Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Hardware & Hardware Repair > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 04-07-2014, 17:09   #8791 (permalink)
Member: 2123204
Sir i have a nokia 5800 xpress music although it was working fine suddenly the three keypad and the camera botton is not working but keypad light is working..could u please suggest me a solution .THANK YOU SIR IN ADVANCE !.
Old 04-15-2014, 06:39   #8792 (permalink)
Member: 556789
nokia c2 RM-704 white display but phone is working i have change display but same problem. any solution?
Old 04-17-2014, 03:00   #8793 (permalink)
Member: 1351606
nokia N900
i flash image and fiasco but still no apps come up when i press menu and low memory warning can u help
Old 04-17-2014, 07:26   #8794 (permalink)
Member: 1291503
Originally Posted by nolyboy View Post
hey guys post your problem here ill try to help
i have network problem with my nokia n95 pls send jumpering for this pls
Old 04-18-2014, 06:11   #8795 (permalink)
Member: 2063449
solution change the nokia c2 flex cable [strip]
Old 04-18-2014, 06:29   #8796 (permalink)
Member: 2063449
Originally Posted by Ejy View Post
I restarted my x2-01 cellphone, after it restart it asked me for my security code.
I forgot my security code, is there's a way that i could retrive my password or just remove the security code? THANK YOU SIR!
You can format your Nokia X2-01 device by reinserting battery and pressing 3 keys at a time: * + 3 + call + Power on. Before the device is reset,
Old 04-18-2014, 08:20   #8797 (permalink)
Member: 2063449
Originally Posted by astig_king24 View Post
sir help please how to recover my nokia xpressmusic 5530 RM-504 and what tools i use?
because my nokia is can't open only vibrate no power? help please?
vibrate means there is power if there is no display then change the display if it didn't work i will give jumper solution
Old 04-18-2014, 08:24   #8798 (permalink)
Member: 2063449
Originally Posted by sudhakarkg View Post
sir nokia206 insertsim problom. sim ic. and sim control ic. changed. problom not solv. plz send me any solution. sir...
try changing battery some times that help or change sim connector
Old 04-18-2014, 08:28   #8799 (permalink)
Member: 2063449
Originally Posted by jijutony2010 View Post
nokia c7 low network problem
did you change the housing panel ?
if not then replace the antenna .
Old 04-18-2014, 08:40   #8800 (permalink)
Member: 2063449
Old 04-18-2014, 08:42   #8801 (permalink)
Member: 2063449
the best thing is to use jumper solution rather changing the ic it last long .
Old 04-22-2014, 17:50   #8802 (permalink)
Member: 1911905
Hi, I've got a Nokia N98 that will output the ringer/buzzer noise too low, I tried with a couple of new loudspeakers, but still had no luck.
Any suggestions?
Thanks!
Old 05-08-2014, 19:22   #8803 (permalink)
Member: 2167423
Sonork: 100.1655428
Driver problem
I got a problem, MTK usb com port driver falt on device manager win xp,
mobile conectivity shows( MTK 6253 if) (MTK 6225 debug) plzzz help
Old 05-12-2014, 11:46   #8804 (permalink)
Member: 2184853
Nokia N900 Memory Corrupted
Hey I have Nokia N900. The problem is while using phone it show memory card corrupted it has inbuilt 32 GB memory no external card is used. but when i connect the phone to PC in Mass storage mode it shows the full memory and allow to store or read data.
as soon as i disconnect it the memory is not accessible .
Help me for the same
Old 05-15-2014, 16:17   #8805 (permalink)
Member: 2186981
Nokia 6280
please watch the video because I don't know how to explain it properly.
the phone boots to Nokia screen then the screen turns on and off before switching off.
http://www.youtube.com/watch?v=fwulDbuYqxY
post me your problem in motorola and let me give you the rite solution greeni222000 Motorola Hardware Repair 2161 12-25-2023 05:54
Post me your BB5 problem here.. Ill try to help with Pict Rizal Arsyad Dini Nokia Hardware & Hardware Repair 13 10-05-2014 09:23
!!!!post Me Your Hardware Problem!!!! Ustad rajab.Com Nokia Hardware & Hardware Repair 32 01-18-2013 08:37
post me your all 6600 problem tommobil2005 Nokia Repair Guide and FAQ 459 01-17-2011 12:23
Page generated in 0.24219 seconds with 10 queries
