Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 03-21-2006, 15:55   #796 (permalink)
_iskor_'s Avatar
Member: 94806
Originally Posted by gurson
i got nokia 6600 ...i have lost my security code..n i am suffering.....i cant use my cell........plz help me find it.........plzzzzzzzzzz
ull need the help of a cp technician for that. try to ask for a discount.
Old 03-21-2006, 16:00   #797 (permalink)
_iskor_'s Avatar
Member: 94806
Originally Posted by benchout
my 6600 keypad (menu and OK button doesnt work) please help
check the crystal on the ryt side of the board to board connector. replace if needed.
Old 03-21-2006, 16:05   #798 (permalink)
_iskor_'s Avatar
Member: 94806
Originally Posted by ticoichip
I have 6610.When i charge battery about 6hours-->phone die.
Now i try to flash.It's okie.But cant info.
I also do : relfow.UEM,Ram,Harga.---> flash okie .Check okie ,Cant info
Pls help me
are using jaf? try to power on phone. jaf does not display local mode if UEM is damage. if u cant power on phone mannually then replace UEM.
Old 03-21-2006, 16:08   #799 (permalink)
_iskor_'s Avatar
Member: 94806
Originally Posted by BoomBoy
Then i install the following software and have installed the Dongle, and open the program (software prog....) it's comes up with a box that tells the program had vault, and then close..
just let the installer finished installing , then try to search and pair a device.
Old 03-21-2006, 16:19   #800 (permalink)
_iskor_'s Avatar
Member: 94806
Originally Posted by bboyredcel
I have a 6230b and a 6230i... I was wondering if i can somehow mess with the RF or something to allow the 6230i to accept 850/1800/1900 so that it will work better in the US? Is there anyway to reflash the 6230i to accept 850? or change some hardware? I'll do any steps necessary cuz i am interested in learning how to do this and getting my 6230i up and running full steam here in the US...
I have the 6230i that does not get very good reception around my area, the towers local to me are 850 for the most part... I also have a 6230b which gets rediculously good reception around me, how do i go about converting the 6230i to support the 850 frequency?
any and all help is much appreciated!
6230i is primarily made to work with asian region which uses gsm 1800 and 1900, while us uses 850 2000 mghz. when a phone from US came here in the PH we usually replace filters to work with gsm 1800 n 1900. why not try to replace 6230i filters with the one that comes from a phone that uses 850 n gsm2000.
hope i got it ryt.
Old 03-21-2006, 16:21   #801 (permalink)
_iskor_'s Avatar
Member: 94806
Originally Posted by fanbang
thanks for replying. received a w800 with same problem today.
have you got a picture of where is LCD driver is?
thanks again
searching the thread will help u a lot?
good luck!
Old 03-21-2006, 16:23   #802 (permalink)
_iskor_'s Avatar
Member: 94806
Originally Posted by Moldovanus
I have a SX1. I have done a phone format using the *#7370# code and now the phone won't start with my memory card inside:it says "Aplication closed:Phone" and "contact retailler". if i remove the memory card, the phone starts normally. but when i insert my memory card it says "App.closed AppArcServerThread". this error appears over and over again, blocking my phone. please help
formating ur memory card wilh solve the problem and it should.
Old 03-21-2006, 16:34   #803 (permalink)
_iskor_'s Avatar
Member: 94806
Originally Posted by Barbaros
When i download *RAR. files i cant install them onto my phone, so i changed it to 'Open with nokia app installer' didnt work. i tried copy pasting them and then installing with a file manager but it just gave an error. I tried to 'Open with word' This did get on my phone but now it says ''No Default viewer for *.RAR''
what is ur phone model and what are u trying to install.maybe u are trying to install a jad or a jar file with ur wd2 phone. it will not work.
wd2 phones need a sis file.
Old 03-21-2006, 16:41   #804 (permalink)
_iskor_'s Avatar
Member: 94806
Originally Posted by saanus
what is the use of "auto CNT" option in UFS?
ur reseller will help u a lot.
Old 03-21-2006, 16:48   #805 (permalink)
Member: 217367
Pls help me
UEM is damage, replace UEM.
Old 03-21-2006, 21:26   #806 (permalink)
Member: 237321
Originally Posted by brikyo
i have a problem... i have N70. I have a problem reading sms when i change my themes into a dark coloured or a colourful themes. the colour of the sms fonts is black..and i cant seem to change it... is there any solution to this? i want to be able to enjoy beautiful themes without having to worry about not being able to read sms.
any help/reply would be greatly appreciated.
thanks
Originally Posted by bingo_888
hi,
go to settings, display, then adjust light...
Its a litle bit better now thanks~! but is there any other way perhaps to change the colour of the sms font? or is there a program to read sms? i am still having problem reading it if the background is totally black like a Nike theme.
Thanks a lot for the reply though, appreciated it.
^__^
thanks heaps
Old 03-21-2006, 21:44   #807 (permalink)
Member: 245217
master code for hash code
hi,
can anyone give me the master code for a hash code.
I need to access bios .
ta
Old 03-22-2006, 01:57   #808 (permalink)
Member: 218345
nokia2600 file
dear nolyboy please send me nokia2600 new version file on my mail thank you my mail id is agrawaltimengd37@rediffmail.com
Old 03-22-2006, 04:40   #809 (permalink)
nolyboy's Avatar
Member: 197247
already there pls check ur mail
Old 03-22-2006, 04:50   #810 (permalink)
nolyboy's Avatar
Member: 197247
[quote=saanus]what is the use of "auto CNT" option in UFS?[/quote
one thread is enough pls dont spam this thread]
post me your problem in motorola and let me give you the rite solution greeni222000 Motorola Hardware Repair Section 2051 06-15-2013 03:25
!!!!post Me Your Hardware Problem!!!! Ustad rajab.Com Nokia Hardware & Hardware-Repair Area 32 01-18-2013 07:37
Post me your BB5 problem here.. Ill try to help with Pict ichal_spy Nokia Hardware & Hardware-Repair Area 10 11-15-2012 10:43
post me your all 6600 problem tommobil2005 Nokia Repair Guide and FAQ 460 01-17-2011 11:23
Page generated in 1.08221 seconds with 12 queries
