give Me Solution As Early As Possiable. Thanks |
03-10-2006, 10:34 | #56 (permalink) |
Junior Member Join Date: Jun 2005 Age: 44
Member: 152426 Status: Offline Thanks Meter: 2 | camera failure...... first lcd display was blinking and camera working ok after change the crystal display ic display fault ok but hardware failure restart camera fault is now apper? plz help me......with thanks |
03-10-2006, 10:36 | #57 (permalink) |
Freak Poster Join Date: Oct 2005
Member: 186333 Status: Offline Thanks Meter: 4 | i hope we will help to gsm forum members in any hardware sol 101% online support: ([email protected]) br harish (vhb communication) (www.gsmleader.com) |
03-10-2006, 10:51 | #58 (permalink) | |
do not change or remove IC first you check LCD and also LCD connector if is done successfull rehot flash rom2 and full erase flash,and write phone flash again you must write a fresh copy of pm file BEST REGARD, Last edited by ..::Neo::..; 04-03-2006 at 17:23. | |
03-10-2006, 10:57 | #59 (permalink) | |
hope you'll success If a problem occure to contact us, BEST REGARD, Last edited by ..::Neo::..; 04-03-2006 at 17:26. | |
03-10-2006, 11:16 | #60 (permalink) | |
check charging jack and charger pin if also same check charging way's BEST REGARD, ISMAIL KHAN Last edited by ..::Neo::..; 04-03-2006 at 17:26. | |
post me your problem (NOKIA) | nolyboy | Nokia Repair Guide and FAQ | 8987 | 02-27-2024 03:43 |
post me your problem in motorola and let me give you the rite solution | greeni222000 | Motorola Hardware Repair | 2161 | 12-25-2023 05:54 |
!!!!post Me Your Hardware Problem!!!! | Ustad rajab.Com | Nokia Hardware & Hardware Repair | 32 | 01-18-2013 08:37 |
Search And Post Here Your All 6600 Solution Problem's Ismail Khan | tommobil2005 | Nokia Hardware & Hardware Repair | 0 | 04-04-2006 16:55 |
