Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Hardware & Hardware Repair > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 09-01-2014, 08:36   #8836 (permalink)
Member: 2235701
Hi, i need ful pm file for nokia asha 201 , code RM-799 plz help!!!
After reset counter my phone is in contact service mode. I am flash phone by Phoenix and now is in test mode, need to write pm
Old 09-10-2014, 04:43   #8837 (permalink)
Member: 2219122
Thanks Meter: 4
nokia 6111 insert sim promblem
i need help sir, what you have any idea of nokia 6111 insert sim solution.
Old 09-21-2014, 04:11   #8838 (permalink)
sumit070's Avatar
Member: 1938143
Sonork: 051013903
Thanks Meter: 47
nokia 205 mic way needed
hello sir, I need nokia 205 mic way....its urgent
Old 09-21-2014, 11:50   #8839 (permalink)
Member: 2261411
Nokia E7 mobile
ProblemErrorin Usb Connection Disconect cable
please give idea
Old 10-08-2014, 18:59   #8840 (permalink)
Member: 2259691
Pls help me with the solution of bold 2 no service and nokia x2 -00 not displaying but only white
The Following User Says Thank You to TEGOSSLOT For This Useful Post:
Old 10-17-2014, 04:51   #8841 (permalink)
Member: 2230326
any help, plsss.
my nokia n70, no signal
The Following User Says Thank You to nolie26 For This Useful Post:
Old 10-26-2014, 15:24   #8842 (permalink)
Member: 1597170
Thanks Meter: 3
Need Solution NOKIA x2-02 mic,spker,ringer not warking plz need ani solution thx in advance
Iflash with latest tool with latest Flash File Same Product Code but problam stem same Ani solution
Old 11-03-2014, 14:36   #8843 (permalink)
Member: 2257824
Unhappy Sim card invalid
Guys would you please help me with my Nokia 6120c RM-243 after I flash it with BB5 Best after it was successfully flashed i could not accept any sim card always invalid sim. I'ved tried to search for solutions just come up to flashed it with RPL. can somebody tell or show me a tutorial what program should I use or anything to fix my phone. It would be a great help and of course it would be a great experience that will add to my knowledge on fixing mobile phones. Thanks in advance... Godspeed!!!
Old 11-04-2014, 06:53   #8844 (permalink)
Member: 2274761
Originally Posted by jarniel View Post
you can flash it normally same us all dct4 model phones.....
how do i flash my nokia 7210 supernova, i follow all the procedure but i have a problem saying that neither DP1.0 nor DP2.0 was not found for the product or the product cannot be identified.
Old 12-13-2014, 11:02   #8845 (permalink)
Member: 2211135
help
who can help me to security code for nokia 210.. i essai many codes but doesn4t ok.. wait you abassi
Old 12-14-2014, 16:27   #8846 (permalink)
Member: 1520712
Thanks Meter: 19
nokia lumia 800 dead. usb not recognized and when try to power on ,phone do nothing. batery have 4volt voltage . with usb on pcb no power on conectors of battery. please help!!! thanks in advance!!!!
Old 12-23-2014, 12:20   #8847 (permalink)
Member: 2315778
Hi,
The touchscreen of my brother's Nokia Lumia 610 is broken.
What options do i have to recover sms, contacts and files?
I know the PIN code, but i can't enter it.
Is there software available to do that?
Another possibility is to try replacing the touchscreen.
Thanks for your help!
Greetings,
Old 12-24-2014, 21:54   #8848 (permalink)
Syifa.Cell's Avatar
Member: 624037
Sonork: 100.1608764
Thanks Meter: 41
The phone damage by water, I has cleaning the board, I see the PCB is good, no corotion or something wrong.
I has flashing by ATF and UFS with interface USB, All Done, but cannot setting UI, and the phone still syas :"Startup Failed Contact the retailer"
ThiS is maybe hardware trouble?, please anybody help me.
Thanks B4
Sent from my BlackBerry 9220 using Tapatalk
Old 12-26-2014, 10:28   #8849 (permalink)
Member: 2317331
hai... I'm having a Nokia C2-05. its software was tampered & now it contains C1-01 software. i want to Change the mobiles software to the correct one. Plss help.....
Old 12-29-2014, 05:00   #8850 (permalink)
Member: 2318831
Nokia101 lcd light solution pls hlp me
post me your problem in motorola and let me give you the rite solution greeni222000 Motorola Hardware Repair 2161 12-25-2023 05:54
Post me your BB5 problem here.. Ill try to help with Pict Rizal Arsyad Dini Nokia Hardware & Hardware Repair 13 10-05-2014 09:23
!!!!post Me Your Hardware Problem!!!! Ustad rajab.Com Nokia Hardware & Hardware Repair 32 01-18-2013 08:37
post me your all 6600 problem tommobil2005 Nokia Repair Guide and FAQ 459 01-17-2011 12:23
Page generated in 0.26676 seconds with 10 queries
