Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
12-29-2005, 02:08 | #137 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: PHIL
Member: 197247 Status: Offline Thanks Meter: 296 | Quote:
12-29-2005, 02:09 | #138 (permalink) | |
12-29-2005, 02:11 | #139 (permalink) | |
12-29-2005, 05:19 | #140 (permalink) |
Junior Member Join Date: Sep 2005 Age: 42
Member: 182994 Status: Offline Thanks Meter: 0 | pls help 6600 Detected: V 5.53.0 30-12-04 NHL-10 (c) NMP 1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x007FFFFF,0001277E,Amd 29BDS064J Fl1: 0x02000000-0x027FFFFF,0001277E,Amd 29BDS064J Fl2: 0x04000000-0x047FFFFF,0001277E,Amd 29BDS064J Fl3: 0x06000000-0x067FFFFF,0001277E,Amd 29BDS064J Algorithm: w3_amd.fia, w3_cbusb.fia Algorithm Ok, MSID: 844501BA46B0029DBA53797584 Decoded MSID: 3E4EBAF7-00D20FCD-A9000000 Encoded FAID: 15C6F0BE-4AF00A18-3C34EC71 Erasing: 0x00000000-0x0000FFFF ... Erasing Error: 10, at: 0x00000000-0x0000FFFF, 940207, Time: 00:00 Process Failed, Repowering Mobile can same bady help? |
12-29-2005, 08:20 | #142 (permalink) | |
12-29-2005, 09:23 | #144 (permalink) |
No Life Poster Join Date: May 2005 Location: GULMI Age: 49
Member: 143007 Status: Offline Thanks Meter: 141 | 3230 white screen hi @nolyboy ]hey guys post your problem here ill try to help: sir ihave a smole problem a 3230 white screen sir i have a full flashing mcu end ppm all ui options end format user area but no reseld im check lcd is good check iner key pad bourd is good all conncter ree hat all ic s the problem is same im mack 20 pis same problem iner key cheng is ok ) but 5 piss. not working sir plg guid me mobile is on i put card end call only ringing i acapetd but yes key not working plz sir guid me 3230 white screen ???? thankSyou |
12-30-2005, 03:30 | #148 (permalink) | |
12-30-2005, 06:15 | #149 (permalink) |
No Life Poster Join Date: Sep 2004
Member: 82423 Status: Offline Thanks Meter: 1,203 | 9500 I need Display IC Solution With Picture ----------------------------------------- Hi, I have faceing Some problem 9500. After cahnge the display still blank set was liqvid damage i want to know which will be display IC. So please any one know about this problem so please shere with picture. regared Irfan Amin [email protected] |
post me your problem in motorola and let me give you the rite solution | greeni222000 | Motorola Hardware Repair | 2161 | 12-25-2023 05:54 |
Post me your BB5 problem here.. Ill try to help with Pict | Rizal Arsyad Dini | Nokia Hardware & Hardware Repair | 13 | 10-05-2014 09:23 |
!!!!post Me Your Hardware Problem!!!! | Ustad rajab.Com | Nokia Hardware & Hardware Repair | 32 | 01-18-2013 08:37 |
post me your all 6600 problem | tommobil2005 | Nokia Repair Guide and FAQ | 459 | 01-17-2011 12:23 |
